Quantcast spyder6's rubicon build - Page 11 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > spyder6's rubicon build
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 10-29-2008, 08:25 PM   #151
spyder6
Just violated my Parole
spyder6's Avatar
Id love to use a 63mm Garrett Turbo, but fabrication to make it is simply not feasible, nor is the space for how id want to run it. knowing me i would mount it on the drivers side and build a completely new manifold and run a the intercooler in-front of my radiator and all that jazz.
the way i want to do it is just not feasible
Im stuck with a supercharger, which honestly, isnt that bad. especially being able to utilize Avenger's Twin Screw Auto Rotor design.
A blower is way out in the future as it is. I cant even afford to take on the motor alone right now. I spoke with Jason @ RedRock today. He told me there are some interesting things going on down at RedRock fab and they are currently coming up with flat fender plans for the JK and TJ's. I'll be getting a pair thanks
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 10-29-2008, 09:22 PM   #152
PBR
great looking rig man. VERY CLEAN!! wish mine could stay that clean!
are you goin to get the aluminum head from hesco?
PBR is offline   Reply With Quote
Old 10-29-2008, 09:23 PM   #153
spyder6
spyder6's Avatar
id hope for a test pair, but i believe that will be doubtful considering our extreme distance. I will be buying a pair when they get done. Jason told me to expect the TJ flare prototypes late spring. I believe they will be made to order, so their quality should be second to none.
Thanks
Unfortunately no, not right now. If i find the money to put a super-charger on this sucker then i'll be able to find the money for the aluminum head. Until then though, the ol' cast iron will have to suffice.
Im going to get the remainder of the stroker kit from hesco less the camshaft and hopefully the piston rods. that should bring the price down. Im going to see if Crane or COMP will make me a billet camshaft instead of a forged one. They're a bit stronger and harder than the forged ones and are less likely for breakage. Ive read several stories of people having straight 6 cams snap on them because of how long they are.
I just need to figure out what kind of cam i want! no idea!
USAF
Blue Crush Build
Really?
Old 10-29-2008, 09:28 PM   #154
PBR
Unfortunately no, not right now. If i find the money to put a super-charger on this sucker then i'll be able to find the money for the aluminum head. Until then though, the ol' cast iron will have to suffice.[/QUOTE]
Are you going to get the HO head atleast?
Old 10-29-2008, 09:32 PM   #155
PBR
are you going to get the head port and polished or even an HO head?
Old 10-29-2008, 09:37 PM   #156
spyder6
spyder6's Avatar
i was going to have the head ported and polished. I was not aware there was a head other than the Hesco aluminum that was better than mine.
USAF
Blue Crush Build
Really?
Old 10-29-2008, 09:40 PM   #157
PBR
yeah you can use the head off a older 4.0L which i have, that has bigger exhaust and intake ports. problem with the head is there is no tapped hole for the idler pulley. So i had to drill and tap the hole for my idler pulley. PITA!!!
Old 10-29-2008, 10:31 PM   #158
spyder6
spyder6's Avatar
i'll see what i can do about enlarging those ports, i gotta see if i can find the bigger valves and see if my machine guy can take care of it.
thanks for pointing that out.
USAF
Blue Crush Build
Really?
Old 10-29-2008, 10:33 PM   #159
PBR
no problem man.
Old 10-29-2008, 10:39 PM   #160
PBR
Originally Posted by thedirt View Post
Are you sure? I'm under the impression that the 4.0L head is the HO head. Do you have any comparison photos or references?
no but im pretty sure cuz when i took my 4.0L out and looked at the exhaust ports they were alot smaller than the one on my stroker.
Old 10-29-2008, 11:00 PM   #161
spyder6
spyder6's Avatar
I looked into every corner and crevice of Hesco's website and there is nothing in there about oversized valves. I'll have to call bennie.
I too, was under the impression that the 4.0 was the HO
USAF
Blue Crush Build
Really?
Old 11-06-2008, 03:50 PM   #162
spyder6
spyder6's Avatar
Well, this afternoon i decided that i was going to rip open my fog lights and remove the baffle that is on the inside. Im very pleased with the mod, the luminosity of the lights has doubled. I did a step by step for those who want to do this too if your curious about how it works and the results. As a disclaimer, those of you who come into my thread with intentions of saying how this is a stupid mod and i'll be blinding people and there is a reason they're called fog lights; You can leave now. The state of KY allows 4 lights in addition to the main headlamps to be in operation on vehicle with no specified beam pattern and a limit of 55watts. So now i have 2 driving lights with dispersion pattern lenses instead of 2 fog lights
so, let the show begin!
Start by undoing the 3 screws on the back of the fog light, its a T-20 torx
Opened
disconnect the ground from the shroud and pull back the retainer and remove the bulb and set aside
there are 3 metal tabs that are holding the retainer in place, bend them straight up and then you can remove the retainer
this is the blasted baffle
you can see parts of the shroud folded over onto the baffle to keep it in place. simply bend them back if you want a clean job, or hack the baffle off
end product
reconnect everything and reassemble the unit minus the baffle. here is comparatively. as you can tell, there isnt any excessive glare getting into the camera lense. the beam pattern HAS NOT CHANGED its just twice as bright
all lit up (IPF's + Fatboys + modded fogs)
i will try to get a picture tonight when its dark out for those of you who care!
USAF
Blue Crush Build
Really?
Old 11-06-2008, 04:11 PM   #163
Tompatt
1987 YJ Wrangler
nice. i care. LOL
Thomas
-1987 YJ
Jeep Build
Tompatt is offline   Reply With Quote
Old 11-06-2008, 07:14 PM   #164
Tompatt
1987 YJ Wrangler
lookin good.
Thomas
-1987 YJ
Jeep Build
Old 11-06-2008, 07:16 PM   #165
Camo Deere
Neat little mod, that's a lot of light.
Camo Deere is offline   Reply With Quote
Glock Forum
