Tarantula_TJ Rubicon Build - Page 179 - JeepForum.com
 2Likes
post #2671 of 3547 Old 01-29-2014, 08:10 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Where did you get it and what is the length?
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #2672 of 3547 Old 01-29-2014, 08:35 AM
MO2500
12" spot/flood combo with 3 watt Crees, he got it through a group buy one of the members of my local club organized. I picked up a couple too, they are freaking bright!
Instagram: @omsmike
MO2500 is offline
post #2673 of 3547 Old 02-18-2014, 10:32 AM
TURBevO8
Hey man! As I am coming closer and closer to my next project I may have to pick your brain a bit. That being the rear stretch. Two questions come to mind. One, when notching the frame for the outboarding, how did you determine how far into the frame to cut initially? I would think you would want to cut the minimum while having the shock clear the tire and anything else. Second is you used the Synergy/Poly frame mounts right? I am going to have to dig back through to see how you set and welded them. Any pointers? Thanks!
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline
post #2674 of 3547 Old 02-18-2014, 10:41 AM
TURBevO8
Third question...what did you about the rear x-member (formerly used for tub and shocks) that you cut in post 1609 (2nd pic down shows it perfectly)? Did you just ditch it and the 2 body mounts or fab up something new? Sorry, just too many pages!
TURBevO8 is offline
post #2675 of 3547 Old 02-18-2014, 12:30 PM Thread Starter
AngryTJ
1) Will you be using the stock upper bucket?
Im trying to remember but I believe I measured exactly 5 inches rearward from my rear bump stop and marked it on the frame. I then measured how big my upper coil mount was to ensure the bump stop would be in the center of that mark and how much of the frame I needed to notch to ensure it fell in place. Then before cutting while the rear axle was still in place I set the axle at full bump with no springs and measured to ensure a full 5 in stretch would clearance the tank. Not sure if thats the best way to do it but it worked for me.
2) Yes I used the poly mounts and set them about an inch from touching my tcase skid on the frame and welded them in. The artec brackets are just as good you simply need to weld them together yourself.
3) The rear crossmember I notched to allow my stock upper coil bucket to fit in the middle of the frame and still touching the crossmember. Its welded to the frame and the crossmember. I also have to notch the crossmember because my upper truss hits since I sit low but I havent had the time to do so.
AngryTJ is offline
post #2676 of 3547 Old 02-18-2014, 03:51 PM
TURBevO8
Hey thanks for the response.
1. Sorry, I was not clear. I was referring to the shock towers. I am going to use the Ford F250 towers and not sure how far into the frame I need to cut. I was hoping to not have to keep cutting a little off at a time, but also don't want to remove more of the frame rail than I have to.
2. I already got the Poly mounts and geometry figured out. I was just hoping you wouldn't say something like "I had to remove all the body mounts and jack up the tub to access to weld the top to the frame" or something like that.
3. I see what you did there. That makes sense. I think I may just use some 1x1x1/4" tube away from where the truss mounts will be when flexed to add rigidity back to the frame. I may skip those 2 body mounts or I may tie in to them with some plate. I have a 1.25" BL and will just remove the BL at those 2 mounts to be able to mount a bit higher. I'll post pics!
Thanks again...
TURBevO8 is offline
post #2677 of 3547 Old 02-18-2014, 05:18 PM Thread Starter
AngryTJ
I cut the frame almost all the way through. You want to make sure your lower axle shock mount is as far outward as possible so when looking from the front or rear of the jeep they are mounted as much like / \ as possible.
You can see I left a small lip from the frame and then cut a slot in the tower for more welding area.
AngryTJ is offline
post #2678 of 3547 Old 02-18-2014, 08:37 PM Thread Starter
AngryTJ
Final trail ride of my trip last summer
AngryTJ is offline
post #2679 of 3547 Old 02-18-2014, 08:46 PM
MO2500
That's it.... we have to go back...
Instagram: @omsmike
MO2500 is offline
post #2680 of 3547 Old 02-18-2014, 10:14 PM
aw12345
We gotta gotta do Carnage canyon, looks like a hoot
aw12345 is offline
post #2681 of 3547 Old 02-18-2014, 10:15 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
I'm in.
gst95dsm is offline
post #2682 of 3547 Old 02-18-2014, 10:23 PM
kyle_craig
Chinaman's is a good time. Carnage is uber gnar-gnar.
kyle_craig is offline
post #2683 of 3547 Old 02-18-2014, 10:40 PM
aw12345
That's exactly what makes it a fun challenge
aw12345 is offline
post #2684 of 3547 Old 02-19-2014, 05:44 AM
TURBevO8
Angling them like that would help them not smack into the frame when flexing the axle. Ex: droop the driver side and raise the passenger side and the shock smacks into the frame if you do not do what you are saying. I get it. Thanks!
PS: When the weather gets warm I am going to hold you to that Rausch Creek trip we talked about a while back. I'm heading up there this Sat actually. Last run on 94.5" WB.
TURBevO8 is offline
post #2685 of 3547 Old 02-19-2014, 09:52 AM
gspup
Ya, not sure I ever want to be on that trail with my junk.
I'm in.
I will be there when you run Carnage. Bring your spare 8.8
gspup is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 07:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 06:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 03:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 01:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
