Tarantula_TJ Rubicon Build - Page 11 - JeepForum.com
 2Likes
post #151 of 3547 Old 11-12-2011, 04:03 PM
TeddyTurmoil
Retorq'd the entire suspension and found out my front passenger side shock is leaking so Ill def be calling Zone for a replacement. Also painted the Riddler Covers and fully mounted the driver side rocker panel. (before and after pics)
Ridlers are a nice color can't wait to see what they look like on
Cheers Teddy
www.arctic-air.co.uk
TeddyTurmoil is offline
post #152 of 3547 Old 11-12-2011, 07:22 PM
kashoggio
Nice look with the Armos.. Should of picked up a set when they were on sale so the wife would stop harassing me about how much of a pain it is to get in and out.
2004 TJ RUBICON~ LIME GREEN
"Some desire is necessary to keep life in motion."
kashoggio is offline
post #153 of 3547 Old 11-13-2011, 10:58 AM
REDNWHITE
Did the rubber gasket come with the slidders or did you have to order them separately?
REDNWHITE is offline
post #154 of 3547 Old 11-13-2011, 01:01 PM Thread Starter
AngryTJ
I took the gasket off the Rubicon diamond plate Rockers and kept those knowing I would need them. I believe Rokmen has them for sale though.
AngryTJ is offline
post #155 of 3547 Old 11-14-2011, 07:11 AM Thread Starter
AngryTJ
Got the front Diff cover installed and fluids changed. Ran out of daylight to do the rear I had a bunch of other crap to do. Might change out the rear tonight after work if its not cold as balls out.
AngryTJ is offline
post #156 of 3547 Old 11-14-2011, 07:14 AM Thread Starter
AngryTJ
In other news my serpentine belt squeaks like crazy in the mornings, I sprayed a whole mess of belt dressing and it didn't seem to help much. The belt itself looks fine and has proper tension so not sure if I should just change it out anyway.
AngryTJ is offline
post #157 of 3547 Old 11-14-2011, 07:21 AM
krashnpa
Purdy!
krashnpa is offline
post #158 of 3547 Old 11-14-2011, 12:17 PM
KevKaos
When you do the sliders on the other side, is there any chance to can slip them in place WITH the gaskets on and mark your holes? If so, that would prob save you a ton of work. Also, you may have to think about going backing and getting someone to weld those other holes up (the ones that didnt match up correctly). Just a thought.
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #159 of 3547 Old 11-14-2011, 12:59 PM Thread Starter
AngryTJ
Thank you, take a look at my most recent pics and let me know what you think.
Yeah I got a really good deal on mine off of poison spyders website. Check it out it would be under "currie closeout sale" on the lefthand column if they have any left.
I will definitely be gluein the gasket to the slider first hand this go around.
AngryTJ is offline
post #160 of 3547 Old 11-14-2011, 01:08 PM
krashnpa
When I did mine (on the TJ), I jack it up against the body, center punched it, then dropped it, drilled, did the inserts, cleaned the paint, test fitted, RTV'd the back of the slider, jacked it up in place, aligned, then screwed that thing to the tub. I forget how they mounted under the tub, think to the body mounts. Ran a bead of RTV along the top, smoothed with a spoon, and forgot they were there. I didn't have gaskets on the backside, but that would have been a good idea.
Anyway, along with what Kev said, RTV the holes with some black RTV and you'll be golden.
krashnpa is offline
post #161 of 3547 Old 11-14-2011, 04:26 PM Thread Starter
AngryTJ
one of many issues is that these sliders have tubes in which dont allow you to center punch the holes because they are in the way. Instead I marked em with whiteout dropped the rockers, drilled, did the inserts and when they didnt align perfectly had to drill the hole on the rocker larger to make it align.
its time consuming and a pain in the ***!
In other news I finially purchased some of my own tools. Sears is having a great online sale I took advantage of today and got a massive craftsman tool set
AngryTJ is offline
post #162 of 3547 Old 11-14-2011, 05:35 PM
TeddyTurmoil
Riddler cover looks great on the front now!! Just got my ARB diff covers in red, arrived to day but no time to fit them.
Did you add the special lubricant to the diff oil or is that just for LSDs and not Rubicon diffs ?
Cheers Teddy
post #163 of 3547 Old 11-14-2011, 05:50 PM Thread Starter
AngryTJ
I used Mobil 1 75w140 synthetic nothing else
AngryTJ is offline
post #164 of 3547 Old 11-15-2011, 03:05 AM
misfitJason
well done
misfitJason is offline
post #165 of 3547 Old 11-16-2011, 09:02 AM Thread Starter
AngryTJ
Originally Posted by misfitJason View Post
well done
Thanks, its coming along slowly
AngryTJ is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 08:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 07:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 04:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 02:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 01:04 PM
