Tarantula_TJ Rubicon Build - Page 163 - JeepForum.com
 2Likes
post #2431 of 3547 Old 10-25-2013, 11:10 AM
g-rocc
This is one of the worst problems to have. I know all too well about it. I ended up just buying the centramatic wheel balancers and that was the best thing I did. I wasn't able to drive 45 w/o shaking to pieces then I slapped those on and I can go 75 maybe even 80 if Caleb is leading.
g-rocc is offline
post #2432 of 3547 Old 10-25-2013, 11:21 AM
MO2500
Can condensation build up overtime in the tire from repeated deflation and inflation with not very dry air (straight from a compressor not nitrogen or air run through an air dryer) and cause the beads to stick together?
This probably doesn't help you at all, but I used 8-10oz of airsoft BBs in my 37's prior to mounting them, no noticeable imbalance while at speed offroad
Instagram: @omsmike
MO2500 is offline
post #2433 of 3547 Old 10-25-2013, 01:26 PM Thread Starter
AngryTJ
Originally Posted by kyle_craig View Post
Are they wearing evenly? If so, I'd just switch em back!
No they needed to be rotated
On mine I do a static balance with tape weights. It takes A LOT of weight, 6 to 8 ounces but I've never had an issue doing it this way. I would first rule out that what you were feeling isn't just a temporary flat spot in the tire due to them sitting, and it being very cold in the morning.
Yeah the tire shop I took it to way back when wouldnt add that much weight. They said it needed about 8oz but wouldnt do it for liability reasons I assume.
Originally Posted by Hendrix View Post
My local discount tire will do bead locks but only if I call ahead so I get a fresh daily calibration first thing in the morning. Might be worth a try to stop by there and ask. Then schedule a balance with them. Need to vacuum all the beads out first.
I feel your pain, been there with my krawlers.
I might have to try something like this if it continues to act up. Not having a garage though sucks because its getting cold and I dont want to be dismounting beadlocks in 30* temps.
Originally Posted by aw12345 View Post
Somewhere back in time I had dynabeads in my front tires and it did much the same as you experience. It would shake so violently at times that the front would actually move up end down. First jack the front up slightly spin the tire with a jackstand near it to check it for runout and wobling on the rim. If all that is good get a proper tire balance
Are your 40s properly balanced by a shop?
never looked into those.
Thats my theory because when I first get it on the road the shakes appear and the longer I drive the jeep and go from slow speeds to higher speeds it then goes away or at least is less noticeable.
AngryTJ is offline
post #2434 of 3547 Old 10-25-2013, 01:36 PM
g-rocc
They work great. Check out the below video. I tried everything from weights to air soft bb's and couldn't get nearly as well off as they did for me.
g-rocc is offline
post #2435 of 3547 Old 10-25-2013, 01:50 PM
janesy86
Those are pretty interesting!
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #2436 of 3547 Old 10-25-2013, 02:41 PM
aw12345
Luciano the shaking up front in a TJ is related to the steering setup.
On my big Jeep I can run what ever tire I like unbalanced find a down hill hit 80 mph and no shakes.
The thing has had some good tires on it as well as several sets of old rags hasn't had a shimmy or shake yet. Got to love true hi steer and hydro assist. Here is a thought to further narrow it down. Swap one front tire at the time to the back see if you can isolate it to one tire.
Goodyear produced a bad batch of 35 and 37" MTR's that are about impossible to balance, you could have one of those. Got a tire waranty?
aw12345 is offline
post #2437 of 3547 Old 10-25-2013, 05:46 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I think I have 5 tires from the bad batch.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #2438 of 3547 Old 10-25-2013, 06:04 PM
GregStephens2
Another thought of mine is that the rim is not centered in the tire properly when I mounted them? :
That's a normal problem with weld on beadlocks but yours should be like mine and have a lip that centers the tire on the wheel until its locked down.
Also what you are describing with it coming and going and sometimes being able to have no vibes. Makes it more confusing and difficult to pin point the cause.
What psi are you at and is it the normal psi for the tire rating?
Meaning are your tires D rate or E rate.
When I ran radials and airsoft pellets I had DW issues unless the tires where at 45 psi+. They were D rate with a max cold psi of 50.
Hope that helps.
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline
post #2439 of 3547 Old 10-25-2013, 08:18 PM
aw12345
Which is why I told you to jack it up move a jackstand just about against the tire thread and spin the tire it will show tire run out and wobble. When I had dynabeads one thing that helped as odd as it sounds they worked best with a big wheel weight on the inside lip of the wheel. Don't know why but that helped dynamic balance, which when off is what causes the shimmy
aw12345 is offline
post #2440 of 3547 Old 10-26-2013, 07:14 AM Thread Starter
AngryTJ
For now Im just going to put the tires back where they were. Temps outside are dropping and I dont have time to be playing Sherlock Holmes.
It has to be the beads though if sometimes it shakes like crazy and other times its fine.
AngryTJ is offline
post #2441 of 3547 Old 10-27-2013, 07:12 PM Thread Starter
AngryTJ
anyone know where I can get a wiring pigtail for a 98 hardtop to plug into an 05 jeep for the wipers and defrost. Only one I've found is $100, wasnt sure if there were any less expensive.
AngryTJ is offline
post #2442 of 3547 Old 10-27-2013, 07:18 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
I have the body side plug, you could wiring it into your 05 harness.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2443 of 3547 Old 10-27-2013, 07:26 PM Thread Starter
AngryTJ
Shoot me a pic when you have a second. Is it from a 97-02?
AngryTJ is offline
post #2444 of 3547 Old 10-27-2013, 07:32 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Yeah, cut it out of mine when I cleaned up the harness.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2445 of 3547 Old 10-27-2013, 07:49 PM Thread Starter
AngryTJ
perfect...shoot me a PM with your paypal info and what you want for it
AngryTJ is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 07:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 06:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 03:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 01:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
