stanton3's build-wk - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > stanton3's build-wk
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-09-2011, 05:58 PM   #16
stanton3
2007 WK
Posted this is in the wk section but figured id post it here too.
I cut my front bumper today here are some pics...
It isn't too drastic, but I like the way it came out. Gives it a more aggressive stance and alot better ground clearance. I might eventually cut more off, but I didn't want to go too crazy the first time!
BEFORE:
AFTER:
Still need to go over everything with undercoating, but I think it turned out good!
2007 WK 4x4 | OME HD 3" Lift | OME Shocks front + rear | 265/70/17 BFG All Terrains | 1.25" Wheel Spacers on stock wheels | Saguaro4xcomponents 5/8" Front recovery shackles | Aries Taillight Guards | PIAA 510 fogs in stock location | Midland 1001z Cb | Mopar Rear recovery hook | Rola Roof Rack |2 Hella 500ffs mounted behind grill | Firestick 3' Antenna | Saguaro Antenna Mount | Front Bumper Cut/Fender Trim | OEM Front suspension skid | 4xguard Front skid | Rusty's .5" Front Spacer | Lots more to come
[SIZE="3"]Want to buy: 4xguard Rear Guard[/SIZE]
[SIZE="3"][URL="http://www.jeepforum.com/forum/f22/stanton3s-build-wk-1134656/"]My Build[/URL][/SIZE]
[B][COLOR="Gray"]
[SIZE="3"][URL="http://wrjeepclub.com/"]Warner Robins Jeep Club[/URL][/SIZE][/COLOR][/B]
stanton3 is offline   Reply With Quote Quick reply to this message
Unread 07-09-2011, 06:10 PM   #17
stanton3
2007 WK
Originally Posted by cloiselle View Post
Hey are you hitting your pinch weld up front with your lift / tire combo at all?
Not all the time. Every once in a while it will barely hit. It hits pretty bad offroad when it flexes and the wheel is turned though. After cutting my front bumper my rubbing on the street has gone away for the most part.
Pinch weld will probably be the next mod to fit 33's.
Originally Posted by bumzo1 View Post
Nice Jeep! ours are pretty similar, I even noticed you did the little zip tie thing with your front shackles. You said it only took you 6 hours to install your OME by yourself?!? I hate you. It took me and my dad twice as long to install mine :/
Thanks man! Yea those zip ties have been gone for a long time!
Yea front was the only part that took any time, the rear was simple!
[B][COLOR="Gray"]
Unread 08-10-2011, 04:46 PM   #18
stanton3
2007 WK
Just a couple quick mods.
Got my cb and antenna all finished up:
And replaced my crappy plastic guard that it came with with a steel front suspension skid. Much better than the plastic!
Have another skid that shipped today that should be here sometime next week along with a few other things! *
[B][COLOR="Gray"]
Unread 08-19-2011, 12:46 AM   #19
drewfus53
nice jeep man, What 4x4 system do you have QD, QT I or QD II? And how well does it work for you?
drewfus53 is offline   Reply With Quote Quick reply to this message
Unread 09-12-2011, 09:42 PM   #20
0321Nick
2006 WK
How hard was switching out the fog lamps to the PIAAs? Were you able to wire them into the stock Fog switch on the steering wheel?
KHAKI CLUB #65
2006 WK 4.7L V8 - Modified OME HD with Bilstein 5125s (28" length); JBA UCA; JKS Rear Discos; K&N CAI; PowerStop Discs; HyperTech; TOYO Open Country AT IIs 285/70/17; + some other goodies
0321Nick is offline   Reply With Quote Quick reply to this message
Unread 09-28-2011, 01:53 AM   #21
WKChris89
2006 WK
wk looks awsome man. where did u order ur steel skids from?? i ripped my plastic stock ones off and def. need something more sturdy.
WKChris89 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2011, 09:19 AM   #22
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Originally Posted by stanton3 View Post
Do you need a skid plate of beef-ier cross member to protect the radiator?
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 09-28-2011, 03:17 PM   #23
stanton3
2007 WK
Sorry guys, sorta forgot about this thread. I forgot to update it but here are some updated pics. Bad pics sorry
Added a 4xguard front skid to protect the radiator:
[B][COLOR="Gray"]
Unread 09-28-2011, 03:20 PM   #24
stanton3
2007 WK
Also installed a .5" rusty spacer in the front.
[B][COLOR="Gray"]
Unread 09-28-2011, 03:27 PM   #25
stanton3
2007 WK
http://www.justforjeeps.com/skidplates7.html
There's a link to the mopar front suspension skid. To get the tcase skid to mount you also need the fuel tank skid.
Updated pics, added a skid plate for the front.
[B][COLOR="Gray"]
Unread 01-26-2012, 07:39 PM   #26
Black1998ZJ
Your WK looks awesome.
Black '98 ZJ: 4.0L 2" Rusty's BB, painted Canyons black, 31x10.50r15 Goodyear Wrangler Authority, Rusty's front Tow Hooks.
*slow* build thread - http://www.jeepforum.com/forum/f22/budget-zj-build-1283495/
Black1998ZJ is offline   Reply With Quote Quick reply to this message
Unread 02-26-2013, 10:06 AM   #27
NJFirefighter
2005 WK
Fog Light Install
how'd you do the fog light install? i'm really interested in how you mounted them. i'm weary about cutting into anything.
NJFirefighter is offline   Reply With Quote Quick reply to this message
Unread 09-04-2013, 04:29 PM   #28
tfreezy
2006 WK
I like what you did with the front bumper. How much do you think it improved your approach angles?
tfreezy is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 01:07 PM   #29
iamme1892
I am new to this forum but I would like to document my build, I have just ordered a 7.2l 440 ci w/magnusson supercharger to install in my 05 grand cherokee. My truck does not carry the srt badges but that is mostly the point...It goes in monday to have the beast installed . I currently have a 5.5 inch lift with 35 inch tires and By summer this year I hope to have this truck in show shape
iamme1892 is offline   Reply With Quote Quick reply to this message
