Tarantula_TJ Rubicon Build - Page 107 - JeepForum.com
 2Likes
post #1591 of 3547 Old 03-24-2013, 11:52 AM
yellow_snocone
Yeah went with the genright stretch steel corners. I didn't want to mess with cutting my own wheel wells on some blanks
Good stuff
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #1592 of 3547 Old 03-29-2013, 11:47 AM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
What's the hold up around here????
gst95dsm is offline
post #1593 of 3547 Old 03-29-2013, 01:09 PM
yellow_snocone
Lets see your jeep stretch like Stretch armstrong
Military Jeepers
post #1594 of 3547 Old 03-29-2013, 01:23 PM Thread Starter
AngryTJ
The thing people call a job is taking all my time
haha In all seriousness Im making progress I just didnt plan to update the build until there is a good amount of work to report.
AngryTJ is offline
post #1595 of 3547 Old 03-30-2013, 11:34 AM
djflyy
to be sent for paint
You're not going to rattle can them? Just so touch-up is easier?
I'm even debating stripping my T&Ts up front and doing a rattle can black just 'cause touching up a metallic paint code is a PITA.
djflyy is offline
post #1596 of 3547 Old 03-30-2013, 11:57 AM Thread Starter
AngryTJ
Scratching my head a little right now. Let me know if anyone has suggestions. So I'm cutting into the frame to move the upper buckets but the rear crossmember is welded directly behind this piece of the frame I need to cut out. How should I address this so the springs can fit in here?
AngryTJ is offline
post #1597 of 3547 Old 03-30-2013, 12:28 PM
gst95dsm
gst95dsm's Avatar
I'd probably cut it, and work it into my new coil upper coil bucket since it looks like it's going to occupy the same location. All it's doing now really is holding up the front of the gas tank isn't it? As long as you don't cut the rear most cross member before you get that one secure again the frame will stay "relatively" square. That would be my ghetto fab thinking.
gst95dsm is offline
post #1598 of 3547 Old 03-30-2013, 12:46 PM
IEcrawlerTJ01
It no longer hold the tank. Trench tank has new side mounts. All it does is body mounts
Angrytj
I would use the cut you started and just get rid of the entire crossmember an build a new one.
Remember it only holds the two body mounts now. And those are not hard to find a soloution for.
If you notch any lower like the barnes kit your gonna have to run a much smaller spring to achieve the same ride height
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #1599 of 3547 Old 03-30-2013, 01:00 PM
gst95dsm
gst95dsm's Avatar
Angrytj
Forgot about the body mounts! In that case since it's not hold the tank at all, and obviously no longer responsible for the shocks.... I'd make a new one just for the body mounts.
gst95dsm is offline
post #1600 of 3547 Old 03-30-2013, 01:08 PM
IEcrawlerTJ01
This is what I said.
Jut make a new one to support body mounts. Nothing else
Nuff said...
post #1601 of 3547 Old 03-30-2013, 01:14 PM
gst95dsm
gst95dsm's Avatar
Yep I was just agreeing.
gst95dsm is offline
post #1602 of 3547 Old 03-30-2013, 03:04 PM Thread Starter
AngryTJ
Thanks for the advice guys. I'm thinkin Ill just notch the crossmember and use a smaller bucket. Potentially the ballistic fab ones and tuck the larger side on the inside of the frame?
AngryTJ is offline
post #1603 of 3547 Old 03-30-2013, 07:18 PM
TJRHD
Ballistic fab stuff will never work on this forum...
NOT A HATER
TJRHD is offline
post #1604 of 3547 Old 03-30-2013, 07:21 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
X2. Stuff looks good on the cad machine, but is poop in the end.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1605 of 3547 Old 03-30-2013, 07:26 PM
gst95dsm
gst95dsm's Avatar
I'm sure you have it figured out but that coil bucket with the side piece looks perfect for a place to weld the "new" crossmember to if you so chose to make one, actually you could probably just section out a bit of the old one and reuse it. Now THAT's what I'd do. That would make the welding easier.... not so deep in there with the bucket on the backside. Of course I'm not sitting there looking at it so.... I'm just thinking out loud looking at your pics.
gst95dsm is offline
TR Rubicon build tjindiana Jeep Builds 68 01-07-2015 07:06 AM
.06 Rubicon Build. MRYJ101 Jeep Builds 104 01-08-2013 06:10 PM
06 Rubicon Build muddy8jeep8 Jeep Builds 26 10-30-2012 03:43 PM
04 Rubicon Build skinpin Jeep Builds 23 07-18-2012 01:59 PM
My LJ Rubicon Build Kedive Jeep Builds 1 06-03-2010 12:04 PM
