SuperWade2's TJ Build Thread - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > SuperWade2's TJ Build Thread
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 01-22-2010, 06:43 PM   #16
SuperWade2
More Money than Brains
SuperWade2's Avatar
Finally got my Savvy Corner Armor ordered from Gerald this week. Should show up Monday, hope to get em installed before my Snow trip on Presidents day weekend.
I took the my Hanson Tire Carrier Off today ... 47lbs for just the frame... bumper has to be another 50-60 or so by itself I'd guess... No word from Gerald/MrBlaine on what their Rear is going to weigh, but I'd guess WAY WAY LESS
I can't wait see/get the Savvy Rear. I think I'm going to run without my spare until Savvy does the Tire Carrier (I'll get the Savvy bumper as soon as they are in production and they will sell me one). I didn't want to drill more holes in the corner armor than necessary (at least not 2 big ones that I won't be using very long to mount that old carrier!)
I had to jerryrig the License plate mount as I threw away the old plastic holder (if anyone has an extra laying around I'd be interested) and had been mounting it on the spare with a LED mount thing.
Here is how it looks waiting for some corners.
SuperWade2 is offline   Reply With Quote Quick reply to this message
Unread 01-22-2010, 08:38 PM   #17
338WinMag
what kinda headlight did you use to convert those stock one ?
338WinMag is offline   Reply With Quote Quick reply to this message
Unread 01-22-2010, 08:51 PM   #18
SuperWade2
SuperWade2's Avatar
These are the Round Eyes Replacement Headlights... They were better than stock, but only some... I could probably try a different H4 Bulb (but don't have a CLUE what I would/should try), and they are RIDICULOUSLY out of alignment (cause I don't really have a long flat spot to do the aiming thing on).
7" Round Jeep® Conversion Headlamps - Jeep® Headlamps by Roundeyes™ Inc.
Unread 01-25-2010, 07:09 PM   #19
SuperWade2
SuperWade2's Avatar
Savvy Corner Armor
Got a present for myself today...my Savvy Corner Armor is here... won't get em installed tonight, but couldn't help dry fitting.
Unread 01-29-2010, 12:03 PM   #20
SuperWade2
SuperWade2's Avatar
Finished my Savvy Full Corner Install last night. I reused my stock flares (with a fresh coat of Krylon Fusion) for now and may switch if something Bolt On were to hit the market eventually. I also want to get a set of the Tub Rails from Savvy once they are in full production with them. I may also someday pony up the $$$ for a set of their tail lights just so everything matches.
I plan on running like this (without a Spare) until I can get a Savvy Rear Bumper and eventually whatever swing out carrier that Blaine develops whenever that happens.
I don't drive at night much, so not real worried about getting pulled over for the lack of license plate light.
No big issues with the install...a couple of the OEM Torx bolts holding the Tailgate hinge stripped so had to drill the heads off with 5/16" Drill Bit and the rest of the bolt out with vice-grips. One of my Nuterts (that was probably an optional one anyhow) got a little off-center so I had to do tweaking to get a nut on the back of the bolt. Stripped a couple Bolt heads and missing 1, so will replace those once I get to Fastenal or somewhere that sells these stainless bolts.
Unread 01-29-2010, 01:05 PM   #21
BeepTheJeep
great looking jeep! congrats for your great find!
BeepTheJeep is offline   Reply With Quote Quick reply to this message
Unread 01-29-2010, 05:21 PM   #22
LGriffith
Looking good!
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote Quick reply to this message
Unread 02-04-2010, 11:48 PM   #23
LuckRider
LuckRider's Avatar
I love the savvy diet. I can't believe I haven't seen this thread yet. I am pretty sure that bumpre is going to be about 17lbs (even though Gerald thinks it is higher). You should lose a bit of weight with the TT too. Apparently the UCF skid weighs less than the factory skid.
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote Quick reply to this message
Unread 02-04-2010, 11:50 PM   #24
Mark4883
Damn this is a sweet Jeep!
Mark4883 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2010, 11:54 PM   #25
SuperWade2
SuperWade2's Avatar
Thanks... unfortunately I think that I'm 'locked in' to my Rubicon Express Long Arm Belly Pan. The Arm mounts are kind of integrated into the side frame mounts and then the bellypan mounts in the middle. So unless I change lifts (which I don't think I'm going to have the $$$ for any time soon, and I'm not unhappy for the most part with my RE Lift) or do some custom Mounts, I don't think I'll be able to get the Savvy TT/Engine Skids any time soon.
I did add the Savvy corner armor @ 13 lb or whatever per side, where I didn't have any before, so I guess I could subtract that from my weight loss, but it's splitting hairs.
Wade
Unread 02-04-2010, 11:57 PM   #26
LuckRider
LuckRider's Avatar
Yeah, but I would look at it as a preventative procedure. That is like packing a little bit of weight from muscle. It is better to be small and strong than have big muscles, but weak (like those muscle heads. A smaller guy can lift as much, thier muscle is just better utilized).
Rear bumper will do a lot to save weight. I actually hope to see a savvy rear tail gate.
Support Our Troops!
Unread 02-05-2010, 08:08 AM   #27
MountainMan864
All those mods and still on 33's. Step it up to 35's bigman. 33's look small to me nowadays.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2010, 10:08 AM   #28
SuperWade2
SuperWade2's Avatar
I know, I know... it's been near the top of my list for a good while now...every time I go drop another couple $'s on a new Savvy thing, it seems like something at the house blows up (I've replaced Water Heater, Water Softener, Pipe Burst above Living room and new sliding glass door in the past year or so), it just pushes the tires out a little further.
I was hoping to get some $$$ back on taxes this year to spend on tires, but I guess the Gov't decided they needed my money more than I needed new tires (even though I made 15% less than last year), but that's a different discussion for the political forum I guess.
Sw2
Unread 02-05-2010, 02:30 PM   #29
ChitwnGrnJP
I love your rig...I have an '04 in the same color. The combo of the Savvy corners, the Viking top, and the Litedots are awesome. I've been seriously considering the Savvy front bumper too. ha, in fact most of the parts you have are on my list of wants!
Any idea of when you're going to sell that Hanson tire carrier? I'm in the market for a tire carrier. Shipping would suck though...
| 3.5" RE Lift | 315/75R16 BFG KM2's | Dana 30 w/ Lockrite | Dana 44 | Metalcloak Front Bumper | Smittybilt Rocker Armor | Knockoff Warn Tire Carrier | Rokmen Shorty Corners |
ChitwnGrnJP is offline   Reply With Quote Quick reply to this message
Unread 02-05-2010, 02:49 PM   #30
SuperWade2
SuperWade2's Avatar
Thanks Much!
I'm selling the Hanson Rear as soon as Gerald and Blaine @ Savvy will sell me one of theirs. I have a local buyer from my club already, so unless he backs out, it's "spoken for". And I'm guessing your right, shipping would be $$$$.
Wade
