Tarantula_TJ Rubicon Build - Page 14 - JeepForum.com
 2Likes
post #196 of 3547 Old 11-22-2011, 06:58 PM
whitejeep881
Trip looked like fun.
whitejeep881 is offline
post #197 of 3547 Old 11-22-2011, 07:47 PM
kashoggio
Nice pics maybe one day I will finally make it out there
2004 TJ RUBICON~ LIME GREEN
"Some desire is necessary to keep life in motion."
kashoggio is offline
post #198 of 3547 Old 11-22-2011, 07:59 PM
MO2500
Jeep looked great this weekend and performed very well
Had a good time wheeling with you. I'll try and get my pics and vids uploaded tomorrow. I've been real busy at school the past 2 days
Instagram: @omsmike
MO2500 is offline
post #199 of 3547 Old 11-25-2011, 01:33 PM Thread Starter
AngryTJ
Originally Posted by Allgood_73 View Post
Awesome build thread man and great clean looking jeep... I just read all through it.
One thing is for sure... you can paint a hell of a lot better than me... I get too impatient and end up with paint runs.
Too bad you didn't catch me sooner.... I could've sent you a LOT more stuff with those bumpers.... such as the riddler diffs, beadlocks, currie HD steering, etc.
Anyway, I'll follow your build.... later man.
Thanks man, and thanks again for the bumpers
Yeah man we had a great time you'll have to come out with us next spring
Next spring!
Yeah man I had a great time, will def do it again next spring
AngryTJ is offline
post #200 of 3547 Old 11-27-2011, 04:44 PM
krashnpa
I need some schooling and advice Ed. Ok so Im "considering" trussing my axles and beefing up my control arms so my questions are as follows:
1) Should I just truss both front and rear, run short arms on stock brackets and call it a day?
1a) Which truss should I use, TNT, clayton, ???
2) Should I 4link the rear?
2a) If I do 4link the rear whats your opinion on claytons rear long arm 4link
http://claytonoffroad.com/product_in...roducts_id/139
or should I just http://claytonoffroad.com/product_in...roducts_id/355
Need your opinion and knowledge to help decide
Hey Dude.
TNT truss - I like them. As far as I know, Clayton only has a bridge for the front, not really a truss. The stock rear housing is pretty stout, not unbendable, but it will hold up to some abuse. Think it will hold 35s without trussing. The front has thin .250 wall tubes. Not any better than a dana 30 with the exception of the larger ring gear. I would truss that first.
I liked your plan that you had posted up here on your build as far as mods... is that plan still on track?
As far as arms - if what you have is working now, why upgrade to shorties at this point if you are thinking about a 3 & 4 link? I don't think you've reached the limits of your current setup only two times out. Unless you are having vibe/drive issues, stash the money you would spend on shorties and buck up for the Clayton setup.
If you go with the Clayton 3 link, and a TNT truss, we'd have to weld a upper link mount to the tnt truss. You would not want to get the upper mounts unless you plan on getting the 3 link at a later date. Oh yeah, another option is Synergy Suspension from Poly Performance.
One thing to remember is set the limit for how far you are willing to take it. If the sky is the limit, then have at it, but don't do what I did and end up with three different suspensions. Decide how far you want to go, do it right, one time. I wish I had. Just remember, everytime you do one thing, it creates a need, want, or problem elsewhere!
krashnpa is offline
post #201 of 3547 Old 11-28-2011, 05:58 PM
midnight_f150
I think would stay away from the TNT truss. Check out Hendrix build he lot of trouble with his and didnt like it at all.
midnight_f150 is offline
post #202 of 3547 Old 11-28-2011, 07:13 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Check out Undercover Fabworks for some sweet new trusses also.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #203 of 3547 Old 11-28-2011, 07:45 PM
Whitford
Great build thread and a very nice, clean Jeep. Thanks, I enjoyed it!
Whitford is offline
post #204 of 3547 Old 11-29-2011, 03:14 AM
krashnpa
Well, duh, that's cuz you have to weld it on, not bolt it on!
UCF does have nice trusses and other nice stuff, remind me a lot of BTF, but I don't think they have anything for the front 44 yet.
Lu, what bracketry are you using if you do the LA?
krashnpa is offline
post #205 of 3547 Old 11-29-2011, 02:51 PM
MO2500
IIRC John's issue with the TNT truss had to do with cold, poor quality welds done by TNT. The truss separated at the upper link mounts. Nothing wrong with the design of the TNT truss but the welds sucked.
Instagram: @omsmike
MO2500 is offline
post #206 of 3547 Old 11-29-2011, 03:30 PM
krashnpa
Yeah, I appreciate a good weld, especially when it's holds my front suspension together. I did check the welds (habit) before I welded it to the tubes, I was more worried about what I was laying down. Then again, the uglier she is, the tighter she is. The hardest part to suck up was the shipping from MT.
I would have gone with TNT again, but the BTF/Clayton HC bracket combo gives more options for the ram and a better spot on the trackbar.
krashnpa is offline
post #207 of 3547 Old 12-01-2011, 11:18 AM Thread Starter
AngryTJ
Checking in quickly from Aruba here and Ive had some relaxing time to think about what I want to do with my build but it creates many questions. My thought process right now is the following:
-TNT truss with stock mounts for the front axle and run currie jj arms upfront.
-Then (still have plenty of research to do on the clayton 4link rear longarm upgrade) but do the clayton 4 link with their truss in the rear.
-Do a 1-1.25in body lift not sure which would be better w/ motor mount lift
-pull out and sell the 4in zone coils and replace with 3" currie coils (brings up the issue of driveshaft. Its a brand new driveshaft and I dont know enough about the rear clayton to know if I can still run the same lenth driveshaft im running now??? INPUT NEEDED)
-Lastly once the body lift has been completed run either a UCF or Rokmen high clearance tcase, engine, and gas tank skid.
Opinions and suggestions please!
AngryTJ is offline
post #208 of 3547 Old 12-01-2011, 01:08 PM
KevKaos
Put about $1300 cash aside in a bank account for if/when you toast your front locker. And, hope that you got a great buddy close by like Krash that can help and guide you through the install.
If your wheelin and not breakin stuff, you aint Honeybadger wheelin.
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #209 of 3547 Old 12-06-2011, 02:51 PM Thread Starter
AngryTJ
EDIT***
REDecided on the following once the new year comes around:
-Clayton longarm upgrade kit w/ 4link rear truss
-.5" Rokmen body lift
-1" brown dog mml
-UCF lowpro mount
-Clayton Tcase/engine heavy duty skid
-Rokmen Gas tank Skid
-Currie ultimate steering with Savvy tie rod
-Currie Antirock
Cant Wait
AngryTJ is offline
post #210 of 3547 Old 12-08-2011, 10:35 AM
KevKaos
I was just reading through your build thread again, and I was wondering if you are still having vibe problems, or did they go away? You said that you eliminated your TC drop right? Did you do that as you were installing the new driveshaft? In other words, did you measure for the driveshaft while the TC drop was still in place? I ask because in that one photo of the driveshaft, you appear to have about an inch or more of slip joint showing than I do on mine. Not that I would nessecarily worry about it, but how does that slip joint look at full droop? I thought I had some vibes, but they seem to have gone away when I put on the new tires. I would like to remove my TC drop as well, but wondering now if I am going to cause problems by doing so?
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 07:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 06:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 03:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 01:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
