SuperWade2's TJ Build Thread - Page 11 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > SuperWade2's TJ Build Thread
The Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 03-28-2010, 09:32 PM   #151
SuperWade2
More Money than Brains
SuperWade2's Avatar
There you go man.
I just went down and beat the CRAP out of it with a dead blow hammer and a 4lb sledge on the 1-1/4" Socket... it didn't budge, even a little bit...I was worried about taking off the entire mount off the top of the pumpkin I was whacking it so hard...
Now I'm out of breath, need a beer and still have a stuck sleeve.
SuperWade2 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2010, 11:36 PM   #152
Bevo
Lifetime Premium Member
Bevo's Avatar
Try spraying some PB Blaster to loosen things up and give it a few minutes to work. If that still doesn't help maybe use heat on the outside so it will expand and apply some cold inside the sleeve so it will contract. If lube, heat/cold, and a BFH still don't get it I'm at a loss.
Bevo is offline   Reply With Quote Quick reply to this message
Unread 03-28-2010, 11:54 PM   #153
RubiconRazorbac
RubiconRazorbac's Avatar
That'd be the next thing to try. Heat is your friend
I wish I'd have gone this direction. Drilling the bushings to fit the Currie bolts wasn't fun. Plus, I'd rather have a joint there instead. I'm watching this close to see how it comes out. Once we move and I get another DD, I'm pulling the axle to do this.
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
RubiconRazorbac is offline   Reply With Quote Quick reply to this message
Unread 03-29-2010, 07:16 PM   #154
SuperWade2
SuperWade2's Avatar
Got it.... Used an extension on the 1-1/4" Socktet and the 4 Lb Sledge and went to to town... After the first couple of whacks it came out.. I did apply a little heat, but not a ton...and I sprayed a little PB on both sides last night before I gave up.
Unread 03-29-2010, 07:19 PM   #155
LuckRider
LuckRider's Avatar
Glad to hear you finally got it out. It is amazing how something that seems so simple turns out to be the biggest *****.
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote Quick reply to this message
Unread 03-29-2010, 08:17 PM   #156
SuperWade2
SuperWade2's Avatar
Got this today too... after chatting briefly with MrBlaine, I need to work myself to lopping off the passanger side mount here, maybe later 2nite if I can get the cut off wheel mounted on my grinder (having some issues for some reason)...will take a peek in a bit.
Unread 03-29-2010, 08:29 PM   #157
nriver
2011 JK Wrangler
Fun project. Keep it up.
Why do I post here?
nriver is offline   Reply With Quote Quick reply to this message
Unread 03-29-2010, 08:36 PM   #158
SuperWade2
SuperWade2's Avatar
Removing upper 1/2 of Pass Side UCA mount
Unread 03-29-2010, 08:38 PM   #159
The27Jeenyus
that looks like fun
Zach
Facebook
Originally Posted by Willy36 View Post
icequeen's got something sticky in her hair from some dude named zach
The27Jeenyus is offline   Reply With Quote Quick reply to this message
Unread 03-29-2010, 09:12 PM   #160
SuperWade2
SuperWade2's Avatar
And a few more...
Removing some paint, I probably took too much, but I like playing with the flapper disc 8-)
Test "fit" of the passenger side mount
And the driver side JJ... I have to finish pounding it in with the supplied "install tool", but my kids were going to bed, so I'll pound tomorrow.
Unread 03-29-2010, 09:14 PM   #161
The27Jeenyus
i cant wait to see it all buttoned up
Zach
Facebook
Unread 03-30-2010, 09:52 AM   #162
SuperWade2
SuperWade2's Avatar
I was eyeballing my rear shocks last night and really wondering if I should think about a lower shock shifter or new lower shock mount. They are both REALLY close to the spring perch now with the fatter tube on the bottom. The driver side is actually wedged against the hard brake line. I think LONG term I'd like to eventually outboard, and from reading the big long thread on it, the lower mount gets redone as well... I'm wondering if I should do that now and do the upper mount later... thoughts, suggestions?
Unread 03-30-2010, 11:05 AM   #163
Apex
Recon death squad
Apex's Avatar
Do it now before you destroy the tube on the shock. It'll happen and I think you know this.
Apex is offline   Reply With Quote Quick reply to this message
Unread 03-30-2010, 11:11 AM   #164
SuperWade2
SuperWade2's Avatar
So making the safe assumption that "fabbing" up my own lower mounts isn't within the realm of possibility, what are my options?
Unread 03-30-2010, 11:15 AM   #165
Apex
Recon death squad
Apex's Avatar
Have a chat with mudb8...he'll lay it all out for you.
Hell, I think he'll even send you out a template for the price of a stamp.
