TAALA 2 Build Thread - JeepForum.com
post #1 of 590 Old 02-04-2011, 04:54 PM Thread Starter
bradentaala
Table of Contents
2000 TJ, LS1, 4L60e, Custom Cage, 104" wheelbase, 14" coilovers, 42" Kevlars, walker evans bead locks, Atlas 4, HP KP Dana 60, Shaved 14 bolt, Detroits, 5.13's, Hydro Assist Steering, Hydro Boost Brakes.
General Specs
Frame height 22.5"
4.5" up travel in the front
5" up travel in the rear
Front axle width: 69.25" WMS
Rear axle width: 67" WMS + 1.5"/side adapter = 70"
Wheels 8.5" wide on 4.5" BS with a 14.5" wide tire
Wheelbase: 104" (tires hang in front of the front bumper and behind the back bumper)
Phase 1
4 inch teraflex lift
35X12.50R17 KM2's
Super 44
Super 30
ARB's
3.88's
Rocker Guards
Front Stinger
37X12.50R17 KM2's
Phase 2
TNT Rear Hylines (page 5 - page 11)
Custom Hood Work
GenRight tire carrier/rear stinger
GenRight Comp Tank
Phase 3
This phase will include 1 ton axles, ~6" rear stretch, ~4" front stretch, coilovers, 40's, on an on.....
GenRight 3 link
GenRight double Triangulated 4 link
GenRight coilover mounts
GenRight Belly up
Fox 14" coilovers
39.5X13.50R17 Irok's
HP Kingpin 60
Dana 70
14 Bolt
Hydro Brakes
Walker Evans 17" beadlocks
3" Teraflex Speedbumps
Behind Axle Tie Rod
Atlas 4
Ready for shakedown run
6" front stretch (stock steering box location)
Phase 4
Suspension Seats
Bumper
Sound System
42's (street tires)
Phase 5
Full custom cage (8 point)
LS1, 4l603
Before:
Current:
Costs associated with a build like this...
Before you decide to go all in and start tearing your jeep down, I suggest putting together a spreadsheet of all the items you're going to need, then adding ~20% for miscellaneous items. Here are just a few costs of the bigger items on my build:
Atlas 4 speed: $3600
Front axle (locker, gears, etc...): $2000
Rear axle (lockers, gears, shave kit, etc...): $1750
42" kevlars: $3500
Hydro Steering: $1400
Hydro Brakes: $1000
custom drive shafts: $1000
seats: $1400 for 2 (harnesses, metal for mounts, etc)
Sound system: $2500
Armor (high lines, rockers, belly up): $3300
Genright 3 link: $1100
Genright 4 link: $1400
Genright tank: $800
Coilovers: $2000
Bumpstops: $700
Beadlocks: $2000
Winch and line: $1500
bradentaala is offline
post #2 of 590 Old 02-04-2011, 04:59 PM Thread Starter
bradentaala
New Tires
I purchased this TJ in January of 2010. Like some first time jeep owners, I didn't think i was going to end up so addicted to modifying.
Before:
Poor thing needed a LOT of TLC!
The inside was horrible. There was hay everywhere. I had to take the carpet out and pressure wash them!
Right off the bat I knew I had some work cut out for me. The tires were shot, the back bumper was welded to the frame, suspension rusted like crazy, shocks shot.... Hmmm. Where to begin!?!!!
post #3 of 590 Old 02-04-2011, 08:11 PM
Hurley91
Looks like a 4" lift to me... maybe it settled a little bit.
Hurley91 is offline
post #4 of 590 Old 02-06-2011, 01:19 AM Thread Starter
bradentaala
After i got the new 35's on.. it was rubbing galore!
after a trip to TeraFlex i got a new 4" lift. The lift it came with sagged big time.. it was sitting about a 2-3" not a 4". But with a 10 year old Teraflex lift...didn't surprise me.
The 'new' tera lift is temporary. (meaning 1.5 - 2 years).
RUST RUST RUST!
D35...bye bye...
hello d44
Look what came in the mail today
Super 44, super 35, ARBs, 4.88s, slip yoke eliminator, Tom Woods Shaft, ARB compressor and Currie AntiRock.
After about 30 minutes of thinking about where to mount the ARB compressor...i found the perfect spot!
Found a good spot for the ARB switches too:
all of this install was going on right before EJS 2010. I ended up driving through the night and pulling into moab at 5:00AM! i was just glad to get the lockers and everything in .
post #5 of 590 Old 02-06-2011, 01:20 AM Thread Starter
bradentaala
Rocker Guards:
Front Stinger:
First time in Moab. hours after everything installed:
post #6 of 590 Old 02-06-2011, 01:24 AM Thread Starter
bradentaala
After jeep safari i decided to buy something to fill in that monster opening on the front stinger/bumper!
