SuperWade2's TJ Build Thread - Page 10 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > SuperWade2's TJ Build Thread
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 03-27-2010, 01:40 PM   #136
SuperWade2
More Money than Brains
SuperWade2's Avatar
Originally Posted by Houston_JP View Post
yessss! when are they getting mounted onto the jeep?
I wish I knew... I waiting on some parts for my front end, and then some time to get em installed.
If I get the rear shock bolt thing fixed today and the shock isntalled, I'll mount up the back 2 on and snap a pic!
Wade
SuperWade2 is online now   Reply With Quote Quick reply to this message
Unread 03-27-2010, 04:12 PM   #137
Apex
Recon death squad
Apex's Avatar
Wade, why are me and you doing things at the same time and rate? This is wild
I just got my 35"s mounted today. I am also sitting on a Rubicon Express short arm 3-link...(I wouldn't recommend driving it though)
Congrats on the tires though, can't wait to see them on the rig
Apex is offline   Reply With Quote Quick reply to this message
Unread 03-27-2010, 04:50 PM   #138
LuckRider
LuckRider's Avatar
Those tires look to have a bigger void than any other pic. I guess the angle makes all the difference, and people don't do a good job of showing the beasts.
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote Quick reply to this message
Unread 03-27-2010, 05:06 PM   #139
SuperWade2
SuperWade2's Avatar
Well, after 3 trips to the hardware store, a new Dremel, some new chisels, some new drill bits and some grade 8 hardware, and a buttload of hammering and swearing, I was able to get the weld nut cut off and the shock reinstalled. I decided to reward myself by installing my new rear tires. I need to dial down the shocks or let some air out of the tires (or both), or I'm never going to get the Rig thru the garage door. *Note* No Rear bumper and no spare, so I suspect that would droop the back a little bit, and I have jackstands under the frame and the nose down with no front Axle!
Here is evidence!
Unread 03-27-2010, 05:12 PM   #140
Apex
Recon death squad
Apex's Avatar
You might win the award for "tallest Jeep EVER"
I had the same thing going on today...my front axle was dropped all the way down and the frame was on jackstands and the 35s looked TINY with the huge gap...It looks much better now that the Jeep is sitting on it's own weight again. You'll be fine
Unread 03-27-2010, 05:18 PM   #141
SuperWade2
SuperWade2's Avatar
Yah, the LCoG police here on JF will be hunting my down here soon!!
I'm not worried, it's going to be a bit, but hopefully get the parts I need and stuff reinstalled up front in the next couple of weeks.
Wade
Unread 03-27-2010, 06:18 PM   #142
LuckRider
LuckRider's Avatar
Blah... Your gonna roll it... Blah... It is to high... Blah... That is dangerous... Blah... I hate HCoG... Blahhhhhhh.
Btw, I do understand the benefits of LCoG, but it depends on what you do.
Support Our Troops!
Unread 03-27-2010, 06:28 PM   #143
RubiconRazorbac
RubiconRazorbac's Avatar
Wade that's looking really good. Love the MTRs!
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
RubiconRazorbac is offline   Reply With Quote Quick reply to this message
Unread 03-28-2010, 09:56 PM   #144
SuperWade2
SuperWade2's Avatar
Originally Posted by SuperWade2 View Post
I popped out the old rubber bushing with a properly sized socket and my Ball Joint press (it's been getting a lot of work here recently, but no Ball joints). Does the "sleeve" that the red arrow is pointing too in the below pic stay on the axle, or do I need to figure out how to get it out too?
Bump, looking to get an answer from last week for a question that got lost in the excitement of new tires...
Unread 03-28-2010, 10:08 PM   #145
Imped
Imped's Avatar
Sleeve comes out too.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 03-28-2010, 10:10 PM   #146
SuperWade2
SuperWade2's Avatar
Any tips, or BFH?
Unread 03-28-2010, 10:11 PM   #147
LuckRider
LuckRider's Avatar
Vice grips
Support Our Troops!
Unread 03-28-2010, 10:14 PM   #148
Imped
Imped's Avatar
Put a correctly sized socket in there and pound it out.
OlllllllO
Float Test Build
IndyORV
Unread 03-28-2010, 10:22 PM   #149
SuperWade2
SuperWade2's Avatar
That's how the rubber bushing came out...guess I needed 1 size bigger to get the sleeve out too...
Unread 03-28-2010, 10:25 PM   #150
Imped
Imped's Avatar
There you go man.
OlllllllO
Float Test Build
IndyORV
