Quantcast spyder6's rubicon build - Page 5 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > spyder6's rubicon build
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 09-14-2008, 08:01 PM   #61
spyder6
Just violated my Parole
spyder6's Avatar
Originally Posted by thedirt View Post
You have to cut for 37s . Or at least be running some more bumpstop extensions to keep them out of the fenders.
cutting is different from comp cutting
i have no issues with going to tube fenders and modifying the body. i just dont want to remove most of the rear quarter panels and move the axle back. thats not my cup of tea.
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 09-16-2008, 03:17 PM   #62
spyder6
spyder6's Avatar
so i felt like my Jeep has been a real dog for a while back and i seemed to remember it being substantially quicker on its feet. i remembered that we have an adaptive computer that learns the drivers habits in the first 50 key turns. thinking back in the history this is when i had only driven it every now and then.
so i decided today that i was going to reset the ECM. i followed some instructions i found on here and i went out and did it. WOW big difference! i dont know if its a temporary effect but its like it got a good 20 or 30 more horsepower by the butt-dyno. there isnt that spot around 1600-2500 RPMS where it feels like there is no power anymore, it pulls hard all the way from idle. i wonder if taking delivery of this during the humid spring months may have screwed with the computer some how? none-the-less, wow
in other news, i made an appointment for thursday to get a 35% tint on the driver and passenger windows. Premier Ceramic Film.
that is all
USAF
Blue Crush Build
Really?
Old 09-16-2008, 03:33 PM   #63
97Jeep11
all i got to say is WOW!!!!! wish i had some money like that lol
[B][B][/B][/B][COLOR="RoyalBlue"][/COLOR][SIZE="6"][/SIZE][FONT="Comic Sans MS"][/FONT][CENTER]THE WHALE[/CENTER]
97Jeep11 is offline   Reply With Quote
Old 09-16-2008, 03:34 PM   #64
DixiesCJ3B
Where did you find out how to reset your ECM???
And pics of your jeep tinted when its done please!!!
1999 TJ Wrangler, 4 banger 5-spd
Soft-top, full doors
31" BFG AT, 3" Lift
1954 CJ3B Willys
Hurricane 4, 3-spd with Warn Overdrive, Snow-plow
NGJC# 15
Low Output 4 cylinder Jeep Club Member #166
Build Thread
Are You An Offroad Junkie
Originally Posted by MysticGringo View Post
This "Jeep thing" is like dating a really really hot chick, who is crazy! Its alot of fun, you spend too much money, your up all night ending up sweaty & greasy from it, your friends are jealous, you get admission into some sort of weird club... but it gets mad at your for no reason, throws fits seemingly randomly, has unexplained issues which it somehow solves on its own only after you try a bunch of different things (and spend a bunch of money) to solve it... and yet you can't resist getting in it every chance you can.
DixiesCJ3B is offline   Reply With Quote
Old 09-16-2008, 04:41 PM   #65
spyder6
spyder6's Avatar
i searched for computer reset in the forum
the steps are to unplug the positive terminal from the battery and ground it to something for 30+ seconds to discharge the capacitors. reset the positive terminal. place the ignition in on (dont start the engine) turn the headlights on, then turn them off and turn the ignition off and remove the key.
according to the post the computer adapts to your driving habits through 50 warm up cycles (a difference of 40* to operating temp) or 500 miles.
USAF
Blue Crush Build
Really?
Old 09-16-2008, 05:12 PM   #66
spyder6
spyder6's Avatar
none that i can find, i would imagine decreased fuel milage temporarily though
USAF
Blue Crush Build
Really?
Old 09-16-2008, 05:27 PM   #67
GDTIME
This very simple procedure will Erase the “Adaptive Memory” stored inside the TJ PCM and allow a new “Adaptive Memory” to be developed.
After performing this procedure the PCM will re-learn and store into Adaptive Memory your engines performance characteristics.
Disconnect the POSITIVE battery Terminal and touch it to ground for 30 seconds. (This is to discharge the PCM capacitors, which maintain the Adaptive Memory.
