Stone's '93 YJ Build - Page 7 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Stone's '93 YJ Build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-03-2011, 08:10 PM   #91
jeepster1407
Man, that thing looks sweet! ive got those same axles sitting in my building already built just waiting on a few small parts like u joints and wheels. do you have a pic from the front? and how you ran your rear brake lines?? and what width wheels are those and what backspacing? what pitman arm did you use? also i have those same tires aswell. I really like it and am considering rock rings aswell, only i cant weld as good as you so ill probably grind mine smooth. anyways Great build man!!! Oh, have you taken it down the rd yet? does she ride smooth with the tires?
jeepster1407 is offline   Reply With Quote Quick reply to this message
Unread 10-03-2011, 08:54 PM   #92
stone
I haven't ran the brake lines yet. The wheels are 16.5 x 9.75 with 4.5" backspacing. Stock pitman arm, just drilled out the taper. I haven't driven it yet. Still need to get brake lines, install the SYE, add a leaf from my extra springs, cut the driveshafts down. Once I can move it I'll throw it on the trailer and take it to work and flex it out to measure for shocks. I was going to build my own shock hoops but I like the MORE setup and since they're pretty cheap I might just go that route. If only I had more time and money!
Here's a picture of the front
My YJ Build - http://www.jeepforum.com/forum/f22/stones-93-yj-build-1115815/
stone is offline   Reply With Quote Quick reply to this message
Unread 10-03-2011, 08:57 PM   #93
stone
Originally Posted by '92 vegas YJ View Post
Looks great.
Ive been watching since the beginning
Thanks!
Originally Posted by gspup View Post
Let me know how you like these after running a few trails. I'm thinking about making some at work myself. Great build.
Will do. The plan is for inner air locks once funds allow it.
Unread 10-04-2011, 06:35 AM   #94
jeepster1407
Your still going to use the factory front shaft right? Looks great! Mine will be identical lol.
Unread 10-04-2011, 08:14 AM   #95
jeepster1407
how close is the Passenger side front leaf spring to the tie rod with the stock pit man arm? any potential issues with it hitting? sorry for all the questions man I'm just literally about to do the SAME swap lol
Unread 10-04-2011, 10:37 PM   #96
stone
Yeah factory front shaft. I need to cut it down just a little bit, we'll see how far once I get the extra leaf in there.
It's not that close. I have turned it to full lock both ways with no problems.
Unread 10-05-2011, 03:58 PM   #97
jeepster1407
awesome. I was unaware i will have to cut the front shaft down though. does it bind when flexing?
Unread 10-05-2011, 05:19 PM   #98
stone
It barely fits at ride height, I have to have it all the way collapsed and even then I have to spin it just right to even get it to sit in the yoke.
Unread 10-10-2011, 10:32 AM   #99
jeepster1407
Any updates over the weekend??
Unread 10-10-2011, 11:04 AM   #100
1LittleYj
Looks awesome man!!
1LittleYj is offline   Reply With Quote Quick reply to this message
Unread 10-10-2011, 09:47 PM   #101
stone
Not nearly as much as I wanted, but I did get some pictures of the steering for you.
Also pulled the transfer case
and almost finished the SYE kit before I ran out of time, hopefully sometime this week I'll be able to finish it up so I can put the transfer case back in.
Unread 10-11-2011, 09:49 AM   #102
jeepster1407
Looks great man! Did you have any issues with the tie rod contacting the diff cover in that position? Im running my tie rod just like you and I know with my SOLID diff cover I had to adjust my steering stops out a little to keep it from contacting the cover. Looks really good btw!
_________
My Thread - http://www.jeepforum.com/forum/f22/p...arrel-3291513/
Unread 10-11-2011, 07:37 PM   #103
stone
No but I'm also running a stock diff cover right now
Unread 10-12-2011, 01:24 PM   #104
jeepster1407
Looks very stable with the low stance also!
_________
Unread 10-12-2011, 03:20 PM   #105
TJRHD
thats awesome!
NOT A HATER
TJRHD is offline   Reply With Quote Quick reply to this message
