Stone's '93 YJ Build - Page 10 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Stone's '93 YJ Build
Savvy/Currie Aluminum Control ArmsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAlloy usa heavy duty ball joint kits
Unread 09-10-2012, 04:56 PM   #136
stone
stone is offline   Reply With Quote Quick reply to this message
Unread 09-10-2012, 04:58 PM   #137
stone
Originally Posted by 1of625 View Post
Great Looking YJ,,,mine will be like your soon except i'm going with 8.8 in the rear.
I also have a 2000 Z28 M6 with your employer's tubular turbo K-Member.
Can't wait to see it finished.
I have owned 3 f-bodies before I got the Jeep, they're a lot of fun too.
Unread 08-25-2013, 05:46 PM   #138
stone
Ok so I haven't posted much and this thread is old, but the Jeep is finally running and driving. The fuel pump strainer melted from the fuel sitting in the tank, so we put a new fuel pump and strainer in. I cut down and welded a front XJ driveshaft for the rear, put all new u-bolts and u-bolt plates from ruffstuff, plumbed the master cylinder and front and rear brakes. Next weekend we'll bust out the welder and weld up the MORE shockmounts and weld shock mounts on the axles and I'll start driving the jeep every few days to work out any bugs from it sitting for so long. Then I'll build a traction bar for the rear and it's time to start wheelin it!
Measuring for shocks
Unread 08-26-2013, 06:23 PM   #139
tractor1
tractor1's Avatar
1979 CJ5
Nice flex. Is the front going to rub?
1979 CJ5 304 T150 Dana 20 under construction
1993 Wrangler 4.0 HO AX15 231 4” lift 33 12.5 15 DD
1994 Wrangler 2.5 AX5 231 Stock Sold
1973 Cj5 304 T15 Dana20 Sold
tractor1 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 07:48 PM   #140
stone
It just barely rubs in the front, but I'm going to bumpstop it so it won't. In the picture the rear is actually touching the tub, I'm going to cut the rear to a TJ size opening
Unread 08-27-2013, 08:18 PM   #141
stone
My buddy Danny welding up the shock mounts on the rear. He's been a huge part of this build, it wouldn't be where it is today without his help.
Unread 08-29-2013, 08:52 PM   #142
stone
Took it for the maiden voyage today, and it went pretty well. I got it up to around 50 mph and had no vibrations or wobble, which is amazing. Being that I welded the rock rings on the wheels and I didn't get them balanced, and I didn't get the rear driveshaft balanced after I cut and welded it. Our eyeball alignment was good enough to take my hand off the wheel and the Jeep stayed straight. The rear pinion seal is leaking pretty bad and the brakes need bled better, both of which I'm going to do tomorrow after work.
Unread 08-29-2013, 09:41 PM   #143
88hatchy
Looks good! What shocks are you running?
1997 TJ - Current project: Simple build --> LCG, 35s
1988 Civic Hatch - Runs 12's, gets 30 mpg
88hatchy is offline   Reply With Quote Quick reply to this message
Unread 08-29-2013, 10:21 PM   #144
stone
At the moment, some stock F250 take offs. They happened to be the correct length, I'm going to order some Bilsteins soon
Unread 02-08-2014, 11:23 PM   #145
stone
Bringing this back up due to this build actually moving along well now. The rear end that I had in it was in pretty bad shape, so I picked up a new one. Got it all set up and put in. It's open diff right now, but I'll be putting an ox locker in it when I have the money.
The jeep drives great. I have had it up to 75 mph with no vibrations or issues, which is crazy since the tires aren't balanced and neither is the driveshaft. Now that I have been putting some miles on it, it's time to get everything else done.
Also got plates formed for rock sliders and a rear crossmember, or start of the rear bumper.
Also picked up a Trail Worthy Fab 12" LED light bar
Unread 02-09-2014, 01:25 AM   #146
mike_breaker_5
mike_breaker_5's Avatar
lesson learned: be glad you live in Florida running those military oz tires. they are the worst cold weather tire on the planet hands down.
Ratmonkey donation page. all proceeds will go to his family.
http://www.youcaring.com/memorial-fu..._source=widget
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
http://www.jeepforum.com/forum/f22/m...r-junk-990191/
mike_breaker_5 is offline   Reply With Quote Quick reply to this message
Unread 02-15-2014, 11:54 PM   #147
stone
Got some more TWF leds, two 6" bars for the rear. Also ordered 120ft of 1.75 x .120 DOM...
Unread 02-23-2014, 10:57 AM   #148
stone
Got some rear tube flares for a TJ, and opened them up more to clear the 37s, and 4" LED taillights.
Almost fits in my garage with the top on! It'll fit with no top which is when it really matters.
Unread 02-25-2014, 09:43 PM   #149
stone
A little forklift flex at work
Unread 03-04-2014, 04:19 PM   #150
stone