Reconnect the Battery Cable
Turn Ignition Switch to the “On” position but DO NOT start the engine
Turn Headlight “On”
Turn Headlights “Off”
Turn Ignition Key “Off”
Adaptive memory has now been flashed, or erased from the PCM.
When you start the engine it will be running off a set of pre-programmed tables that come with the PCM from the factory.
When you get the engine up to operating temperature the PCM will start to collect data for the “Adaptive Memory”.
The PCM will collect data for Adaptive Memory for the first 50 Warm-up Cycles.
Warm-up Cycle
A warm-up cycle happens when all of the following conditions exist.
Engine is running
A raise of 40F in engine temperature must occur ABOVE the engine temperature at start-up
Engine Coolant Temp must reach at least 160 F.
Once your engine has gone through 50 warm-up cycles in at least a 500-mile distance the PCM adaptive memory is set.
It WILL NOT Change unless you flash it out and start all over again.
Enjoy
WTB Tailgate for the Jeep, Any color.
Rear Seat for Sale out of my Rubi, all hardware incl. PM for info/pics
Rubicon
- (rōō'bĭ-kŏn') - A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
Project "Apocolypse": http://www.jeepforum.com/forum/f22/04-rubi-build-thread-609162/
Zombie Outbreak Response Unit #69
GDTIME is offline   Reply With Quote
Old 09-16-2008, 05:38 PM   #68
Whackmaster
Nice Jeep. I likey........
Whackmaster is offline   Reply With Quote
Old 09-16-2008, 05:42 PM   #69
spyder6
spyder6's Avatar
im considering re-doing my exhaust. i have a Magnaflow 14" on right now and while i like the sound, there isnt enough of it in my opinion. after listening to my brothers Magnapacks on his mustang they were just the right loudness for me. what do you guys think of this parts list?
http://store.summitracing.com/partdetail.asp?part=MPE-10416
http://store.summitracing.com/partdetail.asp?part=MPE-53006CA
USAF
Blue Crush Build
Really?
Old 09-16-2008, 09:24 PM   #70
JPcpa
I've got the same problem. Big flat spot in power between 1500 and 2000 rpm. 37k on the odometer. I'll give the ecm reset a shot.
You ready to sell the RE4.5 lift and upgrade to a long arm yet?
2004 LJ, Auto, Zone 3.5"/1.25"BL/MML/285 KM2s
2005 Rubicon, RE 4.5/3.5" SF, 285 KM2s sold
99 Sport, BB, BL, MML, 33s, sold
JPcpa is online now   Reply With Quote
Old 09-16-2008, 09:34 PM   #71
spyder6
spyder6's Avatar
haha no. i wont be doing a long arm for a very long time if ever. i have issues with grinding those factory brackets off
USAF
Blue Crush Build
Really?
Old 09-18-2008, 09:05 AM   #72
spyder6
spyder6's Avatar
got the tint done this morning...
its a 35% Photo-ceramic tint. walked out the door for $120. it looks great. it gets lighter as it gets darker outside, which is pretty cool. i would relate it to sunglasses. easy to see through behind it. hard to see through in-front of.
USAF
Blue Crush Build
Really?
Old 09-18-2008, 09:54 AM   #73
JEEP97TJ
Wow, that looks great!
Awesome Jeep.
Blacksburg, VA
JEEP97TJ is offline   Reply With Quote
Old 09-18-2008, 11:31 AM   #74
spyder6
spyder6's Avatar
i went and got the MDF for the sub box. ive looked all over for 5/8ths and IT IS A MYTHICAL SIZE. i went with 3/4 and im just going to change SirGCal's measurements to fit 3/4
USAF
Blue Crush Build
Really?
Old 09-18-2008, 04:38 PM   #75
spyder6
spyder6's Avatar
i started construction of my sub box today. we have no form of table to work on so i had to "southern engineer" a stable to work on.
all the pieces cut, saturday will bring construction. i need to go buy some liquid nail and some screws. and a length of speaker wire.
USAF
Blue Crush Build
Really?
Glock Forum
