SuperWade2's TJ Build Thread - Page 58 - JeepForum.com
 2Likes
post #856 of 1160 Old 09-21-2012, 04:55 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
Well... slacked off from work this afternoon and started to finish the front end project. Got the 2" JJ rebuild kit from Gerald today (thanks GMan! ), and after a quick call and picture sent over from MrBlaine (thanks Blaine ), and a trip to ACE Hardware for some threaded rod, I was able to get it put back together, this was my first JJ service needed.
I got everything re-installed and tires back on the ground. I need to do an alignment and put my Driver side Rockers and Fender Flares back on but I'm getting close!
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #857 of 1160 Old 09-21-2012, 09:12 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Ok...so to recap here is the stuff I got done over the past few weeks...
* Installed New Timkin Unit Bearings (Machined beautifully to fit Vanco Kit Rotors)
* Installed New Synergy Ball Joints
* Installed New RE LCA Rubber Bushings (front 2, still need to do the back)
* Installed New RE UCA Rubber Bushings
* Installed New Spicer Axle U-Joints
* Installed New 2" Johnnie Joint UCA Bushing on Pass Side
* Removed, Cleaned and Regreased SuperFlex Joints On Long Arms (4 Long Arms + Large Tri-Link Mount), Sanded and Painted Arms
* Completely Removed ORO Swaylock, Cleaned, Re-greased and Re-installed
* Replaced a couple bolts that I screwed up (Driver Side Long Arm Axle and Frame Side, One of the JJ Greasebolts, etc)
I'm still not sure if my Front Drive Shaft may need to be rebuilt... I might call Tom Woods and see what they can tell me... when I last had it disconnected from the axle, there was basically no push back on the splines, it felt sloppy and it pooped all of the grease out of the little hole by the U-Joint, and the the upper grease fitting (and the metal around it) is pretty well wrecked.
I was kind of hoping that Gerald would have the Savvy Aluminum RE Belly Pan replacement (and hopefully Aluminum Engine Skid attached) ready that he has hinted about in a couple other threads, but I guess with his Vacations and all the race stuff, new product release stuff has fallen behind :-).
2017 WK2 Overland
post #858 of 1160 Old 10-11-2012, 03:31 PM Thread Starter
SuperWade2
SuperWade2's Avatar
On the road for the first time in almost 2 months... Pretty well wrapped up this round of fixes... I want to drop my front drive shaft and see if the vibes I'm feeling are from it (I think maybe), and it might need to be rebuilt. And some new Sliders to bolt on, and I'll be good I think until the next round of updates.
2017 WK2 Overland
post #859 of 1160 Old 10-11-2012, 09:06 PM Thread Starter
SuperWade2
SuperWade2's Avatar
p.s., I realized that my Viking top isn't waterproof any more... both seats quite wet where water dripping from zippers along the edge... Wet butt sucks!
2017 WK2 Overland
post #860 of 1160 Old 10-11-2012, 09:42 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Dang, I was going to ask you about that.
Jeep looks great. Bet you're glad it's rolling again!
Your shaft isn't long enough to handle that kind of droop...
My build thread:
RubiconRazorbac is offline
post #861 of 1160 Old 10-11-2012, 09:48 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Thor @ Viking sent me some seam sealer stuff last year for the top. I think I need to reapply at the threaded edges where the zipper ends.
Since its not my DD any more, and I really only had it out so I could get it aligned (I'm not very good at the driveway method), I can keep it home during most of the rain we get over the next several months.
2017 WK2 Overland
post #862 of 1160 Old 10-17-2012, 10:05 AM
4wdjeepguy
This may be a dumb question, but what how many lbs did you tighten your Superflex joints? Tight is tight?
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #863 of 1160 Old 10-17-2012, 07:07 PM Thread Starter
SuperWade2
SuperWade2's Avatar
About 3 grunts until the little alignment/screw hole thing lined up. I did buy the RE tool wrench ends and had it attached to my air tools. So I didn't goto a specific lb.
