smith0200s YJ build - JeepForum.com
post #1 of 5 Old 01-10-2015, 06:51 PM Thread Starter
smith0200
2009 JK Wrangler
smith0200s YJ build
Got my 92 wrangler now time to build it
smith0200 is offline
post #2 of 5 Old 01-10-2015, 06:54 PM Thread Starter
smith0200
2009 JK Wrangler
Got this jeep in august 2014. Like most I thought I'd just start with upgrades. I knew it would need a bit of work but not as much as it did.. Anyway here we go.
post #3 of 5 Old 01-10-2015, 06:56 PM Thread Starter
smith0200
2009 JK Wrangler
I've had an on going battle with a steering issue. Turned our to be the boz bolted to a piece of frame that was completely detached. Haha not good. Also had the rear by shackles reinforced.
post #4 of 5 Old 01-10-2015, 07:00 PM Thread Starter
smith0200
2009 JK Wrangler
So far since I got it I've done radio( jerk before me cit the harness so I had to figure out what wire went to what!), thermostat, frame work, steering shaft, tie rods, heating duct, header(manifold had intense leak at collected), throttle body spacer, cold air intake, alternator, fuse box wiring(jeep wouldn't turn on for a while finally found out the issue), vacuum check valve, and I have a proper lift kit going in, 4.10s front and rear, stinger, and a tire carrier soon. More pictures to come!
post #5 of 5 Old 01-10-2015, 07:03 PM Thread Starter
smith0200
2009 JK Wrangler
There's the lift , stinger,and old exhaust manifold.
Snapchat-7392631828253952425_1420941621186.jpg   Snapchat--3104279948110622028_1420941639632.jpg   Snapchat-8914620090910456479_1420941652403.jpg
