starting a 4.3 swap - Page 5 - JeepForum.com
post #61 of 131 Old 02-22-2011, 08:35 AM
AbAngler
Looks great! I'm ordering up those same headers today. We got the motor out of the Jimmy last weekend. What a pain in the a55! Also thinking about going with the same rad.
I notice your air intake goes to the passenger side, was this stock? The one off the Jimmy I am using goes to the drivers side, so I'm taking one off an newer 5.7l that goes to the passenger side. I am building a snorkel and didn't want it coming up the drivers side.
AbAngler is offline
post #62 of 131 Old 02-22-2011, 09:11 AM Thread Starter
Dre40
yes my engine came out of an 01 Chevy 1500 and thats how the air intake was. i cut some off and modified it a little bit.
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #63 of 131 Old 02-22-2011, 10:09 AM
AbAngler
Makes sense. Thanks!
Did yours have that "honeycomb" filter? Seems pretty restrictive, so I cut it out....
AbAngler is offline
post #64 of 131 Old 02-22-2011, 10:16 AM Thread Starter
Dre40
what filter you talking about? the only other thing in line is the Mass airflow sensor and you need that for the engine to run right.
Dre40 is offline
post #65 of 131 Old 02-22-2011, 10:24 AM
AbAngler
There is a honeycomb filter on the inside the air intake assembly that came off the Jimmy. it was before the MAS. We could see so real use for it, so I cut it out. Maybe different on yours.
AbAngler is offline
post #66 of 131 Old 02-22-2011, 10:52 AM Thread Starter
Dre40
no i only had the MAS which if you look into it it does have a honey comb element inside. did the item you cut up have wires going to it?
Dre40 is offline
post #67 of 131 Old 02-22-2011, 11:40 AM
AbAngler
Pretty sure that would be it... My buddy who is a mechanic has been helping me. He's done it before on other motors and they ran fine from what he says... Hope I didn't f it up!
AbAngler is offline
post #68 of 131 Old 02-22-2011, 12:26 PM Thread Starter
Dre40
you might have. the MAS is a very sensitive sensor it could be damaged from just dropping it.
Dre40 is offline
post #69 of 131 Old 02-22-2011, 12:46 PM
AbAngler
Well, I just spent the last hour reading into it and it seems lots of people are removing it on the Jimmy/Chevy/S10 forums. Some say they get noticeable power gains, some say they don't notice a difference. Either way it doesn't seem to mess anything up. They do however recommend NOT doing it if you are using a tuner.
Good to know, I was a little concerned there!
AbAngler is offline
post #70 of 131 Old 03-03-2011, 08:28 PM Thread Starter
Dre40
Well its all back together and driving it every day. now I did some changes removed the restrictive baffle plate on the throttle body. that seemed to help with throttle response greatly. I was going to mess with the MAF but was told to leave it alone because if you remove the screen from the MAF you will have to recalibrate it with the ECM and I don't have that kind of software. one thing I did make a mistake on was I reused the CSFI spider injector when I rebuilt the engine. well I think I got a leaky injector because it running rich and I'm only getting 10MPG and it should be allot better then that. now there is an updated spider CSFI that replaces it with an MFI and moves the electronic injectors down to the injector head. so I might have to go that route.
Dre40 is offline
post #71 of 131 Old 03-18-2011, 09:08 PM
SnowdogMarc
Looks good...I'm going to be starting this swap soon in mine I think
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #72 of 131 Old 03-20-2011, 07:30 AM
captainauti
i changed the spiders in mine and what a difference. whats the plate you took out of the intake?
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #73 of 131 Old 03-20-2011, 08:13 AM Thread Starter
Dre40
Its a Baffle plate under the Throttle plate. it improves acceleration. where did you get the new spider from? and what you pay for it? I haven't done that yet waiting for some extra $$ lol
Dre40 is offline
post #74 of 131 Old 03-20-2011, 04:32 PM
captainauti
got mine from napa, like 175.
Capt. Nate
aka Scallywag
post #75 of 131 Old 03-20-2011, 07:29 PM Thread Starter
Dre40
Do you happen to know what the NAPA part # is? and is it the New Style?
Dre40 is offline
Help Jeep Not Starting After I Did Throttle Body Swap countryboy15 YJ Wrangler Technical Forum 4 01-31-2010 05:19 AM
starting 350 swap... couple questions. nelly97tj YJ Wrangler Technical Forum 11 01-16-2010 07:48 PM
need info for gear swap, starting point johnny9 TJ Wrangler Technical Forum 1 09-13-2009 10:37 AM
starting the 4.0 swap this weekend mtn_wrangler YJ Wrangler Technical Forum 8 06-06-2008 11:21 AM
Not starting after p/s pump swap 92wrangler YJ Wrangler Technical Forum 2 01-09-2007 03:25 PM
