Stone's '93 YJ Build - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Stone's '93 YJ Build
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 11-20-2010, 08:45 PM   #46
stone
Installed the locker and new axle seals in the front axle today. Started to pull it apart and found some water, and that the wheel bearing on the passenger side was in poor shape, so it's being replaced.
Carrier removed
Spartan locker installed. Very easy install, so far nothing bad to say about this locker at all. We'll see how it performs.
That's it so far, slowly making progress.
My YJ Build - http://www.jeepforum.com/forum/f22/stones-93-yj-build-1115815/
stone is offline   Reply With Quote Quick reply to this message
Unread 11-20-2010, 09:36 PM   #47
The_Blacksmith
Genius with this metal
The_Blacksmith's Avatar
1993 XJ Cherokee
awesome, keep it up!
The_Blacksmith is offline   Reply With Quote Quick reply to this message
Unread 11-22-2010, 04:06 PM   #48
stone
Tires came in today!
Unread 11-22-2010, 04:44 PM   #49
Tompatt
1987 YJ Wrangler
nice progress. cant wait to see the finished product.
Thomas
-1987 YJ
Jeep Build
Tompatt is offline   Reply With Quote Quick reply to this message
Unread 11-23-2010, 04:44 PM   #50
stone
Rock rings came in today
Unread 11-23-2010, 07:26 PM   #51
kyle_craig
Digging the tires. Can't wait to see this all together!
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 11-23-2010, 11:07 PM   #52
stone
Me either! Just ordered 3 lbs of wrinkle black powdercoat for the wheels, and anything else later on.
Unread 11-24-2010, 05:12 PM   #53
stone
Stripped one of the wheels today to see how long it would take, stripping the other 3 and sandblasting them all next week.
Unread 11-29-2010, 05:04 PM   #54
stone
Sandblasted and welded the wheels today on lunch
Unread 11-29-2010, 06:06 PM   #55
kyle_craig
Good lookin' welds!
Unread 11-29-2010, 08:25 PM   #56
RuffShod
Nice build!
What did the second set of axles come off of?
RuffShod is offline   Reply With Quote Quick reply to this message
Unread 11-29-2010, 09:08 PM   #57
stone
'78 F-250. HP D44 front and D60 rear.
Unread 11-29-2010, 09:25 PM   #58
VACJ5
good choice in axles!
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it... 3/4 Ton YJ
91 2 door Cherocar... in progress
BeachMetalWorks Custom CNC cut Jeep parts & more
VACJ5 is offline   Reply With Quote Quick reply to this message
Unread 11-29-2010, 09:34 PM   #59
VACJ5
If you run 1310 u joints in your driveshafts, you can get a 1310-1330 conversion u joint from Advance Auto... part number 10134BF. Also I got u joint u bolts at advance too... the D44 takes a slightly larger u bolt than the 60! For the 60, it is part number 10089 and you get them as a pair. The u bolt for the D44 you have to buy each and they are part number 81004. Let me know if you need any part numbers for the calipers/rotors I used on the discs for the D60.
Unread 11-29-2010, 09:37 PM   #60
stone
I already have Spicer conversion u-joints, and I also already have the u-bolts too. Also have the discs set up on the rear too, running K20 calipers. I'm going to do a line-lock style e-brake. I have almost everything I need, I was just waiting to get it together to make some front shock towers and measure for my shocks and brake lines. What MC are you using?
