SuperWade2's TJ Build Thread - Page 52 - JeepForum.com
 2Likes
post #766 of 1161 Old 04-25-2012, 11:12 PM
aw12345
Originally Posted by SuperWade2 View Post
No clue, this was my first time on Jack... we started just to the left of this sign, up and around to the right.
I'm pretty sure we came down Jack North... I think we were going to do Wrecking Ball, but I was just following the group...I had no clue what was what.
This is the gatekeeper thing
This is the the fun part of wrecking ball
aw12345 is offline
post #767 of 1161 Old 04-26-2012, 10:05 AM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
I think I "bypassed" it to the right after the first 2 rigs in front of me failed to get up
Does this look like this spot?
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #768 of 1161 Old 04-26-2012, 07:32 PM
StvDiego
Originally Posted by TJRoberto View Post
Any closer pictures/video or specs of it?
He has 40" rock movers
Love his spotting technique,, such as it is. Did he back you into a rock yet; back, back, back, BAM, OK, that's far enough
Need to try to get another trip in before summer, only a couple of hours from here...
StvDiego is offline
post #769 of 1161 Old 04-26-2012, 10:17 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That's the beginning of Jack and that guy ain't on the line.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #770 of 1161 Old 04-26-2012, 10:18 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Right... he didn't make it either...
2017 WK2 Overland
post #771 of 1161 Old 04-26-2012, 10:25 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Can't imagine anyone else I'd rather have spotting me...even with the ration of **** he gives me!
2017 WK2 Overland
post #772 of 1161 Old 05-09-2012, 09:16 PM Thread Starter
SuperWade2
SuperWade2's Avatar
This is probably a pretty simple question but wanted to check before I did something I regretted.
I've never completely removed any of my RE Long Arms since they were installed coming up on 5 years ago this summer (although probably only 10-12K miles since installing). The fronts have been unbolted from the Axle a couple times for axle swapping/fixing, etc but I've never removed from the frame side, and never touched the rears.
Anyhow, I'd like to yank them off, check all the bushings, check / clean / service / throw fresh grease in the flex joints, maybe throw a coat of paint on them to keep from rusting where I've scrapped them pretty good on rocks... Also the Tri-Link connection in back is pretty gunky and want to make sure it's all good.
Anyhow the simple question is, can I just remove the arms one at a time, with the Jeep on level ground in garage, tires all touching the ground. Do the check/clean/service, re-install and move onto the next one?
I assume they should all be re-installed with specific torque values, but I'll have to dig up and see if I still have the install directions (I didn't install the lift originally, I had it done at a shop).
Thanks in Advance!
Wade
2017 WK2 Overland
post #773 of 1161 Old 05-10-2012, 07:53 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Thanks in Advance!
Wade
I guess I'll just do it and see how it turns out...if they find me dead under the rig I'll know it wasn't a good idea.
2017 WK2 Overland
post #774 of 1161 Old 05-10-2012, 08:00 PM
StvDiego
Dibs on the Savvy stuff
StvDiego is offline
post #775 of 1161 Old 05-10-2012, 08:23 PM
matthewh_1
I've had all 4 of my rear ones off at the same time with the parking brake on, no worries! I've even driven around missing one before.. You shouldn't have any issues removing one at a time.
National Topless Day 2010 winner!
Zombie Outbreak Response Unit #70
Originally Posted by jclauson View Post
When a girl tells you your flex is sexy then you are doing something right in life.
matthewh_1 is offline
post #776 of 1161 Old 05-11-2012, 11:51 AM Thread Starter
SuperWade2
SuperWade2's Avatar
First Arm Off... Driver Lower... Nice and Gunky!
Just a few small scratches on bottom...
And the Rubber Bushing isn't horrible...small cracks, just a bit oblong, but not sure if repalcement warranted yet! Thoughts?
2017 WK2 Overland
post #777 of 1161 Old 05-11-2012, 12:41 PM
MountainMan864
Take it all off and go sell Plasma and Sperm. Instant free new suspension system.
MountainMan864 is offline
post #778 of 1161 Old 05-11-2012, 12:47 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Quite helpful, thanks!
2017 WK2 Overland
post #779 of 1161 Old 05-11-2012, 01:54 PM
4wdjeepguy
I was thinking out doing this as soon as I get some time. Planning on replacing the bushings and inspecting the races. Cleaning and regreasing everything. Putting on a fresh coat of black paint.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #780 of 1161 Old 05-11-2012, 07:19 PM Thread Starter
SuperWade2
SuperWade2's Avatar
First Superflex Joint disassembled, cleaned, inspected and put back together (Thanks to Stu's page for some help)...no damage or gouging on the nylon races or the ball, so cleaned off the old grease and put everything back together. I ordered the $20 RE tool to tighten the end of the joint, which won't be here till next week, but going to Yosemite for 4 days anyhow. Once we get back, I'll tighten, re-install and move on to the next arm. I also got a replacement Currie TRE today from Gerald that I will install and also replace the Steering Stabilizer.
Also threw on a coat of paint on the arms to keep things from rusting even though we have very little rust here, it was gouged bare metal.
2017 WK2 Overland
My build thread black2door Jeep Builds 455 04-10-2012 03:37 PM
My 03 TJ Build Thread teamoney Jeep Builds 43 12-23-2011 05:48 AM
My new XJ build thread. Element96x Jeep Builds 85 03-28-2011 08:32 AM
97 TJ Build Thread joet7287 Jeep Builds 72 05-03-2010 12:14 PM