2017 WK2 Overland
post #864 of 1160 Old 10-18-2012, 07:18 AM
4wdjeepguy
Cool. I think I'm just going to throw my Craftsman impact on mine and let it go until it won't crank down anymore. I finally managed to split one of the original, large bushings from 2007, so it's time to pull all the arms and rebuild everything.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
post #865 of 1160 Old 11-09-2012, 09:41 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Giggity care package from Gman today!
A new set of these ->
To get painted and go on here->
2017 WK2 Overland
post #866 of 1160 Old 11-10-2012, 09:28 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
Nice, but why did you have to replace them? Dented?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #867 of 1160 Old 11-10-2012, 10:00 AM Thread Starter
SuperWade2
SuperWade2's Avatar
I wondered how long it would be before someone asked
When I had my front end torn apart a couple months ago and waiting on parts, I decided I'd go ahead and pull the sliders and rockers so I could re-install the sliders with the nut strips that Gerald had sent quite a while back. I'm not sure if he is including them or not now with Rocker/Sliders, but I think this was how they were originally designed so you could pull the sliders without pulling the rockers.
Anyhow when I went to take the Driver side slider off, all of the middle upper center bolts basically stripped out because of upward pressure in the middle of the slider. Once I got it off (had the cut 2 of the bolts), I found that the center section of the slider far enough pushed up that the holes in the slider were not close enough to lining up with the holes in the rocker/tub to reinstall
So I'm not sure if this was from the trips to JV, where my piss poor driving skills dropped pretty much the full weight of my rig on the bottom of the sliders, multiple times, or if I was a little too aggressive with the Jack in the center of the sliders when I preloaded them (installing initially with the Slider and Rocker mounted together;the only way they could be installed without the strip and the hardware originally included).
Gman recommended that I try the "heavier duty" step sliders which according to him includes a little more material and a bit different angles.
The moral of the story is I shouldn't have messed with the Sliders I had...they would have likely lasted forever on my rig and perfectly done their jobs if I hadn't removed them just to re-install them "differently".
I preferred the bare stainless look with the rest of the Aluminum stuff and the new ones will need to be painted, but small sacrifice to pay!
to Gman for his usual excellent customer service!
2017 WK2 Overland
post #868 of 1160 Old 11-11-2012, 05:20 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Painted... it's been cool, so I'll probably let them sit for a couple days to dry before I install.
2017 WK2 Overland
post #869 of 1160 Old 11-16-2012, 09:29 PM
Harvo
I have read alot of this thread and you have done a great job with the build. It still looks great and you obvbiously don't baby it offroad.
I didn't read wether you drive to the trails or haul in. Just curious.
02-TJ 3spd Auto, Locked Up, 35"MTRs, and some other stuff that keeps me out of trouble...
Harvo is offline
post #870 of 1160 Old 11-16-2012, 09:38 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Thanks Much, appreciate the feedback!
I do both... I don't own a flatbed, but have club member friends that do and willing to loan it the 1-2 times a year I prefer to tow. If I'm going somewhere far like Johnson Valley (8-9 hours from home), it's 100% a trailer trip. I've both trailer'ed it to places 3-4 hours away (say Twain Harte for our Snow run in the Sierra's with my family) and driven it it places 4+ hours hour like Niagara Rim. I've never busted anything bad enough on a trail that I wouldn't have been able to drive it home. Even when I bent my front axle pretty good at Pismo Beach a few years ago I drove it home 180 miles.
I live about an hour from Hollister Hills (where they do the Top Truck Challenge) and I've never towed it down there, always a drive down and play and then drive home.
2017 WK2 Overland
My build thread black2door Jeep Builds 455 04-10-2012 04:37 PM
My 03 TJ Build Thread teamoney Jeep Builds 43 12-23-2011 06:48 AM
My new XJ build thread. Element96x Jeep Builds 85 03-28-2011 09:32 AM
97 TJ Build Thread joet7287 Jeep Builds 72 05-03-2010 01:14 PM
