starting a 4.3 swap - Page 9 - JeepForum.com
post #121 of 131 Old 02-25-2013, 02:03 PM Thread Starter
Dre40
When I had my ECM reprogrammed he changed two outputs to control the fans at diff temps. I don't think the ECM comes standard with an electric fan control because most 4.3 used a regular fan.
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #122 of 131 Old 02-26-2013, 07:00 AM
captainauti
yea, my computer and harness was redone as well. one output was for a fan. are you running electric fan solely? what tstat are you running? i have a 160* and a standard mechanical fan. want to go to a 180* and electric, the low coolant temp code keeps popping up. i didnt have a cooling issue, just like engines running cool. thats the marine tech in me. also what radiator? mines a stock 4.0. just looking for more info... thanx again.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #123 of 131 Old 02-26-2013, 07:11 AM Thread Starter
Dre40
Yes I'm running electric fans solely a high and low. I'm running the stock thermostat I think its a 180 but not 100% sure. The radiator I have is a 4 core I had made by BTR radiator its was for a CJ7 but fits very nicely.
Dre40 is offline
post #124 of 131 Old 05-26-2013, 05:12 PM Thread Starter
Dre40
Well I found one draw back to this swap I did!! Way to much horsepower and torque I keep braking u-joints on the front D30. . But it's a lot of fun 8-).
Dre40 is offline
post #125 of 131 Old 05-26-2013, 05:21 PM Thread Starter
Dre40
Here's a pic three times it's time too look for a different axle.
Dre40 is offline
post #126 of 131 Old 02-18-2014, 01:57 PM
AbAngler
Just got mine on the road a few weeks ago. Other then a pesky oil leak from the oil filter adapter (added an oil cooler) and a faulty fan controller, its fricken awesome! Wiring was a bit of an issue since I had to fire the guy I hired to finish it up. Wiring is not my forte.
One time saving thing I did was get a GPS adapter to the electronic Autometer speedo. http://www.autometer.com/cat_accesso...l.aspx?vid=234
The Astro van headers and exhaust turned out really nice with the ceramic coating. I'll have to update my thread with some pics.
Next on the list is skid plates and mounting the track bar. I can only get to about 90km/h (55m/h) before death wobble, so track bar is a must.
My build in progress
http://www.jeepforum.com/forum/f22/89-yj-4-3l-bunch-other-stuff-build-1171991/
AbAngler is offline
post #127 of 131 Old 02-18-2014, 02:37 PM
AbAngler
Originally Posted by captainauti View Post
did you need the shallow pan? i have the pan in your picture and its not low at all.
Update here... Found a shallow pan off a 2wd S-10 at the wreckers. The key is 2wd, all the 4wd S-10s had the deep ones. Had to modify the pickup a bit, but it works.
AbAngler is offline
post #128 of 131 Old 02-18-2014, 06:57 PM Thread Starter
Dre40
I didn't know they made a shallow pan but i don't have a problem with it in my build. Here's a few updated pics. I got a D44 in her now with Hydro assist.
Dre40 is offline
post #129 of 131 Old 02-19-2014, 08:45 AM
AbAngler
Very nice! I haven't wheeled hard enough to break anything yet, but I definitely know my D30 is the weak point in my build. With all the work I've put into it, I'd probably go with chromoly shafts and u joints rather then a new diff.
AbAngler is offline
post #130 of 131 Old 04-14-2014, 10:51 AM
AbAngler
Hows the mileage? My first tank of gas sucked. Hoping it gets better as the motor breaks in.
AbAngler is offline
post #131 of 131 Old 04-19-2014, 03:48 PM Thread Starter
Dre40
I get around 15MPG with my 4.3 swap. I love it so far.
Dre40 is offline
Help Jeep Not Starting After I Did Throttle Body Swap countryboy15 YJ Wrangler Technical Forum 4 01-31-2010 05:19 AM
starting 350 swap... couple questions. nelly97tj YJ Wrangler Technical Forum 11 01-16-2010 07:48 PM
need info for gear swap, starting point johnny9 TJ Wrangler Technical Forum 1 09-13-2009 10:37 AM
starting the 4.0 swap this weekend mtn_wrangler YJ Wrangler Technical Forum 8 06-06-2008 11:21 AM
Not starting after p/s pump swap 92wrangler YJ Wrangler Technical Forum 2 01-09-2007 03:25 PM
