Tarantula_TJ Rubicon Build - Page 174 - JeepForum.com
 2Likes
post #2596 of 3547 Old 12-20-2013, 02:44 PM
Lemmiwinks
You should also check out JonFund
Lemmiwinks is offline
post #2597 of 3547 Old 12-21-2013, 02:52 PM
TURBevO8
This may be a bit off topic but a few pages back I saw you guys talking about high line washer bottle options. For those it may help, I used the one below and it works amazingly well!
link:
http://store.amequipment.com/15l-was...-12v-p-73.html
pics:
http://www.jeepforum.com/forum/f9/ge...02/index8.html
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline
post #2598 of 3547 Old 12-23-2013, 04:14 PM Thread Starter
AngryTJ
I have looked into them as well as ronin wheelers
Originally Posted by TURBevO8
This may be a bit off topic but a few pages back I saw you guys talking about high line washer bottle options. For those it may help, I used the one below and it works amazingly well! link: http://store.amequipment.com/15l-was...-12v-p-73.html pics: http://www.jeepforum.com/forum/f9/ge...02/index8.html
Thanks for the added info!
Don't forget to go over and vote for tjoty guys and gals. The contest is coming to an end very soon.
AngryTJ is offline
post #2599 of 3547 Old 12-25-2013, 07:35 AM Thread Starter
AngryTJ
Merry Christmas everyone!
AngryTJ is offline
post #2600 of 3547 Old 12-25-2013, 08:09 AM
G Beasley
Merry Christmas to you and yours .
G Beasley is offline
post #2601 of 3547 Old 12-25-2013, 01:07 PM
aw12345
helldorado21 by aartjestaartje, on Flickr
aw12345 is offline
post #2602 of 3547 Old 12-25-2013, 04:54 PM Thread Starter
AngryTJ
Originally Posted by aw12345
Merry Christmas guys!
AngryTJ is offline
post #2603 of 3547 Old 12-26-2013, 10:22 AM
Sarge30
Lou..
Just spent past few days reading your build. Came a long way in past few years. I see you have the Riddler diff covers. Did you have any issues with the front one hitting the trackbar? All the threads I have read, it will hit. Anything you did special? I see you have the JKS trackbar and the Currie steering. Thanks,
Sarge30 is offline
post #2604 of 3547 Old 12-26-2013, 10:32 AM
gspup
Originally Posted by Sarge30
Lou..
Look at the Barnett diff cover. That's what I'll be buying.
gspup is offline
post #2605 of 3547 Old 12-26-2013, 10:41 AM
janesy86
I love mine! Beefy where it needs to be, excellent clearance.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #2606 of 3547 Old 12-26-2013, 12:39 PM Thread Starter
AngryTJ
Originally Posted by Sarge30 View Post
Lou..
Sarge with your 4.5" springs you should have no issues. When I had my 4" zone springs I did not interfere with the riddler at all.
Now that I've dropped in ride height I notice it has scrapped it very lightly but I plan to address that this winter by seeing if anything needs to be adjusted or simply grinding down that spot a little.
Also thanks for taking the time to read through
AngryTJ is offline
post #2607 of 3547 Old 12-26-2013, 02:24 PM
MO2500
If it will hit with less lift it will hit with any amount of lift, spring height doesn't make things clear. You have to pull the springs and soft rubber from the bumps and cycle everything to see clearance issues as sometimes higher ride height will hide a problem until you put the suspension in a certain situation and the clearance issue shows itself. Longer bump stops can prevent clearance issues but we all know we want the least amount of bump possible to achieve better uptravel numbers so it's not always the best solution.
Instagram: @omsmike
MO2500 is offline
post #2608 of 3547 Old 12-26-2013, 02:34 PM Thread Starter
AngryTJ
Interesting...must have been the bumps I adjusted rather then the spring swap that caused the rubbing. Huh
AngryTJ is offline
post #2609 of 3547 Old 12-26-2013, 10:15 PM
Sarge30
I've read with 2" bump you should be fine. I then saw you reduced your lift and figured you would have adjusted your bumpstops not to loose travel. To make things easier, I will probably just go with the Barnett cover. I first need to check my caster as Im hitting the diff cover bolts with the RE crapbar, then go from there. Thanks to all for the insight...
Sarge30 is offline
post #2610 of 3547 Old 12-30-2013, 05:03 PM Thread Starter
AngryTJ
I guess as a jeep owner you never really do make up your mind. Decided to visit the new Clayton shop and pick up a couple goodies.
AngryTJ is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 07:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 06:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 03:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 01:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
