Tarantula_TJ Rubicon Build - Page 112 - JeepForum.com
 2Likes
post #1666 of 3547 Old 04-14-2013, 08:13 AM Thread Starter
AngryTJ
Originally Posted by dayriesw View Post
Very sexy fenders and hood.
Originally Posted by platinum5.9 View Post
Angry I'm excited to see it all come together. I love the fenders, hood and rear armor and flares. I'll be keeping up with this for sure.
Thanks man Im pretty pumped to get it all together!
Originally Posted by Hendrix View Post
Those corners turned out so good. I will seal them and then put a thin coat of seam sealer on the outer seam to keep water out before I paint.
They look great!
Originally Posted by duc202 View Post
are those Mikey's old rims and tires? that set looks great on your jeep
No but they are the same style rims as Mike used to have
AngryTJ is offline
post #1667 of 3547 Old 04-14-2013, 10:51 AM
yellow_snocone
Looking good Lu I cant wait to see the complete finish product
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #1668 of 3547 Old 04-14-2013, 06:55 PM
aw12345
Post a few pics of your rear anti rock mount if you have time
aw12345 is offline
post #1669 of 3547 Old 04-14-2013, 06:57 PM Thread Starter
AngryTJ
I think I'll cut the entire bracket off chop it and mount it on the top side of the frame
AngryTJ is offline
post #1670 of 3547 Old 04-14-2013, 07:47 PM
aw12345
If all else fails knock the nylon inserts out of the mount, find some tubing that will fit it and then do what needs doing. i guess your setup started as a curry mount behind the wheel TJ kit
aw12345 is offline
post #1671 of 3547 Old 04-14-2013, 09:06 PM
MO2500
Lu, I don't have a good picture but if you cut the bracket about a 1/2" below the bushing sleeve straight across then it works pretty well, that's how I did mine. Just make sure you take the poly bushing out before welding.
Instagram: @omsmike
MO2500 is offline
post #1672 of 3547 Old 04-16-2013, 08:31 AM Thread Starter
AngryTJ
Spent a couple hours last nt cutting the upper arms down 2" and cutting the bungs out to reweld. (Disclaimer: My first welds on tube) Also patched and filled in the gaps from the coil bucket to the frame.
Tomorrow ill get it sitting on its own weight and measure for the out boarding of the shocks
image-1111715902.jpg   image-2927202456.jpg   image-3424774964.jpg   image-1762400408.jpg
AngryTJ is offline
post #1673 of 3547 Old 04-18-2013, 12:27 PM Thread Starter
AngryTJ
Been feelin like **** the past couple days but was able to take advantage of a UCF 15% off email coupon and buy some windshield guards. Also planning to get the jeep rolling again this weekend
AngryTJ is offline
post #1674 of 3547 Old 04-18-2013, 12:33 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Windshield guards???? Never seen em, gonna have to check that out. Hope you feel better soon man!
gst95dsm is offline
post #1675 of 3547 Old 04-18-2013, 12:37 PM Thread Starter
AngryTJ
Thanks man! Check em out
http://undercoverfab.com/misc-armor-...r-jeep-tj.html
AngryTJ is offline
post #1676 of 3547 Old 04-18-2013, 02:37 PM
gst95dsm
gst95dsm's Avatar
Ill wait for you on this one, apparently the Gen rights don't fit well, and the ucf look a little odd to me with that weld seam in the middle. Gonna let you figure it out first, haha!
gst95dsm is offline
post #1677 of 3547 Old 04-18-2013, 07:55 PM
Jeepin72
Did you sort out those shock mounts and the GenRight tank? I had problems with my Clayton stretch and the GenRight tank and so did a buddy of mine (user name hoovail). I had to drill some holes through my new frame slots for the tank. Hoovail welded more steel to his tank and extended the GenRight mounting tabs to get a new hole location.
Jeepin72 is offline
post #1678 of 3547 Old 04-18-2013, 08:05 PM Thread Starter
AngryTJ
I havent addressed it yet but Ill likely cut the frame for the shock towers in that location and just drill a hole through the towers to put a bolt and secure the front of the tank.
AngryTJ is offline
post #1679 of 3547 Old 04-20-2013, 02:14 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Teaser....
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1680 of 3547 Old 04-20-2013, 02:24 PM
gspup
Teaser....
Pimp !
gspup is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 07:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 06:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 03:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 01:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
