Tarantula_TJ Rubicon Build - Page 16 - JeepForum.com
 2Likes
post #226 of 3547 Old 12-13-2011, 09:09 AM
krashnpa
Originally Posted by KevKaos View Post
So do mine. I put like 4 washers behind the steering stops but still get a bit of rub. I might have to consider some spacers instead, but I worry about the cops giving me a hard time when my tires stick out to far from under the flares.
Lowering the offset puts one heck of strain on the unit bearings too...
krashnpa is offline
post #227 of 3547 Old 12-13-2011, 09:49 AM
KevKaos
So using the washers behind the steering stops is a bad idea? Guess I need some spacers as well huh?
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #228 of 3547 Old 12-13-2011, 10:04 AM
krashnpa
Negative, Ghostrider, washers are fine, just increases turning radius - can't use it when you're putting your tires into your LCAs anyway. When you put spacers on your axles it changes the location of the wheel essentially from a positive to a negative offset. So if stock backspacing is 4.75" (or whatever it is) and you add a 1.5 inch spacer, the backspacing is now 3.25", which changes the fulcrum point and increases leverage on the axle. Adding spacers in the back is not as bad as the front. The unit bearings are more susceptible to damage from aggressive backspacing.
For instance - If the wheel is 8 inches wide, and the backspacing is 4.75 then the offset is .75 postive - towards the outside of the wheel. If you add a 1.5 inch spacer, offset is negative 0.75, towards the hub. Zero offset on an 8 inch wheel is 4 inches of backspacing.
Some lifts require less backspacing so you don't rub tire. Trick is to only use what backspacing is necessary to keep arms from rubbing.
krashnpa is offline
post #229 of 3547 Old 12-13-2011, 10:34 AM
KevKaos
Apparently mine needs alot because the thread I got the washer idea from said that usually only 2 washers (maybe 3) were needed to stop most rubbing. I'm at 4 on both side and still rub at full lock. Not as bad as it was before the washers though. Wonder if Lu is in the same boat.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #230 of 3547 Old 12-13-2011, 10:39 AM Thread Starter
AngryTJ
I think my head just exploded trying to comprehend this.
I know running spacers puts a bit more stress on the axle but couldnt pass up the deal and running 33s hopefully wont cause many issues.
AngryTJ is offline
post #231 of 3547 Old 12-13-2011, 10:49 AM
KevKaos
Yeah, thats how I feel everytime I talk to Ed about Jeeps.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #232 of 3547 Old 12-13-2011, 11:03 AM
krashnpa
Sorry! My wheels have 3.3175" backspacing. I still rub the clayton arms, but barely. But then again one of the reasons I am going to the D44r is to get away from replacing unit bearings. Cheap ones dont last, btw...
Here's a website, not jeep related, but explains that stuff well. Tire rack probably has good stuff too.
http://vw.zenseeker.net/Wheels-BoltPattern.htm
krashnpa is offline
post #233 of 3547 Old 12-13-2011, 12:02 PM Thread Starter
AngryTJ
Ed I decided Im going to run just the rear longarm at first to save on cost so I can upgrade my steering as well as add some skids for protection. Not to mention Im not completely sold on the radius arms so Id rather spend the money elsewhere for now.
AngryTJ is offline
post #234 of 3547 Old 12-13-2011, 02:24 PM
rockcrawlernut
WOW The Jeep's looking great!
Once you understand the way broadly you see it in all things.
2004 WJ Special Edition 4.0L Project "
4" IRO Lift | IRO HD Track Bar | Doetsch Tech 8000 | JKS Quicker Disconnects | JKS Bar Pin Eliminators | Cooper Discoverer ST Maxx 265/75/16
rockcrawlernut is offline
post #235 of 3547 Old 12-13-2011, 07:23 PM Thread Starter
AngryTJ
Thanks
AngryTJ is offline
post #236 of 3547 Old 12-15-2011, 11:47 AM Thread Starter
AngryTJ
Found this picture on TNT's website which Im completely obsessed with
This is exactly how I want my Jeep to look
AngryTJ is offline
post #237 of 3547 Old 12-15-2011, 01:33 PM
TeddyTurmoil
Nice
Cheers Teddy
www.arctic-air.co.uk
TeddyTurmoil is offline
post #238 of 3547 Old 12-15-2011, 04:05 PM
KevKaos
Yeah, that's kinda what I have in mind as well, except I probably won't go larger than 33s, and those flares would nev be enough to be legal in MD.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #239 of 3547 Old 12-15-2011, 04:17 PM Thread Starter
AngryTJ
My 33s are basically brand new (3000 miles) so I wont be upgrading to 35s anytime in the near future but I will eventually. Id love to buy the TNT fenders but those will have to hold off until I upgrade my skid plates and beef up my steering. Talking to a forum member that is going to sell me his Currie steering with Savvy Tie rod for $300 + shipping
AngryTJ is offline
post #240 of 3547 Old 12-15-2011, 08:18 PM
MO2500
Damn you Wish I had found this first lol
Instagram: @omsmike
MO2500 is offline
tacguy22
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 07:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 06:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 03:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 01:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
