starting a 4.3 swap - Page 3 - JeepForum.com
post #31 of 131 Old 01-18-2011, 06:56 AM
captainauti
Def wouldn't worry bout that. Where is your tcase in relation to where it was before? What trans and tcase set up r u using?
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #32 of 131 Old 01-18-2011, 07:26 AM Thread Starter
Dre40
it is an SM-465 and a NP-241 with a shorty SYE and it is actually shorter then the stock set up. i installed the engine about 4" forward of the original 2.5 mounts.
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #33 of 131 Old 01-18-2011, 11:21 AM Thread Starter
Dre40
OK so I got this fuel pump from the junk yard the guy tells me it out of an 96 4.3l c1500.. how could I test this pump to make sure it puts out the right pressure before I install it into the tank any ideas??
Dre40 is offline
post #34 of 131 Old 01-18-2011, 04:40 PM
captainauti
put it in the tank, but dont mount the tank back up and try it against your fuel system to see if it builds psi?
Capt. Nate
aka Scallywag
post #35 of 131 Old 01-18-2011, 05:34 PM Thread Starter
Dre40
That's what I decided to do. Now the pump that's in the tank is a bosch is that normal? Also I worried about hose clamp fittings with 62+ psi I wonder if it's going to leak?
Dre40 is offline
post #36 of 131 Old 01-18-2011, 08:16 PM Thread Starter
Dre40
Got some more work done today. got the pull type slave cylinder for the clutch had to fab a bracket for it but its all installed. also started to clean up the Ford 8.8 to install it tomorrow. I decided to do this swap at the same time because I have to have a drive shaft maid. I'm using a CV style out of an XJ so why not.. I also dropped the fuel tank to adapt the Pump.
Dre40 is offline
post #37 of 131 Old 01-19-2011, 12:41 PM Thread Starter
Dre40
OK so I'm faced with an dilemma what fuel pump to use? Ive done allot of research and I'm getting conflicting reports. some say if you have a 92 or so 2.5L MPI the pump will work and deliver the said 62 psi. now there reports that say different. now the other obstacle to cross is fuel lines. I don't want to rely on hose clamp fitting with 62 psi in them what has anyone done here? I thought about going down to the you pull and see if i can grab some lines out of a blazer or van and maybe scoring the pump as well..
Any thoughts???
Dre40 is offline
post #38 of 131 Old 01-19-2011, 12:59 PM
TXvodoo
1987 YJ Wrangler
I've used braided line with AN fitings for turbo applications before, just an idea if you want to spend the $$$ for it.
TXvodoo is offline
post #39 of 131 Old 01-20-2011, 05:31 PM
captainauti
i used SS pex water line crimps inside my fuel tank, and used a fuel pump from a 3500 pickup. the stock pump wont deliver what you need. ask me how i know. i just swapped the pumps in the tank and been great ever since.
Capt. Nate
aka Scallywag
post #40 of 131 Old 01-20-2011, 05:38 PM Thread Starter
Dre40
Lol I keep getting conflicting reports on that. I got a pump from jk it's out of an 96 with a 4.3 but I'm sceptical on it too so I'm going to leave the tank down till I try to fire it up and see what works .. Lol got the Ford 8.8 installed ..
Dre40 is offline
post #41 of 131 Old 01-20-2011, 05:40 PM
captainauti
what did you use for an installation kit on the 8.8... i have mine here for a project, but havent started it
Capt. Nate
aka Scallywag
post #42 of 131 Old 01-20-2011, 06:41 PM Thread Starter
Dre40
I ordered a kit from A to Z fabrication the kit included the pads U bolts plates and shock mounts for 119$ it was kinda funny I ordered it thinkin there on the east coast so I would get the quacker but know it's being stoped shipped from CA lol..
Dre40 is offline
post #43 of 131 Old 01-20-2011, 07:45 PM
Drakeslayer
Slave cyl?
I like the looks of that slave cyl. would have solved my exhaust routing issues with alot less stress and $$$. Where did you get it and what brand is it?
Drakeslayer is offline
post #44 of 131 Old 01-20-2011, 07:50 PM
Drakeslayer
fuel pump
By the way, I used the stock 95 YJ in tank pump to supply my 92 4.3 TBI. The YJ had the 4 cyl with factory fuel injection. I just adapted the fuel lines to the tubes that are attached to the TBI unit. It has worked for 14 months with no issues. The 92 TBI unit has a built in pressure regulator and returns excess fuel to the tank via original jeep return line.
post #45 of 131 Old 01-20-2011, 08:12 PM Thread Starter
Dre40
http://www.speedwaymotors.com/Univer...-Inch,783.html
I got the slave cylinder from here.I figured it was the best option with the set up I have. well I got some Dorman 800151 and 800153 fittings from Napa they have the GM fittings on one end and a union on the other. as far as the pump Im not sure yet. I might go to the you pull tomorrow and see if I could score a pump out of something..
Dre40 is offline
Help Jeep Not Starting After I Did Throttle Body Swap countryboy15 YJ Wrangler Technical Forum 4 01-31-2010 05:19 AM
starting 350 swap... couple questions. nelly97tj YJ Wrangler Technical Forum 11 01-16-2010 07:48 PM
need info for gear swap, starting point johnny9 TJ Wrangler Technical Forum 1 09-13-2009 10:37 AM
starting the 4.0 swap this weekend mtn_wrangler YJ Wrangler Technical Forum 8 06-06-2008 11:21 AM
Not starting after p/s pump swap 92wrangler YJ Wrangler Technical Forum 2 01-09-2007 03:25 PM
