Sonic's 05 TJ build - Page 16 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Sonic's 05 TJ build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-08-2012, 06:39 PM   #226
SonicR1
So, the brake light went on last weekend, and didn't have a lot of time to give it. Tried bleeding brakes a couple times, didn't work. Then again this weekend, I tried, didn't work… the pedal seems solid, but the light stays on… AAAARRRGGGHHH!!!! So tomorrow I'm going to replace the pads and rotors to see if that will help.
[COLOR="Red"]... I guess I'm gonna have to fix that too…….[/COLOR]
[URL="http://www.jeepforum.com/forum/f9/sonics-05-tj-build-1168663/#post10985489"][COLOR="yellow"]The TJ[/COLOR][/URL]
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
[URL="http://www.jeepforum.com/forum/f8/sonics-74-cj5-build-1106795/"][COLOR="DarkOrange"]1974 CJ5 BUILD THREAD[/COLOR][/URL]
SonicR1 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2012, 07:55 PM   #227
SonicR1
After a couple weeks of busy weekends, I got to messing with the Jeep. I put some braided lines on the front and bleed the brakes a couple more times but the light was still on. I admitted defeat and took it to a shop… $250 and a new prop valve and it is better than new!!! The brakes feel great!!! Here are the front lines…
Unread 12-29-2012, 07:11 PM   #228
SonicR1
In an attempt to quiet the exhaust down I changed the turn down to a 90 degree elbow. I aimed it down and to the side... Aparrantly hot gases can melt poly pretty easily...
I spent some time shortening everything so it aims at nothing, but I think a trip to the exhaust shop will be coming soon...
All this after commenting on a thread asking about short exhausts... I don't mind it, the fam doesn't like it... Oh well...
Unread 03-15-2013, 07:08 PM   #229
SonicR1
No TJ news, but had to replace the waterpump on the JKUR...
A lot easier than I thought... Took about 30 minutes.
Unread 03-29-2013, 01:30 PM   #230
SonicR1
Today's jeepin consisted of replacing the tank skid and trying to find the culprit of my P0456 code... I tried replacing the fuel cap but that didn't work... I checked the tank, it held pressure, so I has to be a hose somewhere...
Anyway, the new and old...
Only took an hour, would have been less if my tank wasn't full... Now off to see if I can get the code diagnosed...
Unread 04-10-2013, 09:33 PM   #231
SonicR1
JK crap...
Have had the imphamous ticking for some time now but never really cared to do anything about it due to all the stories I read about expensive replacement cost. I recently started to hear a new ticking coming from what I thought sounded like valve train. Took it to the dealer. They replaced the manifold under warranty (99k+ miles!!!) no questions asked. I got it home and it stilled ticked. I took it back and they thought it may be valve train which they said would be under warranty. My wife called about it today, they said they tore into it and had to keep going, thought it may be a rod baring... And they are working with Chrysler to replace the engine under warranty!!! Two things of note, I am so glad we got the jeep while Chrysler offered the unlimited mile power train warranty and we purchased the oil change package, so they have all the oil changes on file and they didn't even question our maintenance!!!
Now I just gotta fix the P0456 code on my TJ... Aaarrrggghhh!!!!
Unread 04-10-2013, 11:12 PM   #232
mvigo
mvigo's Avatar
Originally Posted by SonicR1
JK crap...
Eric's red jeep has the same error code, throttle positioning sensor is being triggered. Could be that or the clock ring in the steering column. We have yet to get a chance to repair it...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 04-11-2013, 09:10 PM   #233
SonicR1
P0456 is evap system small leak... Everyone says most likely fuel cap, i bought a new one a little while ago, but that didn't fix it. I checked the hoses from front to back briefly, they look dry and could be worn through. Im gonna run through the hoses and see if I got any leaks in them.
Oh, when you guys are ready, I want to move my axle back an inch and weld in new frame coil mounts!
Unread 04-17-2013, 10:10 PM   #234
SonicR1
The JK is back, new engine and all!!!!
Stupid TJ CEL!!! I checked all the lines, and they seam to hold vacuum... I guess I'll be taking it to the shop... Aaargh!!!
Unread 04-18-2013, 10:17 AM   #235
rubidriver
How does the tailgate latch
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote Quick reply to this message
Unread 04-20-2013, 12:35 PM   #236
SonicR1
It latches using the stock CJ latches... Still looking for a better solution, it's kind of a pain to open and close right now, I got to reach through the top!
Unread 04-23-2013, 09:53 PM   #237
SonicR1
$500 later, a new charcoal canister and filter, and the light is gone!!!
Unread 05-24-2013, 03:42 PM   #238
SonicR1
So, I did something today I've been wanting to do for a while. I never really like my front bumper...
So I modified it a bit...
Not sure if I like it still, but I've always liked stubby bumpers, so I think I like it more now...
Unread 05-24-2013, 07:37 PM   #239
mvigo
mvigo's Avatar
much more bueno,
Unread 05-24-2013, 08:23 PM   #240
SonicR1
So I go out to rotate my tires today, find one really jacked up… every other row of tread is about a quarter of an inch shorter than the next (explains some vibes I've been getting), so I go to rotate my spare in (I got it the summer after I got the other 4) and I find out it has different backspacing by like a half an inch… uuuggghhh!!!!!! I got it from the same guy who sold me the 4, he even came out and looked at my jeep!!!
Learned two important things today. 1) Don't buy cheap tires!!! 2) Buy all 5 at the same time!!!
Looks like I'll be getting tires and wheels soon!!!
