Tarantula_TJ Rubicon Build - Page 94 - JeepForum.com
 2Likes
post #1396 of 3547 Old 12-16-2012, 02:02 PM Thread Starter
AngryTJ
Originally Posted by mbporesky
Are you going to 4 link it? why not just do a 3 link. Or is the blue links just showing each side
I already 4 linked i just never put my measurements in the calculator to see my numbers
AngryTJ is offline
post #1397 of 3547 Old 12-16-2012, 05:18 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
I believe that's the rear, 3 link rear would just be crazy.
The CG looks high if that is 34
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1398 of 3547 Old 12-16-2012, 08:06 PM Thread Starter
AngryTJ
It is the rear. Didn't really know where to measure for CG, any recommendations?
AngryTJ is offline
post #1399 of 3547 Old 12-16-2012, 08:16 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
I use the bell housing bolt that is above the starter.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1400 of 3547 Old 12-16-2012, 08:23 PM Thread Starter
AngryTJ
Ill have to double check all my measurements. By lowering the CG it makes my antiquat # jump way up.
AngryTJ is offline
post #1401 of 3547 Old 12-16-2012, 09:03 PM
Holaday
Where is this? Can I go wheeling with you guys next summer?
Holaday is offline
post #1402 of 3547 Old 12-16-2012, 11:32 PM Thread Starter
AngryTJ
you mean this place?
Rausch Creek, PA
This video is muted so dont think your speakers are broke.
AngryTJ is offline
post #1403 of 3547 Old 12-18-2012, 03:17 PM
mbporesky
Its the rear.... That explains it.
If it aint broke, fix it till it is.
mbporesky is offline
post #1404 of 3547 Old 12-20-2012, 11:00 AM Thread Starter
AngryTJ
Updated measurements I believe are more accurate...
How do you post the 4 link calculations? This cell pic will have to do for now
AngryTJ is offline
post #1405 of 3547 Old 12-20-2012, 11:12 AM
Imped
Imped's Avatar
Save it, select the cells you want to copy and paste it into paint. Save that file as a JPG and upload it to your host site like Photobucket. I changed a couple things and hosted the pic to my PB account so here you go.
OlllllllO
IndyORV
Imped is offline
post #1406 of 3547 Old 12-20-2012, 11:27 AM Thread Starter
AngryTJ
Ahh ok that makes sense.
So I'm new to the whole calculator thing but how does it look? Why does yours have a static antisquat?
AngryTJ is offline
post #1407 of 3547 Old 12-20-2012, 12:01 PM
Imped
Imped's Avatar
You're using the same version I am. No idea why mine is labeled 'static' and yours isn't. Regardless of the label, the number is representing the exact same thing.
The changes I made and why:
1) Bumped up the veritical separation at the frame by lowering the lower frame mount 1". That brought the AS down and moved you from an oversteer to a very slight understeer situation. Much more desirable.
2) Moved the upper frame mount back a bit to give the upper and lower links a closer effective length.
I think that's a good plan to move forward from.
OlllllllO
IndyORV
Imped is offline
post #1408 of 3547 Old 12-20-2012, 02:20 PM Thread Starter
AngryTJ
That all makes sense until your last sentence. My rear 4 link is already complete I just wanted to plot my measurements and see what the values came out as. Dont know if you recall but I used the poly brackets on the frame side so my uppers and lowers are roughly on the same plane therefore the upper mount cant be moved back. Im not 100% sure all the measurements are accurate but fairly close.
Heres how the values will be affected with a 5in stretch.
AngryTJ is offline
post #1409 of 3547 Old 12-20-2012, 02:42 PM
Imped
Imped's Avatar
Yes, I know you're already 4 linked. What I meant was if you plan on making any changes to the mounts or wheelbase in the future you're in good shape as it sits.
OlllllllO
IndyORV
Imped is offline
post #1410 of 3547 Old 12-25-2012, 12:05 PM Thread Starter
AngryTJ
Merry Christmas everyone! Have an amazing day and I hope everyone got what they wanted
AngryTJ is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 08:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 07:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 04:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 02:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 01:04 PM