Turns out you have to have a 3rd brake light... yep. gotta fix it ticket.
1. No 3rd brake light
2. No front license plate
3. Insufficient tire coverage (tires stick out too wide)
4. No mud flaps
post #7 of 590 Old 02-06-2011, 01:32 AM Thread Starter
bradentaala
Well, after I moved to the 35's... exactly 1 year to the month of having the jeep, i decided to get it a good birthday present. 37" KM2s
The 5th one is one it's way...but i'll be in china when it gets here...
The old 35" KM2s
The difference:
Before:
After:
I added 1" coil spacers to help out on clearance!
It was a good Thursday Night
post #8 of 590 Old 02-06-2011, 01:35 AM Thread Starter
bradentaala
Now with the new tires, i need an alignment... i also wanted to throw on a Currie HD steering and also a new stabilizer..
New Currie HD steering:
Old steering off:
Old vs. New:
From the picture it doesn't look like much, but the new is a lot bigger!!!
Here it is after the alignment:
post #9 of 590 Old 02-06-2011, 01:39 AM Thread Starter
bradentaala
I've had the jeep for a year now. What have i done?
1. 4" Teraflex lift
2. 1" Coil Spacers
3. 35 then 37" KM2 tires
4. Tire Carrier
5. Poison Spyder Front Stinger
6. Poison Spyder Rocker Guards
7. SYE
8. Tom Woods DS
9. High Output ARB compressor
10. D44 housing
11. Superior Super 44 shafts (35 spline)
12. Superior Super 30 shafts (30 spline)
13. front and rear 4.88s
14. Kenwood CD player
15. Currie AntiRock (front)
16. Currie HD steering
17. new steering stabilizer
18. Warn 9.5ti
19. Synthetic winch line
20. Poison Spyder aluminum fairlead
21. D30 axle tube cap things..
22. CB
23. CB antenna mount
24. Mirror relocators
25. Steering Skid
26. new wheel bearings, ball joints etc..
27. Used stock soft top
28. Rock Lights w/ arb style switch inside
29. Rokmen Control Arms
30. Front and Rear ARB lockers
Before:
and Now:
with 35's:
with 37's:
Monday I'm ordering TNT Customs HyLine tube flairs, front and rear then the GenRight rear stinger/tire carrier shortly after oh and depending on my tax return... a 4:1!!!!!!
Last edited by bradentaala; 02-06-2011 at 03:21 PM. Reason: Keep Remembering more things i've done! ugh.
post #10 of 590 Old 02-06-2011, 01:47 AM
MCObray
Sweet ride . Some beadlocks would sure set it off though.
1994 Dodge Ram 2500. 12V Cummins Turbo Diesel.
MCObray is offline
post #11 of 590 Old 02-06-2011, 02:59 PM
801DubJay
Sweet TJ, man... I've enjoyed seeing how far your rig has come and look forward to seeing where it goes!
'00 WJ Laredo V8 aka Katie
My Build Thread: http://www.jeepforum.com/forum/f197/801dubjay-build-thread-1114628/
801DubJay is offline
post #12 of 590 Old 02-06-2011, 03:29 PM
311LJ
311Popo
311LJ's Avatar
Ha last night ur poor rear flair was hating life.. Love the jeep! Welcome to the 37's club lol
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #13 of 590 Old 02-06-2011, 03:36 PM Thread Starter
bradentaala
I've thought of doing bead locks sooner rather than later, but i've decided to get all the armor done and stretch it first. I also plan on changing axles some time and might end up on a differ bolt pattern, so i'll wait for now. I run 10 PSI and haven't ever had any issues yet. I also have friends that run 6-7 PSI w/o bead locks and they haven't blown a bead yet... So maybe in a year or two i'll have bead locks..
'00 TJ, 14" coilovers, teraflex speedbumps, double triangulated 4 link, 3 link, D60, 14 bolt, 42" Kevlars, 17" walker evans beadlocks, high lines, 104" wb, atlas 4 (11.7:1), hydro assist steering, hydro boost brakes, belly up, Corbeau CR1 w/5pt harness.
post #14 of 590 Old 02-06-2011, 03:37 PM Thread Starter
bradentaala
Thanks man! I think it will change a lot even from now to EJS 2011
post #15 of 590 Old 02-06-2011, 03:46 PM Thread Starter
bradentaala
Ha, welcome to the WRANGLER club.
CJ5 build thread hybridmoments Jeep Builds 195 10-24-2012 11:31 PM
My not really a build thread build thread.. CapeCodGuy Jeep Builds 3 08-04-2010 04:15 PM
my build thread Glenn5 Jeep Builds 3 05-18-2010 08:10 PM
My Build Thread - '05 TJ 05rockymtn Jeep Builds 12 10-29-2009 01:26 PM
