-   Jeep Builds (http://www.jeepforum.com/forum/f22/)
-   -   The Stretch ... (http://www.jeepforum.com/forum/f22/stretch-640107/)
NaeKid 11-29-2008 04:41 PM
The Stretch ...
Well - its been almost 3 years, and, at the beginning I stated that I will not modify my new LJ .. I am such a liar :laugh:
The day I picked it up:
http://www.jeepforum.com/gallery/data/4/SUC50071.JPG
Mostly still stock - just a new back bumper
http://www.jeepforum.com/gallery/data/4/S5000663.JPG
Installed a fuse-box and tool right beside the fuse panel
http://www.jeepforum.com/gallery/data/4/S5000451.JPG
Proceeded to drive across Canada
http://www.jeepforum.com/gallery/dat...EI-Dipping.jpg
Installed Aussie locker
http://www.jeepforum.com/gallery/dat...m/S5002726.JPG
Installed Airaid throttle body spacer
http://www.jeepforum.com/gallery/dat...m/S5002657.JPG
Installed 1 1/4" wheel spacers
http://www.jeepforum.com/gallery/dat...m/S5002729.JPG
And with a 2" RE lift, I fit my new 32" BFGs
http://www.jeepforum.com/gallery/dat...m/S5003288.JPG
No close-up pictures of my Bushwacker hood and fender protectors, no close-ups of my head-light guards or my tail-light guards. No pictures of my door sill and tail stainless guards. No pictures of my air-bag setup .. but, they are all on there. Just ask, and I can add more pictures!
Godchsr 11-29-2008 05:35 PM
hahaha It's a disease!
Nothing every stays stock! :P
FletchXJ 11-29-2008 06:44 PM
Congrats! I have a 350z that got me with the mod bug and when I bought this I started spending the same day, :D.
Eagle9046 01-15-2009 03:11 PM
So did that Throttle spacer help out with the touchy go-go pedal!
NaeKid 01-16-2009 07:42 AM
When I ran the stock tires, in first gear it was really jerky .. 2 gear wasn't much better. After putting on my 32" tires, it really helped to smooth out the drive. The throttle-body spacer seemed to boost my gas milage by almost 100km / tank.
Right now my gas milage has dropped significantly / tank. I will be doing some maintenance on my Jeep - new spark plugs, clean my throttle-body and spacer. It might be due to my 32" tires - but - I might as well do something to see if I can make it better :teehee:
NaeKid 04-27-2009 08:25 AM
3 Attachment(s)
So - I made some new goodies for my Jeep. I replaced the rear bumper again with another design and this weekend I fabb'd up a new front bumper. Its not finished yet, but, it is getting closer.
I will be capping the bumper-ends with some 1/8" CheckerPlate and I haven't decided if I want to put tow-tabs on the front or build a stinger. If I go with the tow-tabs, I will design them to be a steering-box protector. If I go with the stinger, then again, I would want to protect the steering box from impacts.
mJUSTINm 05-04-2009 06:32 PM
could you get some more shots? im thinking about getting a 2.5" lift with 32s for my LJ and want to see as much as i can. thanks.
flatlander757 05-04-2009 09:15 PM
The front bumper looks really good! Just add some d-ring shackle mounts!
And what's with the title? I was hoping to see a cut up LJ w/ stretched wheelbase :laugh:
NaeKid 05-05-2009 11:58 AM
I have some pictures in the "Picture Requests" section of my Jeep. Thread is called "Head on pics"
Specific replies with the pictures ..
http://www.jeepforum.com/forum/showp...&postcount=236
http://www.jeepforum.com/forum/showp...&postcount=238
NaeKid 05-05-2009 01:09 PM
Having three Jeeps in the household each one has been given a nickname. This one has finally settled on "The Stretch". My white one is "The Monster" and the little lady's hasn't really been named yet ... still have to come up with something better than That damn thing is broken :rofl:
NaeKid 02-19-2010 08:14 AM
I decided to leave the bumper as is. That is TJ-bumper-design Rev3. I have already started designing TJ-bumper-design Rev4 that will be about 1 1/4" shorter (not stick out quite as far from the frame-rails) with a couple more bends just for strength-factor. If I like how the next design turns out, it will get a brush-guard, steering-box-guard and D-ring shackle-mounts. The one that is currently on my Jeep will probably be sold off to make room for the next design. Nothing really wrong with it, just not as happy with it as I feel I should be.
So, that picture above of the bumper that I designed and welded up, well, it is painted now and I found an 8000# Warn winch for it, put on some new driving lights and it is on the Jeep :thumbsup:
http://www.jeepforum.com/gallery/dat...16_Medium_.JPG
Picture taken in the parking lot at work, I'll get a better picture when the weather turns a little bit better.
patrick076 05-08-2010 03:31 AM
very nice and well maintained vehicle all credits for owner
corndogduff 05-08-2010 04:01 AM
Without a doubt one of the most inportant "first mods" you can do, ask me how I know :brickwall
NaeKid 06-07-2010 08:19 AM
2 Attachment(s)
I was bored so I took some time and drew-up a CB antenna mount in AutoCAD, sent it to the laser, bent it on the little Ursviken 220-ton CNC break, primer'd it and painted it. Then put the antenna on - looked good. I made it so that it can be placed on either the driver-side or the passenger side of the Jeep. Currenty, it is on the passenger-side, I may choose to re-route the wire and run it on the driver's side with one of the other brackets that I made.
Then installed a CB-radio in the foot-well of the front-passenger-side. Also installed a switch so that I can choose when my interior lights come on ...
Picture of the CAD drawing that I did and one of the break in the shop. Following message will have the picture of the final product.
NaeKid 06-07-2010 08:29 AM
2 Attachment(s)
And here are the pictures as promised. How the mount looks tucked tight between the tail-light, the body, the hinge and the wire runs smoothly between the top of the light-housing and the mount.
And, a simple install of the CB-Radio on the bottom edge of the dash. Seems to do well enough there. Yes, the seat does touch the CB when I move the seat forward to put people in the rear, but, it isn't putting alot of pressure onto the CB so I am not too worried about it. I still need to figure out a good place to clip the microphone. So far, I haven't picked a spot, so, when I am not using the system, the mic sits in my glove-box.
The time now is 03:36 AM.
