SuperWade2's TJ Build Thread - Page 9 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > SuperWade2's TJ Build Thread
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 03-26-2010, 06:31 PM   #121
nriver
2011 JK Wrangler
On your shock question. It depends on the type of shock.
Mono Tube or emulsion, typically can down. The oil and nitrogen are not separated. If upside down the valve is typically not in the oil and does not work correctly.
Twin Tube, Remote Res, either way. The oil and nitrogen are separated by a bladder, so the valve is always in the oil.
I hate those upper shock mounts.
Why do I post here?
nriver is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 08:00 PM   #122
SuperWade2
More Money than Brains
SuperWade2's Avatar
Not at all pretty so far...I gave up for the night and started drinking instead. I look at it again tomorrow with fresh (albeit hungover) eyes...
SuperWade2 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 09:44 PM   #123
Apex
Recon death squad
Apex's Avatar
Grinder and a cut off wheel...there should be a single (sometimes there is two) spot weld holding the nut.
Grind as much of the weld off, and then grab a chisel and hammer to finish the work.
I broke all 4 when I did my shocks.
Apex is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 09:47 PM   #124
SuperWade2
SuperWade2's Avatar
How did you get a grinder up there? I had the body disconnected and lifted as far as I could get it, and barely had room for my Dremel... I was pounding the **** out of the thing with a sharp chisel, Air Hammer, 4 lb sledge taking FULL swings and it's not budging, even a little bit
Unread 03-26-2010, 10:00 PM   #125
Apex
Recon death squad
Apex's Avatar
I undid all the body mounts all the way to in front of the doors...I then jacked it up (granted it may not have been the safest thing I have ever done) with some 2x4s stacked on top of each other and screwed together.
I'm still alive with all limbs intact...so I guess it wasn't that bad
Unread 03-26-2010, 10:38 PM   #126
Barrows
Wade,
I had the same problem on my jeep. What I did is get a cutoff wheel that fits in a drill. Like this one...Shop GatorGrit 1-1/2" Mounted Grinding Wheel at Lowes.com this with let you get up in the hole. I assembled it in the hole which let me cut out my old broken bolts. Good luck!
Barrows is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 10:46 PM   #127
SuperWade2
SuperWade2's Avatar
Originally Posted by Barrows View Post
Wade,
Maybe I'll hit up my local HW store tomorrow and see what I can find. I did undo all the body mounts in back (Not all the way up front), but couldn't get anywhere near enough lift to get a grinder in there.
Unread 03-26-2010, 11:17 PM   #128
SuperWade2
SuperWade2's Avatar
At least I have something to be thankful for... the Passenger side went right in...a little anti-seize on the bolts before re-install and they went up and it just installed right up there...
Not a ton of space between the fat 2.75" Shock body on the Rancho and the lower spring perch on my axle (considering I had the can up/rod down on my old shocks) but I guess we'll see how it goes once I get everything bolted back up...
Unread 03-26-2010, 11:20 PM   #129
RubiconRazorbac
RubiconRazorbac's Avatar
So do I just mount the thing "upside" down (Can side down)? Or do I have to swap the bushings, or did I buy the wrong shocks?
***EDIT*** I double checked the part number and all the Installed Pics I see on Google (albeit not on TJ's) show Can side down, so I assume that's the way Rancho Intended
Yep, the new Ranchos are supposed to be mounted can-down. There were a couple of threads a few months ago where it came up, but it's been awhile. Anyway, mine go on tomorrow!
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
RubiconRazorbac is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 11:20 PM   #130
The27Jeenyus
i used an air hammer with a point tip on mine and just jacked the body up with my Hi lift
oh and this is one of my favorite builds
Zach
Facebook
Originally Posted by Willy36 View Post
icequeen's got something sticky in her hair from some dude named zach
The27Jeenyus is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 11:21 PM   #131
SuperWade2
SuperWade2's Avatar
See Post above yours!
Unread 03-26-2010, 11:38 PM   #132
RubiconRazorbac
Yeah I just saw it. That's what I get for trying to post with this stupid phone. By the time I finish a sentence, 5 minutes have already passed.:
Unread 03-27-2010, 12:30 PM   #133
SuperWade2
SuperWade2's Avatar
Unread 03-27-2010, 12:55 PM   #134
INCA
yessss! when are they getting mounted onto the jeep?
INCA is offline   Reply With Quote Quick reply to this message
Unread 03-27-2010, 01:14 PM   #135
The27Jeenyus
awesome! i cant wait to see what they look like
Zach
Facebook
