Super Duper Pete's White Russian Buildathon - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Super Duper Pete's White Russian Buildathon
Unread 03-16-2012, 10:35 AM   #76
Apostle
2015 KL Cherokee
upgrade shocks for added length of the lift received with these. if he is netting two inches then want the shocks to be comparable. not sure how much of a lift you can get by with, with stock shocks.
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline   Reply With Quote Quick reply to this message
Unread 03-16-2012, 10:53 AM   #77
ncb
The shocks probably can't be much longer than stock length because the stock and TF coils are the same length. With longer shocks the coils might become unseated. When you increase ride height and use stock shocks you're giving up extension and increasing the compression length. Chances are your front shocks don't have much extension left with the new coils. I'm not saying your set up isn't good or won't work. With the flat fenders you have plenty of room for 37s. You'll need to install a complete kit in the future if you want to upgrade.
ncb is offline   Reply With Quote Quick reply to this message
Unread 03-16-2012, 11:04 AM   #78
neverhide34
2011 JK Wrangler
In the near future I do plan on upgrading to the TF 9550 shocks. When i dropped the axle for the coil installation I was surprised at how little the stock shocks actually extend. As for the lift height.. it suits me right down to the ground and i won't be going any higher. Though other suspension components will be upgraded with leisure.
Keep Calm, Chive On
neverhide34 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2012, 08:07 PM   #79
mms1946
Jeep looks good. Is it that bad with 4.10s and 35s? I'm in EC as well.
1989 YJ: 1991 - 1996
2000 TJ: 2008 - 2010
2007 JKU: 2011
mms1946 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2012, 08:56 PM   #80
SlvrJK08
Looks great dude, huge fan of lcog builds as I myself have gone the lcog route with my rig.
2008 JK X 2-door, 37" MTRK's, Xenon narrows, 3" Synergy frankenlift, Prorock 44 front with 5.13's/rcv's/rubi locker, Rock Jock 60 rear w/ 5.13's and a Detroit, and lots of armor...
SlvrJK08 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2012, 09:12 PM   #81
neverhide34
2011 JK Wrangler
Thanks man. We should plan a wheeling trip if you're up for it. 35's and 4.10's are.. ah.... drivable. It was really bad when I drove it for the first time. I was certain that regearing was my next mod until I became used to it. The main difference is that 6'th gear is no longer useful. Yeah it's underpowered on the black top.. So what's new? I decided to hold off to regear until I install the 37's.
Keep Calm, Chive On
Unread 03-16-2012, 09:15 PM   #82
neverhide34
2011 JK Wrangler
Thanks. I thought it would be beneficial and exciting to do something different. But who knows. Someday I might pull the gloves off and install a TF 3 inch. But so far, I couldn't be happier
Keep Calm, Chive On
Unread 03-23-2012, 03:14 PM   #83
cwboggs1
In case you were wondering what 37's look like with no lift...
cwboggs1 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2012, 04:39 PM   #84
awinski
Sex ^
awinski is offline   Reply With Quote Quick reply to this message
Unread 05-21-2012, 11:29 PM   #85
4DFUN
Any new updates?
4DFUN is offline   Reply With Quote Quick reply to this message
Unread 05-23-2012, 01:43 PM   #86
ZIMM18
Did you re-gear?
Not Banned
ZIMM18 is offline   Reply With Quote Quick reply to this message
Unread 06-02-2012, 12:19 AM   #87
neverhide34
2011 JK Wrangler
Trying to fix a mistake. I think...
So after I realized that I hit a dead end by purchasing 15 in wheels, I have come to a decision. I will have to sell my newly bought wheels and tires and new tires (37 in M/T's) will be mounted on my original Moabs though this purchase will be put in the back burner until I can afford to do tires and gears at the same time or so. Luckily my set of tires has only been up for a day and already has a few bites.
Well it was a knee jerk purchase in the first place. I better be more careful, I may never get a second chance again. I have yet to decide where to put the cash I'm about to get back.
I'm definitely going to use it to powder coat my fenders. This Duplicolor Spray on crap won't last a week on the bottom of the fender. Then I will need a winch. Well this build has come to a complete halt.
I've also been thinking about doing the homebrew cowl snorkel mod that is in the popular threads section of the FAQ.
Keep Calm, Chive On
Unread 06-02-2012, 08:57 AM   #88
Butterjeep
2015 WK
If you're going to run the stock wheels again will you be running spacers? If so which ones?
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline   Reply With Quote Quick reply to this message
Unread 06-02-2012, 09:07 AM   #89
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Spidertrax just released their "thick" versions at 1 3/4". I had my spacers custom machined at 2" thick so I could get 4" of back space
Sent by Paper Planes
My builds: Bruiser and The Grey
|Forge Overland| or follow us on Facebook
spyder6 is offline   Reply With Quote Quick reply to this message
Unread 06-02-2012, 04:53 PM   #90
neverhide34
2011 JK Wrangler
Yeah I was planning on either SpiderTrax or Alloy USA. I hear that they are pretty close matched when it comes to ingenuity and reliability and the main decision between em is color desired. I'm not worried about colors really so I might just go with SpiderTrax since it seems so many more members run these and swear by them.
Thanks for the info Spyder6. Since I want to run 37's will 1 3/4 work or will I need mine to be custom at 2"? And congrats for landing the Moderator gig.
I was looking at the Jeep J8's bumpers and I think I might want to go that route. It would be easy with C Channel and D ring mounts. It would mount over the existing metal piece under the plastic bumper. I already have a universal winch channel so I just need to find a way to fab a bit so I can add a winch. I also want it to retain the fogs. It will maintain a rugged military look. It will also be very budget friendly. Thinking about doing the same for the rear bumper. Just fab up some C Channel with d-ring mounts. Then again, i will need it to have a tire carrier big and sturdy enough for 37's.
Front will be something like this with provisions for a winch and possibly the factory fogs. I might just ditch the fogs and mount auxiliary lights that are controlled by the fog switch. Don't know yet.
http://www.jgms.com/resource/medium/...11cb46b176.JPG
The rear will be something like this but instead of a tow pintle I would try to retain the factory tow hitch since I do need it for my trailer, bike carrier, boat trailer and any other hobby I so choose for the week, haha.
http://www.jgms.com/resource/medium/...a13f7ac65a.jpg
Wha-da-ya think?
Keep Calm, Chive On
