Tarantula_TJ Rubicon Build - Page 177 - JeepForum.com
 2Likes
post #2641 of 3547 Old 01-17-2014, 09:17 AM
janesy86
Lou, I think I remember you getting some UCF windshield guards... Did you ever mount them up? Curious on the fitmet. I want to get some to protect the replacement windshield frame I'm picking up this weekend to prevent what happened to my current one.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #2642 of 3547 Old 01-17-2014, 10:14 AM Thread Starter
AngryTJ
Yes they are mounted, fitment was good however hardware included sucked so I purchased some button head bolts to use instead.
I also grinded off the weld that shows on the surface
AngryTJ is offline
post #2643 of 3547 Old 01-18-2014, 07:59 PM
aw12345
Here's something to think about, denting the windshield frame is not desirable. But with armor plating on the sides the change that you kitty corner it is much greater and that's pretty much the end of your wind shield and the frame
aw12345 is offline
post #2644 of 3547 Old 01-19-2014, 07:58 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
If you don't want to hit the windshield frame, fold it down or remove it.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #2645 of 3547 Old 01-19-2014, 08:08 AM
purplepig
Or you put it on to cover the damage that is already there.
purplepig is offline
post #2646 of 3547 Old 01-19-2014, 09:07 AM
janesy86
Thats ultimately what I plan on doing for some of the more hardcore trails. Drill out the hinge and put in something like a hitch pin.
Current frame is just too beat up and would need too much time to get it right to even fit the armor...
janesy86 is offline
post #2647 of 3547 Old 01-19-2014, 09:11 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
If that's the case, look into a 97-02 frame due to much less trim that won't have to be removed from the frame every time you fold/remove it. Imped did the swap I believe. I want to cut off the pins and put a quick release piece for the frame. One day....
16 Taco
dayriesw is offline
post #2648 of 3547 Old 01-19-2014, 10:04 AM
OkLaHoMaTJ
Angry I think you can trim the Savvy UA pieces to fit around your body mounts. Just a though. I too like the idea of being able to drop the skid and have a separate crossmember holding up the drivetrain.
I do agree with you about the MML tho. In order to use the engine skid you have to use the Savvy MML. Kinda sucks and I wonder if there is a way to get around that?
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline
post #2649 of 3547 Old 01-19-2014, 02:51 PM
janesy86
Just picked up a mint 97-02 frame. Will swap out once I do the cage...
Thats what I plan to do once I do the raised body mounts. Shouldn't be to hard, just a little trimming. Could even weld on the outer pieces too Really they don't have to come off unless you want to take the whole enchilada off.. As for MML, just come up with your own brace mount, shouldn't be too hard with some steel and a welder.
janesy86 is offline
post #2650 of 3547 Old 01-19-2014, 07:44 PM
aw12345
You don't drill the pins, just cut between the slots of the hinge then drive the outer part of the pins outwards. 7/16" bolt fits it perfect
aw12345 is offline
post #2651 of 3547 Old 01-20-2014, 06:07 AM
janesy86
Thanks bud, haven't seen any info so that helps.
janesy86 is offline
post #2652 of 3547 Old 01-20-2014, 08:56 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
That is the process I have seen. Just cut one of the bolt's flanges off and drive it out. Then get a long shafted 7/16, cut the threads off, drill through the center for a pin and done.
16 Taco
dayriesw is offline
post #2653 of 3547 Old 01-20-2014, 09:55 AM
aw12345
actually the hinge has 2 pins in it that are serrated right behind the head. So what you want to do is cut both pins in the slots of the hinge.
then you can drive the remainder of the pins outwards. You don't have to bother with locking the replacement pin the windshield rubber puts pressure on the frame when bolted in place which retains the pivot pins nicely.
aw12345 is offline
post #2654 of 3547 Old 01-26-2014, 07:15 PM Thread Starter
AngryTJ
Finally in her new home
Untitled by lverdura28, on Flickr
AngryTJ is offline
post #2655 of 3547 Old 01-26-2014, 07:38 PM
Shobes
Originally Posted by AngryTJ
Finally in her new home Untitled by lverdura28, on Flickr
Awesome man! Congrats! Good looking man cave
My "hard way" build -
Shobes is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 08:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 07:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 04:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 02:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 01:04 PM
