SuperWade2's TJ Build Thread - Page 52 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > SuperWade2's TJ Build Thread
ZONE 4.25" combo lift for TJ available at Rockridge4wNew Hours at RUFFSTUFF!Enjoy 5% off in April 2000-2006 Jeep Wrangler Ignition Coi
Unread 04-25-2012, 09:35 PM   #766
SuperWade2
More Money than Brains
SuperWade2's Avatar
Originally Posted by Hendrix View Post
Great vids man.
Thanks, it was fun... next time I'll plan the dash cam better (or get a GoPro HD thing)
SuperWade2 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2012, 11:12 PM   #767
aw12345
aw12345's Avatar
Originally Posted by SuperWade2 View Post
No clue, this was my first time on Jack... we started just to the left of this sign, up and around to the right.
I'm pretty sure we came down Jack North... I think we were going to do Wrecking Ball, but I was just following the group...I had no clue what was what.
This is the gatekeeper thing
http://vimeo.com/15792705
This is the the fun part of wrecking ball
aw12345 is online now   Reply With Quote Quick reply to this message
Unread 04-26-2012, 10:05 AM   #768
SuperWade2
SuperWade2's Avatar
I think I "bypassed" it to the right after the first 2 rigs in front of me failed to get up
Does this look like this spot?
Unread 04-26-2012, 07:32 PM   #769
StvDiego
Originally Posted by TJRoberto View Post
Any closer pictures/video or specs of it?
He has 40" rock movers
Love his spotting technique,, such as it is. Did he back you into a rock yet; back, back, back, BAM, OK, that's far enough
Need to try to get another trip in before summer, only a couple of hours from here...
StvDiego is offline   Reply With Quote Quick reply to this message
Unread 04-26-2012, 10:17 PM   #770
mrblaine
Wizard of Brakes
mrblaine's Avatar
That's the beginning of Jack and that guy ain't on the line.
I am Savvy
blackmagicbrakes.com
mrblaine is online now   Reply With Quote Quick reply to this message
Unread 04-26-2012, 10:18 PM   #771
SuperWade2
SuperWade2's Avatar
Right... he didn't make it either...
Unread 04-26-2012, 10:25 PM   #772
SuperWade2
SuperWade2's Avatar
Can't imagine anyone else I'd rather have spotting me...even with the ration of **** he gives me!
Unread 05-09-2012, 09:16 PM   #773
SuperWade2
SuperWade2's Avatar
This is probably a pretty simple question but wanted to check before I did something I regretted.
I've never completely removed any of my RE Long Arms since they were installed coming up on 5 years ago this summer (although probably only 10-12K miles since installing). The fronts have been unbolted from the Axle a couple times for axle swapping/fixing, etc but I've never removed from the frame side, and never touched the rears.
Anyhow, I'd like to yank them off, check all the bushings, check / clean / service / throw fresh grease in the flex joints, maybe throw a coat of paint on them to keep from rusting where I've scrapped them pretty good on rocks... Also the Tri-Link connection in back is pretty gunky and want to make sure it's all good.
Anyhow the simple question is, can I just remove the arms one at a time, with the Jeep on level ground in garage, tires all touching the ground. Do the check/clean/service, re-install and move onto the next one?
I assume they should all be re-installed with specific torque values, but I'll have to dig up and see if I still have the install directions (I didn't install the lift originally, I had it done at a shop).
Thanks in Advance!
Wade
Unread 05-10-2012, 07:53 PM   #774
SuperWade2
SuperWade2's Avatar
Thanks in Advance!
Wade
I guess I'll just do it and see how it turns out...if they find me dead under the rig I'll know it wasn't a good idea.
Unread 05-10-2012, 08:00 PM   #775
StvDiego
Dibs on the Savvy stuff
Unread 05-10-2012, 08:23 PM   #776
matthewh_1
I've had all 4 of my rear ones off at the same time with the parking brake on, no worries! I've even driven around missing one before.. You shouldn't have any issues removing one at a time.
National Topless Day 2010 winner!
Zombie Outbreak Response Unit #70
Originally Posted by jclauson View Post
When a girl tells you your flex is sexy then you are doing something right in life.
matthewh_1 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2012, 11:51 AM   #777
SuperWade2
SuperWade2's Avatar
First Arm Off... Driver Lower... Nice and Gunky!
Just a few small scratches on bottom...
And the Rubber Bushing isn't horrible...small cracks, just a bit oblong, but not sure if repalcement warranted yet! Thoughts?
Unread 05-11-2012, 12:41 PM   #778
MountainMan864
Take it all off and go sell Plasma and Sperm. Instant free new suspension system.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2012, 12:47 PM   #779
SuperWade2
SuperWade2's Avatar
Quite helpful, thanks!
Unread 05-11-2012, 01:54 PM   #780
4wdjeepguy
I was thinking out doing this as soon as I get some time. Planning on replacing the bushings and inspecting the races. Cleaning and regreasing everything. Putting on a fresh coat of black paint.
4wdjeepguy is offline   Reply With Quote Quick reply to this message
