Sonic's 05 TJ build - Page 17 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Sonic's 05 TJ build
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRIGID LED Light Blowout Sale - All Sizes, All Series, all Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 05-25-2013, 05:53 PM   #241
SonicR1
Went to Frank Reins Park in Patterson today… Lead the group… big mistake, I got stuck a couple times… I hate picking lines!!! I tried to idle up this and started to slip, so as I backed down, I slipped into the rut… it tore off my muffler… the first casualty of the day...
When I got stuck this time, I backed into that bolder…
And sometime during my adventures, I did this… it was folded under a bit more, but I pulled on it and viola, good as new!!!
All in all, a great day wheeling!!!
[COLOR="Red"]... I guess I'm gonna have to fix that too…….[/COLOR]
[URL="http://www.jeepforum.com/forum/f9/sonics-05-tj-build-1168663/#post10985489"][COLOR="yellow"]The TJ[/COLOR][/URL]
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
[URL="http://www.jeepforum.com/forum/f8/sonics-74-cj5-build-1106795/"][COLOR="DarkOrange"]1974 CJ5 BUILD THREAD[/COLOR][/URL]
SonicR1 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2013, 11:26 AM   #242
mvigo
mvigo's Avatar
next time, call me, I am itching for a local trip...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 05-26-2013, 09:45 PM   #243
SonicR1
Sounds good, I think we will go in the next month or so... Not sure about the rubicon still... Trying to work it out.
Unread 05-27-2013, 02:03 PM   #244
Jim1611
Jim1611's Avatar
Nice pictures Bill. You must have some good bolts holding that highlift on for them to not break and bend it like that! The rack must be mounted solid too for it to not have tweeked that as well. Oh and I like the front bumper better after the cut job.
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 08:31 PM   #245
SonicR1
Yeah, Jim, I was thinking I shouldn't have used grade 8 bolts for the highlift... Hind site bein 20/20 and all... today I cut a bit of the tailpipe so it won't hang down as low anymore and I welded the muffler to the y-pipe/cat! It is a little louder now but it won't get hung up and fall off!!!
Oh, and I had a buddy point out, although the bumper looks better now, it would have taken the hit that squashed my fender! He also said that he has made tube fenders in the past (he is the guy who has the JD2 tube bender I used for the tire carrier), so that may be a project for this summer.
While I was under the jeep, I noticed the tranny skid got beat up real good, looks like there is a chip out of the tranny, although it may be old or normal... So I think I may be investing in more underside protection!!! My shock mounts hang down pretty low, so I may end up moving those too!
Also helped a friend with her FJ Cruiser today...
It rode pretty nice on the freeway after the lift!!!
Unread 06-15-2013, 12:21 PM   #246
SonicR1
Well, I've been noticing some heat related engine issues, replaced the radiator cap and it stopped the boiling, still had some heat issues, double checked fluid level, had to add a quart or so, haven't had any issues since, but ordered a PSC hood louver to add some flair and draw some heat out of the engine bay… quick shipping except it was for 97-02… so waiting on exchange…
Unread 06-19-2013, 07:20 PM   #247
Jim1611
Jim1611's Avatar
Bill what's your friend think of the FJ? I like them and have thought that I might like to have one at some point.
On that heat issue. Are the fins on the radiator clean? I've had some problems with that in the past.
Unread 06-23-2013, 10:11 AM   #248
SonicR1
She loves the fj!!! She is like one of us with our jeeps! She just put some bigger tires on it--285's... Now she wants to go wheelin. Anyway, I actually like driving it. Strong engine, nice tranny, tight steering! Only issue is the blind spots, but you can see fine if you use your mirrors and actually turn you head and look... . I don't like the rear door, a little tight getting in and out of the back. The JKU is much easier to get into, and the only issue I have with ours is power, buta really, it works just fine the way it is. It would be head and shoulders ahead of the FJ in every category if they put the diesel/8speed combo in it!!!
I'm gonna have to check the radiator fins today, it was in the high 80's yesterday and the temp reading went up above 210 on a 40 minute freeway ride... I just don't get it, my Chevy 1500hd (6.0/4L80E) stays constantly below 210, pulling my boat with the a/c on!
Still waiting on the louvers...
Unread 06-28-2013, 12:33 AM   #249
SonicR1
Woooo hooooo, it was like Christmas in June today!!! I ordered 4 differant things from 4 differant vendors and everything came today!!!
I couldn't wait, not to mention I did t want to wait because tomorrow is going to be over 100 degrees here, so I started on the Poison Spyder hood louver...
No turning back now...
I thought I'd use the tape for cutting guide...
That worked ok, I started with an angle grinder with a cut off wheel, but my round edged became square real quick when it got ahead of me. I tried a jig saw with a metal blade, but that was worse. I ended up going back to the angle grinder, but was more careful to cut slowly!!!
I had to go back over the cut edges with a flap disc! I painted the top and the bottom... Two reasons, to paint the no longer painted surface, and so the yellow wouldn't show through the louvers.
And here is the end product...
I'm done, it's dark, so no pics on the jeep, I'll get one tomorrow. I like it!
Unread 06-28-2013, 07:24 AM   #250
Jim1611
Jim1611's Avatar
Hood really turned out great. That's gotta help but I think you've got something else going on too, might be wrong and would not be the first time though.
I could deal with the blind spoys on the FJ. I use my mirrors allot. It really amazes me where people don't look when they're driving! I watch people coming up to an intersection, even if I have the right of way, if they haven't turned their head to look at me I'm on the brakes. That saved me from t-boning someone just the other day and I was at 60mph. Most likely they'd not have lived through that and maybe me either. I'm sure you see all kinds of things in your profession.
Unread 06-28-2013, 11:14 AM   #251
SonicR1
Yeah, riding a motorcycle as long as I have, I don't trust mirrors much anyway... Head on a swivel!
And here is a pic from this morning...
And as you can see, I had an early morning project...
I hate that tree!!! Ugly, smells, overgrown, in the way of my rv pad...neighbor thinks its his even though 90% of it is on my side... Well, I got the ok to chop it down, but it's over 85 degrees, and I plan to go to the dump and spend the rest of the day inside!!!
Unread 06-28-2013, 01:08 PM   #252
SonicR1
Oh, Jim, I checked the radiator like you suggested. The fins look good, I washed it out though, and it took awhile to get clean water out the other side, tons of dirt and grime... And bugs!!! hopefully that will help some too!
Unread 06-28-2013, 06:30 PM   #253
mvigo
mvigo's Avatar
looking forward to seeing the hood up close and personal...
Unread 06-28-2013, 09:00 PM   #254
Jim1611
Jim1611's Avatar
Sounds like the fins were clogged up. I bet it runs cooler now.
Unread 06-29-2013, 12:01 AM   #255
SonicR1
It's still running weird!!! Temp was fine on on freeway, over 100 degrees, a/c on, stop and go traffic because of a crash. About ten miles past the crash I get off the freeway and the temp pegs. I start rolling and it goes back down. Weird!!!!
