Tarantula_TJ Rubicon Build - Page 60 - JeepForum.com
 2Likes
post #886 of 3547 Old 05-17-2012, 11:38 AM Thread Starter
AngryTJ
Originally Posted by KevKaos View Post
That's not hard to do with Lu's thread. He's throwing money at his rig like its a high class call girl.
HEY!! ..... She makes me feels special
AngryTJ is offline
post #887 of 3547 Old 05-17-2012, 01:19 PM
KevKaos
I bet she does. hehehe
Are you planning on using a Speedohealer or anything to get your speedo back in synch after doing the bigger meats? I'm like 3mph off at highway speed with my 33s.
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #888 of 3547 Old 05-17-2012, 02:05 PM Thread Starter
AngryTJ
I have a programmer so Yeah I corrected the speedo in relation to the tire size Im running
AngryTJ is offline
post #889 of 3547 Old 05-17-2012, 02:29 PM
KevKaos
So what are you using to do that? I was looking at the SpeedoHealer, but you have a programmer that does more? I dont remember reading about it in your thread.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #890 of 3547 Old 05-17-2012, 02:36 PM Thread Starter
AngryTJ
Im using a Superchips Jeep Programmer. It allows me to program for tire size change, gear ratio, better gas mileage, read check engine lights, 4hi locker mod and other shiznit.
Off topic are those alloy axle seals you have still causin issues?
AngryTJ is offline
post #891 of 3547 Old 05-17-2012, 09:11 PM
KevKaos
Yeah! I hate them. Maybe if I had read that you can use form a gasket to keep them in place, I would feel better about them.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #892 of 3547 Old 05-20-2012, 08:03 PM Thread Starter
AngryTJ
Got started tearing down the rear suspension to start my 4link.
Few before shots:
Stripping down and removing the rear axle:
Cutting and Grinding (not the final product) Such a b*itch
So worked for about 5 hours and we got the axle out, frame lower control arms brackets cut off, all brackets on the axle cut off and ground down, trac bar bracket cut off, and started to cut the upper spring perch.
Im happy with that progress, anyone have any tips on how to cut the spring perches on the inside of the frame!?
AngryTJ is offline
post #893 of 3547 Old 05-20-2012, 09:46 PM
KevKaos
You put those axle tube caps on yet? We took mine off today, and you should see what happens to them when they spin in the tube like mine did. I'll have to get a pic up so you can see them.
Now about tops. I know you said that you got a Rampage, and I saw pics of it. And I know you said you like it. Are there any cons in your opinion? I gashed my top on a tree while doing an off camber section,mso I need a new top. Do you still have to se the door surrounds? One got a little piece broken off, but I can fix that. I really thought I would have more time to figure out what top to get, but such is Honey Badger wheelin.
You ever sell that Novack shifter? Looks like I might have to do one of those as well. My linkage is all F'd up. At least that all I hope is wrong with the Transfer Case.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #894 of 3547 Old 05-20-2012, 10:30 PM
Driver831
Too bad you don't have a torch, would make a lot less grinding too. looks good tho!
Driver831 is offline
post #895 of 3547 Old 05-20-2012, 11:23 PM
MO2500
Lu, when I removed my spring perches, I just cut the outside welds and then beat on them with a BFH back and forth until I broke the welds on the inside of the frame rail. Are you re-using the perches or replacing them with aftermarket?
Instagram: @omsmike
MO2500 is offline
post #896 of 3547 Old 05-21-2012, 05:56 AM Thread Starter
AngryTJ
For the top you need door surrounds, windshield header and tailgate retainer.
Extra Novak shifter I had is long gone.
I wish. Thanks
Planning to reuse them
AngryTJ is offline
post #897 of 3547 Old 05-22-2012, 07:11 PM Thread Starter
AngryTJ
About time
AngryTJ is offline
post #898 of 3547 Old 05-22-2012, 07:57 PM
MO2500
You ended up switching to the discovery shafts right?
Instagram: @omsmike
MO2500 is offline
post #899 of 3547 Old 05-22-2012, 08:44 PM
bobthetj03
Dang! You ain't messing around! Way ta jump right in to it!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #900 of 3547 Old 05-22-2012, 08:51 PM Thread Starter
AngryTJ
Yeah still got the chromoly ujoint but went with Discovery shafts since there was no timetable for the evolution.
Yeah man its finally time. Cant wait till its done!
AngryTJ is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 08:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 07:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 04:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 02:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 01:04 PM
