starting a 4.3 swap - Page 7 - JeepForum.com
post #91 of 131 Old 12-15-2012, 12:18 PM
YJames90
YJames90's Avatar
With my luck the manifold bolts would snap off
My 2.5 to 4.3 swap thread
YJames90 is offline
post #92 of 131 Old 12-15-2012, 04:24 PM Thread Starter
Dre40
Originally Posted by captainauti View Post
dre40, i think i asked before, you put headers on correct? how was the fit?
i have stock manifolds and was thinking of adding headers. ill have the nose off this winter doing a cj clip swap, and would be a great time to upgrade.
what kind did you use?
I got a set off of Ebay
http://www.ebay.com/itm/OBX-Performa...2a5fd7&vxp=mtr
but the problem I had was #1 header pipe was to close to the spark plug and would burn it causing a miss fire. so that's why I took it off and reworked it. not sure but looks like they might have fixed the problem.
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #93 of 131 Old 12-16-2012, 10:15 AM
captainauti
when you say reworked....alil heat and a pursuader? giving more room?
i would prob wrap mine when installing them with marine exhaust wrap.
and as for snapping off, im running a 160 degree t-stat so it runs cold, and we have a trick in the marine field for keeping bolts from freezing in in high heat areas.
we use PTFE grease on all bolts
what are you two running for rear drive shafts?
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #94 of 131 Old 12-16-2012, 10:34 AM
YJames90
YJames90's Avatar
Grand cherokee front shaft cut down to size.
YJames90 is offline
post #95 of 131 Old 12-16-2012, 10:38 AM
captainauti
are the the same as a xj shaft?
i have a advanced adapters SYE in the garage waiting for install, just need a shaft.
Capt. Nate
aka Scallywag
post #96 of 131 Old 12-16-2012, 10:43 AM
YJames90
YJames90's Avatar
I believe so
YJames90 is offline
post #97 of 131 Old 12-16-2012, 04:21 PM Thread Starter
Dre40
Yes I'm running the XJ shaft in the rear and a modified stock front shaft. as far as the header I cut off #1 from the header flange and extended it with new header pipe I got from Summit racing rewelded it up and checked it for leaks. I also rapped the header with high temp racing header rap.
Dre40 is offline
post #98 of 131 Old 12-21-2012, 09:44 AM
captainauti
found an xj shaft and a window for a friend for $40. found my next project
Capt. Nate
aka Scallywag
post #99 of 131 Old 01-03-2013, 08:06 PM
AbAngler
Haven't been on in a while but it sure looks good!
My swap has been coming along slowly. I bought those same headers and had the same issue. Ended up going with some off an astro van which will be ceramic coated. Only slight modification...
Same rad too but used an electric fan off and escort. Had my friend build a bracket to fit.
I found a shallower oil pan from a 2wd S10. I'll have to upload some pics off my phone with it in the Jeep.
My build in progress
http://www.jeepforum.com/forum/f22/89-yj-4-3l-bunch-other-stuff-build-1171991/
AbAngler is offline
post #100 of 131 Old 01-04-2013, 06:49 AM
captainauti
did you need the shallow pan? i have the pan in your picture and its not low at all.
Capt. Nate
aka Scallywag
post #101 of 131 Old 01-04-2013, 10:06 AM
AbAngler
I didnt need it, but wanted it. We've managed to tuck everything up there pretty good. I'm finishing off the front axle tomorrow, so I'll take some more detailed pics.
You can kind of see it here.
AbAngler is offline
post #102 of 131 Old 01-04-2013, 11:46 AM
captainauti
looks good.i made a flat bracket and installed a york where the ac pump goes. you are gonna love the setup.
looks like mine, but im an auto.
Capt. Nate
aka Scallywag
post #103 of 131 Old 01-04-2013, 01:17 PM
AbAngler
That was the original plan, but I ended up with a compressor.
AbAngler is offline
post #104 of 131 Old 01-04-2013, 02:51 PM Thread Starter
Dre40
Looks very nice. I added a compressor to my bracket as well had to modify it a bit but it works.
Dre40 is offline
post #105 of 131 Old 01-05-2013, 10:51 AM
captainauti
dre, do you only have an electric fan? i have the stock gm fan and was thinking of going electric. no cooling issues, just a thought.
Capt. Nate
aka Scallywag
Help Jeep Not Starting After I Did Throttle Body Swap countryboy15 YJ Wrangler Technical Forum 4 01-31-2010 05:19 AM
starting 350 swap... couple questions. nelly97tj YJ Wrangler Technical Forum 11 01-16-2010 07:48 PM
need info for gear swap, starting point johnny9 TJ Wrangler Technical Forum 1 09-13-2009 10:37 AM
starting the 4.0 swap this weekend mtn_wrangler YJ Wrangler Technical Forum 8 06-06-2008 11:21 AM
Not starting after p/s pump swap 92wrangler YJ Wrangler Technical Forum 2 01-09-2007 03:25 PM
