Tally ZJ's 1996 ZJ Laredo build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Tally ZJ's 1996 ZJ Laredo build
Get 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-07-2012, 09:47 PM   #16
TallyZJ
Now I needed some flanges that will accept the outer modular bumper ends that will bolt to the center section. I made these from 1/4" by 1 1/4" wide flat steel, cut and mitered for the angles.
Tig welded into place I will later round the corners and drill the holes for the bolts.
bumper_flange_pieces01.jpg   bumper_flange03.jpg   bumper_flange04.jpg   bumper_flange05.jpg   bemper_center_section02.jpg
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
Capital City Jeepers
Build Thread Here
TallyZJ is offline   Reply With Quote Quick reply to this message
Unread 04-08-2012, 07:10 PM   #17
TallyZJ
Here is the bumper mount tied into the frame rails.
Build Thread Here
Unread 04-08-2012, 07:12 PM   #18
TallyZJ
Now I temporarily tacked the front center section to the mount just to lay out the tow points and hitch receiver.
Build Thread Here
Unread 04-08-2012, 08:06 PM   #19
castorriver
Wow that's a lot of work you put into it. Nice job.
Post a better pic of that front bumper.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline   Reply With Quote Quick reply to this message
Unread 04-08-2012, 08:11 PM   #20
TallyZJ
Will get a better pic tomorrow. Light was getting low this evening and the paint was still shiny.
Still got more to build on this yet. The tow points and receiver have to be mounted and the modular ends have to be built. That is next weekends project.
Build Thread Here
Unread 04-09-2012, 09:21 PM   #21
TallyZJ
Here are a couple more of the center section. Not sure what I am going to do to tie it in better. I actually cut the tacks and removed it today to get a better idea on what to do.
Build Thread Here
Unread 04-14-2012, 05:04 PM   #22
TallyZJ
This thing has turned into a time management nightmare. I have decided to not use bolts to attach the bumper ends to the center section and just weld them on. I am tired and this is a lot of work and I need this thing done.
I have installed the receiver to the center section. This is not a recovery point. This will be for mounting a winch or a tow rope loop for light towing duty.
Build Thread Here
Unread 04-14-2012, 05:07 PM   #23
TallyZJ
I also began working on the first bumper end piece.
I cut the top section from 1/8" steel plate. This piece defines the shape of the bumper end and wraps the corner under the corner marker light.
Build Thread Here
Unread 04-14-2012, 05:09 PM   #24
TallyZJ
For added strength I cut and welded 1/8" thick angle around the edge of the plate. This gives me a place, a shoulder, to weld the stainless too.
Build Thread Here
Unread 04-14-2012, 05:12 PM   #25
TallyZJ
The end piece still has some work left to be finished. Mosquitoes got too bad to endure and I had to quit for the day.
Build Thread Here
