sskilla's build thread - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > sskilla's build thread
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 08-22-2012, 12:15 AM   #16
sskilla
sskilla's Avatar
looks like I gave a sneak peak of the IRO double sheer adjustable front track bar in the JKS pic, so here it is!
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline   Reply With Quote Quick reply to this message
Unread 08-26-2012, 08:23 PM   #17
sskilla
sskilla's Avatar
so this guy showed up. Hughes Engines plenum plate kit. Should fix that oil in the intake issue some of us struggle with. Also it came with a new bypass hose which is good because I think mine is leaking.
plus pulled and begain work on these future swaps
231, u-joint axle shafts and a u-joint front DS!
Unread 08-26-2012, 08:26 PM   #18
sskilla
sskilla's Avatar
been awhile since ive been wheelin, so i had to improvise. found a dirt hill on a jobsite to roll over on my way home from work lol
you can also see in this pic my KOR Radiator support
i guess i never took a pic but somewhere along the lines i replaced my 3" BB with the F > R swap usng IRO front springs on a 1.5" spacer. after sag and spacer squish im sitting at about 4" lift.
Unread 08-26-2012, 08:31 PM   #19
rubiconox
lookin cool man!
04 Rubicon in Khaki,5-speed, 33's,RE 2" coil spacer, Bestop, K&N intake (crap)...pretty much stock.
JEEP: If your question is fuel mileage, the answer is elsewhere.
rubiconox is offline   Reply With Quote Quick reply to this message
Unread 08-31-2012, 06:20 PM   #20
sskilla
sskilla's Avatar
decided id try to clean up my fender trim job only to find out my compressor is horribly inadaquate to run my 3" cut off wheel. finished with the sawzall... terrible lol. the lines are a little cleaner but still a hack job.
Unread 08-31-2012, 06:21 PM   #21
sskilla
sskilla's Avatar
Originally Posted by rubiconox View Post
lookin cool man!
oh thanks! lol i didnt think anyone was ever gonna look at this
Unread 08-31-2012, 06:31 PM   #22
sskilla
sskilla's Avatar
Continuing on the u-joint axle shaft swap... not sure how you F up a u-joint install but i managed it..
i guess some needle bearings came loose from the bearing cap and i smashed em until the cap snapped. there goes $25 bucks... time to order another 760x spicer...
some bench side pics.. i know you're riveted...
at least one came out the way it is supposed to. coated it with some rust preventor.
Unread 08-31-2012, 06:34 PM   #23
sskilla
sskilla's Avatar
this guy showed up from JB Conversions today, my brand spankin new 1.55" input shaft.
just so happens i have a 3 day weekend startin right now! haha, maybe ill tear into my 231 project and get that thing swapped
Unread 08-31-2012, 06:39 PM   #24
sskilla
sskilla's Avatar
dug up this pic of my blue LED dash lights:
Same blue LED's in the tranny and T-case bezel's too... pic to come after I get the 231 swapped.
Unread 09-01-2012, 12:00 PM   #25
sskilla
sskilla's Avatar
found these at the local JY: Yukon Chromoly rear axle shafts for my D35c
$250 brand new and I can get both for $40?? no brainer!... ok maybe $140 to $180 brand new, but still. here they are in the garage!
also cleaned up the axle shafts and 231 a bit
pinion yoke i pulled right before i stumbled on the Yukons. Cleaned it up a bit and painted it.
Unread 09-01-2012, 12:03 PM   #26
sskilla
sskilla's Avatar
the new yukon axle shafts got me thinkin though... maybe its time to start an 8.8 build. I wonder what the chromoly shafts are comparible to strength wise. D44a?? or not quite?
Unread 09-02-2012, 02:32 PM   #27
sskilla
sskilla's Avatar
popped the 1.55" input shaft and new seals into the 231. heres the case about to go back together with the, i believe, .825" shaft sittin in front
Unread 09-02-2012, 08:17 PM   #28
sskilla
sskilla's Avatar
so those yukon shafts? yeah they are different lengths for each side... what a dummy I am. I just pulled my rear apart and put it back together thinkin I couldnt use em. I guess I know what im doin in the morning. same thing i did this morning! lol
man.. all i had to do was line it up with the other shaft... dummy.
Unread 09-04-2012, 10:49 PM   #29
sskilla
sskilla's Avatar
Ok got the Yukons in.
prepped half the driveshaft for a u joint.
just need to rebuild that double cardan and its ready to go in!
Unread 09-05-2012, 08:33 PM   #30
sskilla
sskilla's Avatar
new spicer showed up today.
both shafts with the u-joints successfully installed. Shafts painted.
pass cv out, this is cake! hardest part was my damn brake calipers didnt wanna let go of the rotor... needless to say these brake pads wont last nearly as long as they were supposed to..
pass u-joint shaft in!
driver side cv out next to u-joint shaft.
u-joint shaft in!
suprisingly, neither side gave me trouble getting the hubs off. pulled right off with no effort.
