Taming the BEAST! 5.3L V8 Powered TJ-6 - Page 10 - JeepForum.com
post #136 of 563 Old 05-19-2013, 12:54 AM
cycleguy04
You've fabbed a lot of stuff on this project. Why not just bolt a piece of 1/4" plate steel for the skid with and independent crossmember?
'98 Wrangler Sahara - SOLD
'91 Ranger XLT 2WD - 4.0 V6, A4"hell"D, contemplating twin turbo 5.3
'79 C10 Big Ten 2WD - 350, TH350, contemplating rebuilding to 355ci with supercharger and programmable EFI
'12 Subaru Forester (AKA: Arctic Cat) - 2.5, non-CVT, wife's, still begging her to let me get an exhaust system
'01 SV650 - snorkelectomy, ebay slip-on, cam swap and re-jet in the near future
cycleguy04 is offline
post #137 of 563 Old 05-19-2013, 10:59 AM Thread Starter
clintrivera
If I was doing a flat skid plate I would have made it. I needed around 2" of drop, and for $120, the barnes 4x4 skid plate is a non decision. It would have cost me more in time and materials to make something like this that I can just bolt in place.
clintrivera is offline
post #138 of 563 Old 05-20-2013, 09:39 PM Thread Starter
clintrivera
The original plan was to put the axle in about the stock location, maybe .5" forward. That way I could reuse my track bar and avoid removing the factory track bar bracket.
This is what it looked like. Not happy with the amount of uptravel I was getting or how close everything was to... Everything. So what if I move if forward 2 inches? Much better....
I gained at least 1.5" of up travel. I've read that removing the factory track bar bracket is a pain. That is absolutely correct. I can't believe how solid that sucker is attached to the frame. I killed two good cut off wheels, a 40 grit flap disk, and a set of consumables for my plasma. I was originally going to quit my job and start a business removing factory track bar brackets, but after this ordeal I think I'll stay where I'm at.
Of course in Jeep world, one change means you have to change 20 other things... So a call to Currie, Ballistic Fab, Poly Performance, and Amazon was made. I'll be making a track bar out of 1.5" .25" wall DOM with narrow body Johnny Joints at both ends. It will be double adjustable, so that should make adjustments very easy, and with the Ballistic hex inserts, keeping everything tight will be a snap. I also got Poly Performance's HD all metal TRE's and double adjuster inserts. 1.5" reamer from Amazon.
It's a Jeep thing, and I'm not sure I understand. $$$$$$$$$$$$$$
post #139 of 563 Old 05-20-2013, 09:53 PM
G Beasley
To every action there is always opposed an equal reaction ,or at least thats how I recall the quote . But I dont think Newton foresaw that Jeeps would shoot a hole in that theory
G Beasley is offline
post #140 of 563 Old 05-20-2013, 10:04 PM
Sundowner
Jeeps use higher mathematics than were originally anticipated; it's best to abandon any hope of understanding them and simply buy what they require.
Sundowner is offline
post #141 of 563 Old 05-20-2013, 11:12 PM Thread Starter
clintrivera
Jeeps are supernatural. That's the only explanation.
I found that you can either buy what they require and do it right, or possibly die in a fireball of Jeep and nuns + school children.
post #142 of 563 Old 05-21-2013, 08:16 AM
G Beasley
While this theory is sound , the wife unit doesnt work into that equation very well .
Nuns and schoolchildren is rough ... I thought it was kittens and puppies ?
post #143 of 563 Old 05-21-2013, 04:41 PM Thread Starter
clintrivera
That's one reason I stayed with the girlfriend unit and separate bank accounts.
I live in a real bad neighborhood.
On another note, anyone in the need for a Currie adjustable track bar? CE-9120TJS. Hardly used and won't work with my setup.
post #144 of 563 Old 05-22-2013, 10:31 PM Thread Starter
clintrivera
Most of my parts came in today except my Currie JJ's and headers. Headers will be here tomorrow. Went to track the JJ's and...
Mojave, CA, United States 05/21/2013 6:00 P.M. Train derailment.
Ontario, CA, United States 05/20/2013 10:47 P.M. Departure Scan
05/20/2013 9:10 P.M. Origin Scan
United States 05/20/2013 7:10 P.M. Order Processed: Ready for UPS
Oh oh.. That can't be good. Hard to make that up, huh?
post #145 of 563 Old 05-22-2013, 10:42 PM
G Beasley
Thats not a message you see every day ! Hopefully your parts don't get delayed for too long .
post #146 of 563 Old 05-22-2013, 10:47 PM
Sundowner
Spouses of any denomination seem to often have a propensity to use fuzzy logic and imaginary numbers, I've found.
Train derailment.
That's awesome. It sucks for parts delivery, but it's pretty awesome nonetheless
post #147 of 563 Old 05-22-2013, 10:48 PM
ThatWhiteJeep
Have you checked out under cover fabs Lopro mount? It drops the transmission allowing for a tummy tuck without the need of body lift.
Like my GrandPappy said, only way to learn is to do it yourself. Even if you break some things along the way.
ThatWhiteJeep is offline
post #148 of 563 Old 05-22-2013, 10:55 PM Thread Starter
clintrivera
I've actually seen that message once before. I thought trains were supposed to be safe?
I found a little news clip on it. Looks like a pretty big mess in a remote area. I'm not sure how long this is going to take?
The transmission mount for the 4l60e is pretty flush with the bottom of the pan. With some work, I may have gotten away with a 1" drop. Barnes only had 3", 2", and flat, so I went with the 2". It hangs around as low as the rubicon express skid I had before, so I think I'll be ok.
post #149 of 563 Old 05-23-2013, 10:52 PM Thread Starter
clintrivera
Good news and bad news. My headers came, but they are very unfriendly with my motor mounts. I cut a bunch away to try to make it work, but it's not going to work without reworking both mounts completely. So, I'm going to do what I should have done originality and get the Novak (Sanderson) headers.
The Jeep knows when you are trying to save money, and will do anything in it's power to stop that from happening.
On a happy note, they scooped up my junk out of the overturned train and what is left will be here tomorrow.
post #150 of 563 Old 05-24-2013, 01:49 PM Thread Starter
clintrivera
Made a call to Novak first thing this morning. They had a set of the Sanderson headers in stock. They are in Utah, so a quick two days via UPS unless a meteor hits a train, or a truck bursts into flames somewhere. With the holiday I should see it on Wednesday.
Getting closer!
