Tarantula_TJ Rubicon Build - Page 152 - JeepForum.com
 2Likes
post #2266 of 3547 Old 08-14-2013, 11:39 AM Thread Starter
AngryTJ
Originally Posted by Hendrix
Awesome video man! You guys made a trip of a lifetime out of that.
Thanks John
It was a memorable experience that's for sure.
I have enough video for probably two more videos when I get around to it.
AngryTJ is offline
post #2267 of 3547 Old 08-26-2013, 07:46 PM Thread Starter
AngryTJ
Incase anyone is interested
http://www.jeepforum.com/forum/f126/.../#post15839800
AngryTJ is offline
post #2268 of 3547 Old 08-27-2013, 07:17 PM Thread Starter
AngryTJ
spent a couple minutes under the jeep tonight after putting on my fancy neoprene winch cover, tightened my jam nuts and transmission bolts and Im considering going up an inch.
Possibly try the currie 3" progressive springs.
I know I have to cut my rear crossmember where the old tank ties into so my upper axle mounts dont hit but I also dont think Im utilizing full uptravel in the rear unless I go a tad higher. Not only that but in the front my tracbar is slightly rubbing the diff
Going to cut the crossmember and grind the diff down a hair and go from there.
AngryTJ is offline
post #2269 of 3547 Old 08-28-2013, 09:19 AM
bobthetj03
I didn't realize yours sat so low! Thoughts on the 3.5" cloak springs? Looks like they'd maximize droop, with the right shocks of course.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #2270 of 3547 Old 08-28-2013, 10:04 AM Thread Starter
AngryTJ
My concern now is when I cut the crossmember and get more uptravel will the upper arms run into the tub.
They currently dont but thats also because the axle cant travel any higher before hitting.
We'll see, Im prepping the jeep to go wheelin this sunday and then itll sit because my baby will be born in 3 weeks or less and Ill have more important stuff to do.
AngryTJ is offline
post #2271 of 3547 Old 08-28-2013, 10:24 AM
jermeyg
How much uptravel do you have in the rear and how much room do you have between your truss and the diff? I have my uppers touching the tub while under full hard bump-axle supporting the weight of the rear. Your situation might be different as you are stretched but I don't think touching the tub under full hard bump is a bad thing. Any issues with removing the crossmember?
jermeyg is offline
post #2272 of 3547 Old 08-28-2013, 11:06 AM Thread Starter
AngryTJ
I have not measured what I currently have but Id guess around 4 or 5" with one side stuffed while the other droops but at hard bump with both tires up at the same time probably only 2-3"
AngryTJ is offline
post #2273 of 3547 Old 08-29-2013, 09:09 AM
duc202
how much lift do you have now?
duc202 is offline
post #2274 of 3547 Old 08-29-2013, 09:16 AM
REDLYNER
REDLYNER's Avatar
I have this problem as well and what I have learned is that if you jump the rig enough it will just self correct .
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #2275 of 3547 Old 08-29-2013, 09:18 AM
brplatz
Haha this is damn good
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #2276 of 3547 Old 08-29-2013, 07:46 PM Thread Starter
AngryTJ
2-2.5"
haha
AngryTJ is offline
post #2277 of 3547 Old 08-29-2013, 07:52 PM
aw12345
You just have to be ready to start looking for your dentures when you land
aw12345 is offline
post #2278 of 3547 Old 08-30-2013, 07:14 AM
jermeyg
Lu could you measure the length of your rear springs (perch to perch)? With the 3" spring the ride height is about 11" and you can get 6" of uptravel. Hopefully that will be a reference point for you so you can decide if you want to try 3" springs.
jermeyg is offline
post #2279 of 3547 Old 08-30-2013, 09:17 AM Thread Starter
AngryTJ
Cool, thanks Jeremy
AngryTJ is offline
post #2280 of 3547 Old 09-01-2013, 09:09 PM
G Beasley
Cool, thanks Jeremy
Jeremy is chocked full of goodness
How much longer til Baby Lu is due ?
G Beasley is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 07:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 06:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 03:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 01:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
