SuperWade2's TJ Build Thread - Page 11 - JeepForum.com
 2Likes
post #151 of 1161 Old 03-28-2010, 11:36 PM
Bevo
Lifetime Premium Member
Bevo's Avatar
Try spraying some PB Blaster to loosen things up and give it a few minutes to work. If that still doesn't help maybe use heat on the outside so it will expand and apply some cold inside the sleeve so it will contract. If lube, heat/cold, and a BFH still don't get it I'm at a loss.
Bevo is offline
post #152 of 1161 Old 03-28-2010, 11:54 PM
RubiconRazorbac
RubiconRazorbac's Avatar
That'd be the next thing to try. Heat is your friend
I wish I'd have gone this direction. Drilling the bushings to fit the Currie bolts wasn't fun. Plus, I'd rather have a joint there instead. I'm watching this close to see how it comes out. Once we move and I get another DD, I'm pulling the axle to do this.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #153 of 1161 Old 03-29-2010, 07:16 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
Got it.... Used an extension on the 1-1/4" Socktet and the 4 Lb Sledge and went to to town... After the first couple of whacks it came out.. I did apply a little heat, but not a ton...and I sprayed a little PB on both sides last night before I gave up.
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #154 of 1161 Old 03-29-2010, 07:19 PM
LuckRider
LuckRider's Avatar
Glad to hear you finally got it out. It is amazing how something that seems so simple turns out to be the biggest *****.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #155 of 1161 Old 03-29-2010, 08:17 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Got this today too... after chatting briefly with MrBlaine, I need to work myself to lopping off the passanger side mount here, maybe later 2nite if I can get the cut off wheel mounted on my grinder (having some issues for some reason)...will take a peek in a bit.
2017 WK2 Overland
post #156 of 1161 Old 03-29-2010, 08:29 PM
nriver
2011 JK Wrangler
Fun project. Keep it up.
Why do I post here?
nriver is offline
post #157 of 1161 Old 03-29-2010, 08:36 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Removing upper 1/2 of Pass Side UCA mount
2017 WK2 Overland
post #158 of 1161 Old 03-29-2010, 08:38 PM
The27Jeenyus
that looks like fun
Zach
Originally Posted by Willy36 View Post
icequeen's got something sticky in her hair from some dude named zach
The27Jeenyus is offline
post #159 of 1161 Old 03-29-2010, 09:12 PM Thread Starter
SuperWade2
SuperWade2's Avatar
And a few more...
Removing some paint, I probably took too much, but I like playing with the flapper disc 8-)
Test "fit" of the passenger side mount
And the driver side JJ... I have to finish pounding it in with the supplied "install tool", but my kids were going to bed, so I'll pound tomorrow.
2017 WK2 Overland
post #160 of 1161 Old 03-29-2010, 09:14 PM
The27Jeenyus
i cant wait to see it all buttoned up
Zach
post #161 of 1161 Old 03-30-2010, 09:52 AM Thread Starter
SuperWade2
SuperWade2's Avatar
I was eyeballing my rear shocks last night and really wondering if I should think about a lower shock shifter or new lower shock mount. They are both REALLY close to the spring perch now with the fatter tube on the bottom. The driver side is actually wedged against the hard brake line. I think LONG term I'd like to eventually outboard, and from reading the big long thread on it, the lower mount gets redone as well... I'm wondering if I should do that now and do the upper mount later... thoughts, suggestions?
2017 WK2 Overland
post #162 of 1161 Old 03-30-2010, 11:05 AM
Apex
Recon death squad
Apex's Avatar
Do it now before you destroy the tube on the shock. It'll happen and I think you know this.
Apex is offline
post #163 of 1161 Old 03-30-2010, 11:11 AM Thread Starter
SuperWade2
SuperWade2's Avatar
So making the safe assumption that "fabbing" up my own lower mounts isn't within the realm of possibility, what are my options?
2017 WK2 Overland
post #164 of 1161 Old 03-30-2010, 11:15 AM
Apex
Recon death squad
Apex's Avatar
Have a chat with mudb8...he'll lay it all out for you.
Hell, I think he'll even send you out a template for the price of a stamp.
Apex is offline
post #165 of 1161 Old 03-30-2010, 11:27 AM Thread Starter
SuperWade2
SuperWade2's Avatar
I've seen that... Maybe I'm looking at 2 different things (at least what I was on Humbolts thread) looked to drop the mount even lower than the stock one (which I'm not crazy about).
If I'm going to outboard eventually, it looks like I'd have to move the mount towards the week eventually anyhow. Without moving the mount over (which I don't know that I'm ready for, nor if the new Rancho Shocks I just bought would even support), I don't know that I'd really solve the problem with it hitting the the lower spring perch.
2017 WK2 Overland
My build thread black2door Jeep Builds 455 04-10-2012 03:37 PM
My 03 TJ Build Thread teamoney Jeep Builds 43 12-23-2011 05:48 AM
My new XJ build thread. Element96x Jeep Builds 85 03-28-2011 08:32 AM
97 TJ Build Thread joet7287 Jeep Builds 72 05-03-2010 12:14 PM
