Tarantula_TJ Rubicon Build - Page 162 - JeepForum.com
 2Likes
post #2416 of 3547 Old 10-22-2013, 08:42 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by AngryTJ
I would be all over that if I had the caps.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2417 of 3547 Old 10-23-2013, 07:36 AM Thread Starter
AngryTJ
Originally Posted by janesy86 View Post
Where'd that come from!?
purchased it few months back. Fixed it up a bit and now its for sale
Originally Posted by turbowilber View Post
Epic, all you can say
Thanks man
trade?
AngryTJ is offline
post #2418 of 3547 Old 10-23-2013, 08:10 AM
GregStephens2
I am running air soft bb's and have no vibes at lower psi's. But I am not running radials either.
When I was running radials I had lots of issues with lower psi's.
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline
post #2419 of 3547 Old 10-23-2013, 01:23 PM Thread Starter
AngryTJ
Do you drive yours on the street anymore?
AngryTJ is offline
post #2420 of 3547 Old 10-23-2013, 01:31 PM
GregStephens2
Yup I can run it on th highway with no vibes.
Right now it seeing a fair amount of road time. Hopefully this will change soon.
post #2421 of 3547 Old 10-24-2013, 02:54 PM Thread Starter
AngryTJ
Wasnt really satisfied with the fitment of the hard upper doors or the fact my YJ top had no rear defroster or wiper so both are for sale if anyone is interested.
Buying a TJ hardtop tomorrow and maybe some full doors over the weekend
AngryTJ is offline
post #2422 of 3547 Old 10-25-2013, 09:38 AM Thread Starter
AngryTJ
Ok I need input on how to get my tires balanced properly. I took my jeep to work today and got a bad shake again around 40 which eventually went away as I got up in speed but Im convinced the dynabeads dont work.
What do the rest of you out there use? Metal BBs? How much did you use per tire?
AngryTJ is offline
post #2423 of 3547 Old 10-25-2013, 09:51 AM
GregStephens2
My bet from personal experience is you have a lateral imbalance which the beads are not going to fix.
Breaking the wheel and tire combo down and spinning the tire 180* may help if you can isolate which tire is causing the issue.
As for how much weight I would use the db's chart or the equal chart.
Again I am running airsoft pellets and have 8 oz's in each 36" tire.
Why didn't you just have these tires road force balanced?
post #2424 of 3547 Old 10-25-2013, 09:51 AM
Danno6102
Road force balancing.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #2425 of 3547 Old 10-25-2013, 10:23 AM Thread Starter
AngryTJ
When originally mounting the beadlocks on the tires they were so far imbalanced that I broke them back down and made sure to evenly torque the bolts in a criss-cross pattern so the exterior ring was as even as possible across the front lip of the tire. As I mentioned two I was able to get balanced with a small amount of sticky weights and the others are just so far off I went with the dynabeads.
Another thought of mine is that the rim is not centered in the tire properly when I mounted them? Its just weird how sometimes its a crazy shake and other times I can get up to 70 no problem. Also this shaking has only started now that I moved the dynabead tires in front and the sticky weight 2 in the rear.
I never road force balanced because there are very few places around here that do that and several wont even touch a 35" tire with beadlocks.
AngryTJ is offline
post #2426 of 3547 Old 10-25-2013, 10:36 AM
kyle_craig
Are they wearing evenly? If so, I'd just switch em back!
kyle_craig is offline
post #2427 of 3547 Old 10-25-2013, 11:39 AM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
On mine I do a static balance with tape weights. It takes A LOT of weight, 6 to 8 ounces but I've never had an issue doing it this way. I would first rule out that what you were feeling isn't just a temporary flat spot in the tire due to them sitting, and it being very cold in the morning.
gst95dsm is offline
post #2428 of 3547 Old 10-25-2013, 11:45 AM
gst95dsm
gst95dsm's Avatar
That makes sense really..... each and every time you come to a stop the bead will need to redistribute to the proper area, I could see you getting a temp vibe until that happens.... and you feel an imbalance in the front MUCH more than the rear. A lot of times at work to save time for the customer we only rebalance the ones going to the front during a rotation and very rarely get any negative feedback doing so.
gst95dsm is offline
post #2429 of 3547 Old 10-25-2013, 12:00 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
My local discount tire will do bead locks but only if I call ahead so I get a fresh daily calibration first thing in the morning. Might be worth a try to stop by there and ask. Then schedule a balance with them. Need to vacuum all the beads out first.
I feel your pain, been there with my krawlers.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2430 of 3547 Old 10-25-2013, 12:01 PM
aw12345
Somewhere back in time I had dynabeads in my front tires and it did much the same as you experience. It would shake so violently at times that the front would actually move up end down. First jack the front up slightly spin the tire with a jackstand near it to check it for runout and wobling on the rim. If all that is good get a proper tire balance
aw12345 is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 08:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 07:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 04:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 02:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 01:04 PM
