Speedbuckets ZJ build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Speedbuckets ZJ build
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 05-20-2012, 03:15 PM   #16
speedbucket
First pic is of some hardcore jeepers hard at it.
Finished up the main section of the rear bumper this morning. Ran a sanwhiching strip for the skid plate and bumper mounts.
I wish they were my welds but they aren't.
forumrunner_20120520_160120.jpg   forumrunner_20120520_160206.jpg   forumrunner_20120520_160308.jpg   forumrunner_20120520_160422.jpg   forumrunner_20120520_160503.jpg
http://www.jeepforum.com/forum/f22/speedbuckets-zj-build-1361322/
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline   Reply With Quote Quick reply to this message
Unread 05-22-2012, 09:45 PM   #17
speedbucket
Pulled the rear bumper and skid tonight to knock the rust off and paint. Also picked up a 3.5 ton Jack for 79$
forumrunner_20120522_224021.jpg   forumrunner_20120522_224124.jpg   forumrunner_20120522_224212.jpg   forumrunner_20120522_224324.jpg   forumrunner_20120522_224400.jpg
Unread 07-16-2012, 10:36 PM   #18
speedbucket
Dont mind this pic
Unread 08-17-2012, 09:39 AM   #19
speedbucket
As she sits now
8.8 and hp30 going in with 3 link front and wishbone rear
Unread 08-18-2012, 02:39 PM   #20
stoneydude
What do you think of the Tomken front bumper?
stoneydude is offline   Reply With Quote Quick reply to this message
Unread 08-19-2012, 11:36 AM   #21
speedbucket
I like it, ALOT of people as about it
It has a skid that goes from the bottom of bumper to rad support which i really like
Its sturdy but i would like to see the fenders wings a little thicker but once my boatside to bumper tube fender gets tied in that will be solved
Great fitment, welds are clean
Gives a much better approach angle than the arb
The shackle bars run back into the frame rail and the bumper bolts to the bars with decent spacing which makes it solid. I havent put it through any major abuse yet but the guy i boight it from wheeled it and i had zero fitment issues
Unread 03-31-2013, 11:13 AM   #22
speedbucket
Gonna try and get this going again
forumrunner_20130331_121039.jpg   forumrunner_20130331_121106.jpg   forumrunner_20130331_121149.jpg
Unread 04-05-2013, 07:50 AM   #23
speedbucket
Got the welding setup finished...
Unread 04-05-2013, 09:24 AM   #24
louie5505
Originally Posted by speedbucket
annnnnnddddddd.................GO!
-93 zj
-5.2L-318-255K miles and counting
-46RH tranny-rebuilt at 155k
-np249 t-case
-lpD30 front-open-3:73
-D35 (3:73) rear with Lsd and the optional leaking pinion seal
-(5) 31x1050x15 RTS on black stockies
-4.5" short arm lift
FRONT:
-RC 3.5" lift springs+1.75" spacers
-Home made discos
-Iron Man FAB upper adjustables
-RC fixed lowers
-HYdro shocks
-IRO adjustable track bar
REAR:
-my old front springs with .75" spacer
-RE super flex adjustable uppers
-RC fixed lowers
-IRO adjustable rear track bar
-Hydro shocks
Other ADD ons:
-factory fogs
-surco roof rack
-A-pillar mini spots(deer spotters)
-Built a storage platform for rear cargo area
-I've got Sounds
Future:
-have a Hp 30 (non disco) sitting at home with a Detroit True trac and a broken pinion
-frankensteined a 249 and 242 to work with the 1.55" exposed input but havent sealed it up because i really want a 231
-triangulated and locked 8.8 and 4:56s
test fitting my trail tires right after installed my lift
after some paint and 31s
same
and storage platform
as it sits now
What did you paint your grille black with?
louie5505 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2013, 09:33 AM   #25
speedbucket
All the plastic I scuff sanded with fine grit, wiped with soapy water. Hit it with plastic primer spray can, then hit with rustoleum satin black. RwAlly easy to make it look finished
Unread 04-05-2013, 09:44 AM   #26
louie5505
Does it chip or come off at all???
Unread 04-05-2013, 09:48 AM   #27
louie5505
Is that good or does it need a certain color or something
Unread 04-05-2013, 10:03 AM   #28
speedbucket
Mine was gray. That's fine. 2 light finish coats of black.
Unread 04-05-2013, 10:14 AM   #29
louie5505
Ok cool
Unread 04-06-2013, 07:38 PM   #30
speedbucket
Frame stiffeners. 3x5 x.25 angle
