SuperWade2's TJ Build Thread - Page 2 - JeepForum.com
 2Likes
post #16 of 1161 Old 01-22-2010, 07:38 PM
338WinMag
what kinda headlight did you use to convert those stock one ?
338WinMag is offline
post #17 of 1161 Old 01-22-2010, 07:51 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
These are the Round Eyes Replacement Headlights... They were better than stock, but only some... I could probably try a different H4 Bulb (but don't have a CLUE what I would/should try), and they are RIDICULOUSLY out of alignment (cause I don't really have a long flat spot to do the aiming thing on).
7" Round Jeep® Conversion Headlamps - Jeep® Headlamps by Roundeyes™ Inc.
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #18 of 1161 Old 01-25-2010, 06:09 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Savvy Corner Armor
Got a present for myself today...my Savvy Corner Armor is here... won't get em installed tonight, but couldn't help dry fitting.
2017 WK2 Overland
post #19 of 1161 Old 01-29-2010, 11:03 AM Thread Starter
SuperWade2
SuperWade2's Avatar
Finished my Savvy Full Corner Install last night. I reused my stock flares (with a fresh coat of Krylon Fusion) for now and may switch if something Bolt On were to hit the market eventually. I also want to get a set of the Tub Rails from Savvy once they are in full production with them. I may also someday pony up the $$$ for a set of their tail lights just so everything matches.
I plan on running like this (without a Spare) until I can get a Savvy Rear Bumper and eventually whatever swing out carrier that Blaine develops whenever that happens.
I don't drive at night much, so not real worried about getting pulled over for the lack of license plate light.
No big issues with the install...a couple of the OEM Torx bolts holding the Tailgate hinge stripped so had to drill the heads off with 5/16" Drill Bit and the rest of the bolt out with vice-grips. One of my Nuterts (that was probably an optional one anyhow) got a little off-center so I had to do tweaking to get a nut on the back of the bolt. Stripped a couple Bolt heads and missing 1, so will replace those once I get to Fastenal or somewhere that sells these stainless bolts.
2017 WK2 Overland
post #20 of 1161 Old 01-29-2010, 12:05 PM
BeepTheJeep
great looking jeep! congrats for your great find!
BeepTheJeep is offline
post #21 of 1161 Old 01-29-2010, 04:21 PM
LGriffith
Looking good!
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith is offline
post #22 of 1161 Old 02-04-2010, 10:48 PM
LuckRider
LuckRider's Avatar
I love the savvy diet. I can't believe I haven't seen this thread yet. I am pretty sure that bumpre is going to be about 17lbs (even though Gerald thinks it is higher). You should lose a bit of weight with the TT too. Apparently the UCF skid weighs less than the factory skid.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #23 of 1161 Old 02-04-2010, 10:50 PM
Mark4883
Damn this is a sweet Jeep!
Mark4883 is offline
post #24 of 1161 Old 02-04-2010, 10:54 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Thanks... unfortunately I think that I'm 'locked in' to my Rubicon Express Long Arm Belly Pan. The Arm mounts are kind of integrated into the side frame mounts and then the bellypan mounts in the middle. So unless I change lifts (which I don't think I'm going to have the $$$ for any time soon, and I'm not unhappy for the most part with my RE Lift) or do some custom Mounts, I don't think I'll be able to get the Savvy TT/Engine Skids any time soon.
I did add the Savvy corner armor @ 13 lb or whatever per side, where I didn't have any before, so I guess I could subtract that from my weight loss, but it's splitting hairs.
Wade
2017 WK2 Overland
post #25 of 1161 Old 02-04-2010, 10:57 PM
LuckRider
LuckRider's Avatar
Yeah, but I would look at it as a preventative procedure. That is like packing a little bit of weight from muscle. It is better to be small and strong than have big muscles, but weak (like those muscle heads. A smaller guy can lift as much, thier muscle is just better utilized).
Rear bumper will do a lot to save weight. I actually hope to see a savvy rear tail gate.
Support Our Troops!
JFI Member #7:
post #26 of 1161 Old 02-05-2010, 07:08 AM
MountainMan864
All those mods and still on 33's. Step it up to 35's bigman. 33's look small to me nowadays.
MountainMan864 is offline
post #27 of 1161 Old 02-05-2010, 09:08 AM Thread Starter
SuperWade2
SuperWade2's Avatar
I know, I know... it's been near the top of my list for a good while now...every time I go drop another couple $'s on a new Savvy thing, it seems like something at the house blows up (I've replaced Water Heater, Water Softener, Pipe Burst above Living room and new sliding glass door in the past year or so), it just pushes the tires out a little further.
I was hoping to get some $$$ back on taxes this year to spend on tires, but I guess the Gov't decided they needed my money more than I needed new tires (even though I made 15% less than last year), but that's a different discussion for the political forum I guess.
Sw2
2017 WK2 Overland
post #28 of 1161 Old 02-05-2010, 01:30 PM
ChitwnGrnJP
I love your rig...I have an '04 in the same color. The combo of the Savvy corners, the Viking top, and the Litedots are awesome. I've been seriously considering the Savvy front bumper too. ha, in fact most of the parts you have are on my list of wants!
Any idea of when you're going to sell that Hanson tire carrier? I'm in the market for a tire carrier. Shipping would suck though...
| 3.5" RE Lift | 315/75R16 BFG KM2's | Dana 30 w/ Lockrite | Dana 44 | Metalcloak Front Bumper | Smittybilt Rocker Armor | Knockoff Warn Tire Carrier | Rokmen Shorty Corners |
ChitwnGrnJP is offline
post #29 of 1161 Old 02-05-2010, 01:49 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Thanks Much!
I'm selling the Hanson Rear as soon as Gerald and Blaine @ Savvy will sell me one of theirs. I have a local buyer from my club already, so unless he backs out, it's "spoken for". And I'm guessing your right, shipping would be $$$$.
Wade
2017 WK2 Overland
post #30 of 1161 Old 02-07-2010, 08:01 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
looks great!
My builds:
and
or follow us on
spyder6 is offline
My build thread black2door Jeep Builds 455 04-10-2012 03:37 PM
My 03 TJ Build Thread teamoney Jeep Builds 43 12-23-2011 05:48 AM
My new XJ build thread. Element96x Jeep Builds 85 03-28-2011 08:32 AM
97 TJ Build Thread joet7287 Jeep Builds 72 05-03-2010 12:14 PM
