Silver LJ Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Silver LJ Build
Poison spyder items @ oconee off road 706 534 9955Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-31-2014, 06:45 AM   #1
maiken
Silver LJ Build
Special thanks to Tim and the guys at T&C 4x4 Customs in Cumming, GA for turning this thing into a beast.
Before:
After:
Next:
The 6.0 LS with 550HP and 6l80E trans is being prepped to go in and be mated to the Atlas as well as fully custom long arm suspension with coil overs and rear 4 link built by Tim at T&C. If you are in GA you need to check them out. They build sick rigs.
maiken is offline   Reply With Quote
Unread 07-31-2014, 08:01 PM   #2
DezertTJ
Lost
DezertTJ's Avatar
absolutely gorgeous
06 LJ Rubicon: AZ Backcountry LJ Build
DezertTJ is offline   Reply With Quote
Unread 07-31-2014, 11:34 PM   #3
justntime911
Junior Member
Sweet LJ! What suspension/axles are you running?
justntime911 is offline   Reply With Quote
Unread 08-01-2014, 08:44 AM   #4
maiken
Suspension is currently Rusty's 5 1/2" long arm with coils but it's coming off and doing custom coil over setup front and rear with 4 link rear. Front and rear axles are Dynatrac High Pinion High Clearance Dana 60's locked with ARB's. Wheels are Raceline Beadlock 17x9's and tires are Interco Trxus 38.5 x 14.50.
