Sonic's 05 TJ build - Page 19 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Sonic's 05 TJ build
Savvy/Currie Aluminum Control ArmsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAlloy usa heavy duty ball joint kits
Unread 08-03-2013, 02:49 PM   #271
SonicR1
Thanks Matt!!! I'm hoping the drive shaft will be good... It seemed a little short when I converted to the 8.8. When I adjust the control arms I plan to extend to full droop to see if it's still good. I'll prolly get to that Monday. Still have some exhaust work to do, had to cut the hanger. Not as drastic a change as I expected, I guess the real test will be on the rocks!
[COLOR="Red"]... I guess I'm gonna have to fix that too…….[/COLOR]
[URL="http://www.jeepforum.com/forum/f9/sonics-05-tj-build-1168663/#post10985489"][COLOR="yellow"]The TJ[/COLOR][/URL]
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
[URL="http://www.jeepforum.com/forum/f8/sonics-74-cj5-build-1106795/"][COLOR="DarkOrange"]1974 CJ5 BUILD THREAD[/COLOR][/URL]
SonicR1 is offline   Reply With Quote Quick reply to this message
Unread 08-05-2013, 03:08 PM   #272
SonicR1
And it begins, NO TURNING BACK!!
And here is the stumbling block…
I moved the upper back about a half an inch, but I still had to bring the lowers in and they are as short as they can be… the upper is such a pita to move!!!!!
Unread 08-05-2013, 04:13 PM   #273
jrallen
Maybe this is a dumb question, but what'd you do about the rear TB? I don't know what rear suspension you have and it's been a while since I've read through your build...
Edit: it looks like a wishbone 3link to me. Is that right?
jrallen is online now   Reply With Quote Quick reply to this message
Unread 08-05-2013, 04:42 PM   #274
SonicR1
yeah, Full Traction "3 link upper"… I don't hate it, but this solidifies that my next step will be triangulated 4 link!!!
Annnnndddd…
Thank goodness, I went and checked the mail before I started to adjust the upper again…
Unread 08-06-2013, 10:13 PM   #275
SonicR1
The MML was a lot easier than I expected... I did a lot of reading and read horror stories... All in all it took about 45 minutes.
And the end result:
Vibes are better but they are still there at highway speeds... I guess I have some more adjusting to do.
Unread 08-07-2013, 08:06 AM   #276
Jim1611
Jim1611's Avatar
You could always sell it and buy a CJ
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 09:38 AM   #277
mvigo
mvigo's Avatar
Great idea, Jim! I think he is doing all this work just to keep up with one...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 11:42 AM   #278
SonicR1
Mike, You know it... I need a TJ with 35's to keep up with a CJ on 32's!!!!! Jim, Only thing I will get rid of this for now is a 4-door Rubicon... and since I have one (kind of), I'm never geting rid of this thing!!! The kids can have this, I'll take momma's Rubi and put 37s on it...
Well, I welded up the exhaust bracket last night... that helped with some of the sounds, but I still have a growl... I'm gonna try and drop the skid and see if it is just driveline related...
Unread 08-07-2013, 10:00 PM   #279
SonicR1
And now death wobble has set in........
I checked the steering... Is it bad when the tre's click???
On a better note, I used some washers to drop the skid and vibes got better... So I got to find time to adjust the control arms... That freakin upper is a pita to adjust........
Unread 08-12-2013, 01:36 PM   #280
SonicR1
Soooo close, yet so far away...
Forgot I have a rugged ridge tie rod... Ordered stock replacement parts, so now I have to no back and get tie rod ends for it... All I know is 7/8" standard taper... Hope they will be able to help me figure it out........
Unread 08-12-2013, 04:52 PM   #281
SonicR1
Wellllllllllllllll, there are no replacements for the rh tie rod end that rugged ridge uses...
I previously noticed that my dana 30 cover was getting dinged. I didn't realize how bad until I went to replace the cover...
The bottom two bolts were a little shaved, almost didn't get the one off. I had to grind the bottom edge flat. Anyway... Here is the replacement.
I don't know why, but I kind if wanted to match the rear.
Anyway, all back together, I guess if I'm going to make it to the rubicon tomorrow, I'm gonna have to find a trailer...
Unread 08-15-2013, 06:19 PM   #282
SonicR1
Had a great day on the Rubicon Tuesday!!! Mvigo lead the way on a spectacular trip. Didn't take many photos... Technically, I have over 250--my 7 year old had the camera... I took a few, here are some of the highlights...
Well, got a trailer... and a big thanks to Mvigo who hosted me and my boys Monday night!
Mvigo fixing a hanging tank/skid
I couldn't let mike have all the fun...
And a pic from Mvigo
What a wonderful day!!!
Unread 08-16-2013, 12:40 AM   #283
mvigo
mvigo's Avatar
great day indeed! thanks for making the effort...
Unread 08-17-2013, 05:47 PM   #284
SonicR1
New tie rod ends are in... Still have death wobble... YAY!!!
Steering is all new... So ball joints or control arm bushings???
Aaaand I still haven't figured out what the growl is since I put the tummy tuck on...
Unread 08-25-2013, 08:52 PM   #285
SonicR1
So I count that some of my rattle had to do with my transfer case so I dropped my skid and found this:
I don't think that is normal... I found some washers that fit that seamed to make it all snug... It didn't really help, still have a weird grinding that is associated with driveline rpm... Aaaaarggghhh!!!
Good news is that I think I found the source of my DW-track bar... It seems the rod end on it is not tight. I tried replacing it with another I had, it is better now, but not great...
