SuperWade2's TJ Build Thread - Page 13 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > SuperWade2's TJ Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-01-2010, 11:58 PM   #181
SuperWade2
More Money than Brains
SuperWade2's Avatar
Originally Posted by mudb8 View Post
don't do that, just swap the axle ends.... or get the axle end from JKS for a 99-04 WJ Grand Cherokee. I acually have one that needs a new bushing..
Why shouldn't I swap the TJS for a TJJ?
SuperWade2 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 12:04 AM   #182
mudb8
want it rite or rite now?
mudb8's Avatar
all you need is the axle end, the rest is the same, It'll likely save a bit on shipping costs.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 12:06 AM   #183
SuperWade2
SuperWade2's Avatar
It's only $7 to return it to Gerald @ Savvy, already boxed up and ready to Go.... Gerald said he'd get me a TJJ...just as easy for me to do a full swap... I got weeks before I'm done putting everything back together, so not worried about time...
I still have to figure out what I'm doing in the back with my shocks and mounts... that's a bigger concern of mine right now.
Unread 04-02-2010, 12:15 AM   #184
mudb8
mudb8's Avatar
Sweet!.......
Unread 04-02-2010, 05:45 PM   #185
SuperWade2
SuperWade2's Avatar
How much gap should there be when reinstalling Pitman arm? This is the Non-Drop that I reinstalling... i've never installed one before, so didn't know how far I should be able to get the arm on the steering box splines. If this isn't far enough how would I go about getting it further up?
Unread 04-02-2010, 07:26 PM   #186
SuperWade2
SuperWade2's Avatar
the RS99028 11.2" travel could work well with relocated axle mounts and properly set bumpstop extension, since they are 16.8" compressed.
Could I run the RS99028 with my current lower shock mount setup (I assume I'd still have to worry about the can hitting the spring perch), until I'm ready to outboard? Unless you want to sell me one of your's Mudb8 and I'll find someone to help me cut and weld... (BTW my axle tube is a little thicker than stock...would that make a difference?)
I'm thinking if I'm going to do something with these, it would be better to do before I put any miles on them. I can get the RS99028's for just a bit under $200 shipped ... I suspect I could get most of my money back for my RS999062 if they weren't actually "used" (I think they were just under $90/ea shipped)
Could use some opinions from any folks who might actually be following my build thread.
Sw2
Unread 04-02-2010, 07:46 PM   #187
RubiconRazorbac
RubiconRazorbac's Avatar
Hey Wade, I don't know how much gap there SHOULD be, but I just checked mine and it looks like yours. The gap is around 7/16 - 1/2" or so. Stock pitman arm, never been off the Jeep. My guess is if you have the nut torqued to spec, you're OK
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
RubiconRazorbac is offline   Reply With Quote Quick reply to this message
Unread 04-02-2010, 07:48 PM   #188
ET48
Don't worry about the correct gap. Just torque the nut, the splines are tapered and will dictate the distance.
Nice looking jeep btw.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline   Reply With Quote Quick reply to this message
Unread 04-03-2010, 12:07 AM   #189
mudb8
mudb8's Avatar
yep they would hit the can and be a bit short on uptravel, I'll see about making you a pair this weekend...
you'll need to move your brake line mounting tabs tho.
Sw2
I'll check on a price for you in the morning from my supplier...
Unread 04-03-2010, 12:25 AM   #190
SuperWade2
SuperWade2's Avatar
THANKS Mudb8!!!! I really appericiate the help... And since I have more $ than brains, skills or time, I'm happy to have someone with more of those things than I help me along. 8-)
Now I got myself wondering if I got the wrong ones up front too... Since they haven't been installed yet either maybe I should double check the length on them too! I'm on my iPhone, so can't pop open the PDF link right this second.
Unread 04-03-2010, 12:33 AM   #191
mudb8
mudb8's Avatar
I'm outta here for the night, the shop is getting cold, I'm hungry and wanna get home, I'll check back tomorrow for your front #
Unread 04-03-2010, 12:55 AM   #192
SuperWade2
SuperWade2's Avatar
The fronts are:
RS999061
S42 Upper Mount, XP4 Lower Mount
16.25" Collapsed
26.625" Extended
10.375" Travel
Which after doing a little Excel filtering of copy and paste from the PDF (I'm more of a computer geek than a Jeep one), the RS999061 appears to be the longest traveling of the Rancho 9000XL shocks with the S42/XP4 Mounting configuration. I don't know other mounts are also an option. There are 168 variations of the RS9000XL.
Unread 04-05-2010, 04:20 PM   #193
SuperWade2
SuperWade2's Avatar
Not "Build" specific (since nothing happened over the weekend and just waiting on parts, and to figure out my shock part # situation, any update Mudb8? ), but I picked up a new old unused 60Gal compressor over the weekend. I didn't have one before and had been doing everything by hand. I just need to get some 240v and get the hoses hooked up and I'll be good to go.
Unread 04-05-2010, 09:50 PM   #194
LuckRider
LuckRider's Avatar
I ma jealous. I wish I had one of those.
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote Quick reply to this message
Unread 04-06-2010, 11:37 AM   #195
mudb8
mudb8's Avatar
I haven't had time to dig into the front shocks, but the 200 bucks for the new rears isn't bad at all judging from from what they cost the shop to buy them... I did have time to check on those saturday, just never got it posted for ya....
