starting a 4.3 swap - Page 2 - JeepForum.com
post #16 of 131 Old 12-21-2010, 08:13 PM
captainauti
same clamps used on the stock setup.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #17 of 131 Old 12-26-2010, 10:11 AM Thread Starter
Dre40
Does anyone have some Pics of a 4.3L in a Yj they are willing to share ?
thanks..
Dre40 is offline
post #18 of 131 Old 12-26-2010, 10:54 PM
Drakeslayer
I have an sm420 trans, used chev pressure plate that matched eng, donor and disc from 60s era trans to match input spline. Mounted standard 1500 chev PU slave cyl with fabbed bracket. Used same location of trans and transfer case as front and aft spacing of eng. worked well, no changes to drivelines, already had SYE. Exhaust interfered with slave cyl so used manifold from full size van for more forward dump, then routed front of oilpan to pass side. Custom header may be in future as driveline still rubs, will consult exhaust professional before going furthur with exhaust. Lincoln electric fan.
By the way where did you get your ECM reprogrammed?
Drakeslayer is offline
post #19 of 131 Old 01-04-2011, 08:17 PM Thread Starter
Dre40
An update. the drive train is all ready to go in getting ready to start the swap..
Dre40 is offline
post #20 of 131 Old 01-06-2011, 01:12 PM
captainauti
http://www.jeepforum.com/forum/f12/f...pleted-970585/
there is a link to my engine swap pretty bad pics, but you get the idea.
are those headers set to fit the stock exhaust y pipe? who makes em and how much were they if you dont mind me asking?
Capt. Nate
aka Scallywag
post #21 of 131 Old 01-06-2011, 02:50 PM Thread Starter
Dre40
OBX makes them and 199$ on eBay and I think they are for factory Y pipe
Dre40 is offline
post #22 of 131 Old 01-06-2011, 07:22 PM
captainauti
hmmm..... maybe an upgrade is in order.
Capt. Nate
aka Scallywag
post #23 of 131 Old 01-11-2011, 08:07 PM Thread Starter
Dre40
hay what did you do about a fuel filter? did you upgrade the stock one or just use it?
Dre40 is offline
post #24 of 131 Old 01-12-2011, 09:13 AM
captainauti
Used stock one.
Capt. Nate
aka Scallywag
post #25 of 131 Old 01-16-2011, 07:23 PM Thread Starter
Dre40
So i started working on the swap this weekend was able to remove the tired 2.5L. now to get the Engine bay ready for the New 4.3L
Dre40 is offline
post #26 of 131 Old 01-16-2011, 08:03 PM Thread Starter
Dre40
So now to start figuring out all the wiring mess..lol
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #27 of 131 Old 01-17-2011, 07:08 PM Thread Starter
Dre40
So I made some progress today and got the engine temporarily in and motor mounts welded in. Now i noticed the I was off by an 1/8" from front to drivers side motor mount. Do you think that will matter at all?
Dre40 is offline
post #28 of 131 Old 01-17-2011, 08:36 PM
ozacustoms
1997 XJ Cherokee
I have put lots of engines where they don't belong. Being off by an 1/8" up front can be a good thing at the transfer case / pinion shaft alignment. Check it and see where your at, you may be pleased. I will be reading this daily, it is the swap I am considering for a newly acquired YJ. By the way your engine / tranny combo looks real good...Real Good!! I have heard yellow engines create 10 more ponys than any other color !!
ozacustoms is offline
post #29 of 131 Old 01-18-2011, 05:50 AM
captainauti
Looking good, not sure what you mean by 1/8" off.
Capt. Nate
aka Scallywag
post #30 of 131 Old 01-18-2011, 06:21 AM Thread Starter
Dre40
when i measured from the front bumper to the new motor mount it was 1/8" closer on the drivers side. i don't think it will matter..
Dre40 is offline
Help Jeep Not Starting After I Did Throttle Body Swap countryboy15 YJ Wrangler Technical Forum 4 01-31-2010 05:19 AM
starting 350 swap... couple questions. nelly97tj YJ Wrangler Technical Forum 11 01-16-2010 07:48 PM
need info for gear swap, starting point johnny9 TJ Wrangler Technical Forum 1 09-13-2009 10:37 AM
starting the 4.0 swap this weekend mtn_wrangler YJ Wrangler Technical Forum 8 06-06-2008 11:21 AM
Not starting after p/s pump swap 92wrangler YJ Wrangler Technical Forum 2 01-09-2007 03:25 PM
