Speedbuckets ZJ build - Page 3 - JeepForum.com
post #31 of 83 Old 04-07-2013, 07:10 PM Thread Starter
speedbucket
Spent about 14$ and made my own discos. My old type with clevis pin instead of bolt broke and allowed too much play.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #32 of 83 Old 04-16-2013, 04:12 PM Thread Starter
speedbucket
Brown Santa paid a visit......now just to put it all on
post #33 of 83 Old 05-04-2013, 06:48 PM Thread Starter
speedbucket
Today I went past the point of no return and cut off the control arm brackets, so she's not moving til I'm done.
ForumRunner_20130504_204543.jpg   ForumRunner_20130504_204556.jpg   ForumRunner_20130504_204617.jpg   ForumRunner_20130504_204656.jpg   ForumRunner_20130504_204719.jpg
post #34 of 83 Old 05-06-2013, 06:40 PM Thread Starter
speedbucket
Got the passenger side cut and the driver side up into position
post #35 of 83 Old 07-29-2013, 12:53 PM Thread Starter
speedbucket
so i did a bunch of crap
finished the frame stiffeners
once i could get the heep set to ride height with the jack stands under the frame rails then this happened
followed by this........rolled the new axles under for suspension mock up( 3 link front/dub tri rear)
then got busy doing jerbs on the front x member and got her bolted in place
now i just have to weld some key gussets in, make the new tranny mount and weld in the link tabs. I cheated the crossmember rearward from stock for driveshaft clearance without notching and my heims will actually bolt up rearward of the crossmember and will end up about 40" long eye to eye
post #36 of 83 Old 08-07-2013, 10:25 PM Thread Starter
speedbucket
Finished welding up my new cross member tonight for my truly long....long arms. My lowers will end up 40" eye to eye
post #37 of 83 Old 08-12-2013, 08:36 PM Thread Starter
speedbucket
did some work on the crossmember....
added some gussets/plate to the tranny mount and clipped and added the gussets/bolt protection to the mounting plates
now i just need it not to rain to get my 3rd link bracket/frame mount in and im ready to cut some dom!
post #38 of 83 Old 08-15-2013, 02:07 PM Thread Starter
speedbucket
3rd link mount doneski
post #39 of 83 Old 08-16-2013, 07:08 AM Thread Starter
speedbucket
Last night I:
Beefed up the tranny mount .......
Then primed and painted it
Then primed the cross member as well and bolted it in for the 36th time to check clearances for some gussets.....you can see the 3rd link /lower link relationship here...
Then I welded up said gussets, I went polished off the rest of my 2nd 2lb spool this week so I said screw it and through a 10lb roll on...
post #40 of 83 Old 08-19-2013, 05:31 AM Thread Starter
speedbucket
jerbs...
operation 28 lbs of crap in a 1.8 lb bag was mostly a success..
front long arms doneski
tomorrow the springs go back in, knuckles get drilled out for steering and start on the rear crossmember....
post #41 of 83 Old 08-21-2013, 01:20 PM Thread Starter
speedbucket
links painted
post #42 of 83 Old 08-21-2013, 10:47 PM Thread Starter
speedbucket
whelp
got the front back on its own weight and my ride height was about an inch higher than i had the stands set for but that's tough to figure once the fenders are cut. i don't think 34s or 35s would be a problem for a set of wheeling tires...
i also drilled the knuckles out, put the track bar in and got the ruffstuff steering i got from stevied in. i transferred it to ms paint and my track bar and drag link are dang near perfect as far as plane so bump steer shouldn't be and issue
post #43 of 83 Old 09-24-2013, 10:20 PM Thread Starter
speedbucket
Getting there...
Truss done and tacked on
Rear cross member built
Rear links built
Sye installed
Now that I know it all works its time to take some measurements and pull it back apart to finish weld the axle....
post #44 of 83 Old 10-06-2013, 12:00 AM Thread Starter
speedbucket
She be rolling...test drive in the am !
post #45 of 83 Old 11-21-2013, 09:11 AM
Myusername1674
Nice build man, love the custom arms you have setup now. Only question I have is are you planning to protect those front lowers somehow, I mean they look super beefy but I'd just be a little worried about them hanging down so low. Besides that nice setup man!
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
