Silver Lining - JeepForum.com
post #1 of 67 Old 10-23-2012, 10:30 AM Thread Starter
Ironhead
Silver Lining
Time Line
an unfortunate accident on 1/2/12 and little red was totaled
1/14/12 purchased 03 rubicon with 129k miles spent a few weeks changing all fluids and tune up parts
2/10/12 1.25" zone BL and 1" zone MML, Novak shifter cable
2/17/12 2" BDS springs Fox 2.0 shocks
4/2/12 315/75r16 Goodyear duratracs
4/10/12 AntiRock front swaybar
5/5/12 lower front Savvy aluminum adjustable control arms with mini skids
8/14/12 upper and lower rear Savvy aluminum adj control arms
9/1/12 ZJ tie rod
10/29/12 LED Tail lights, genright hood louvers
12/3/12 Bosch h4 headlights
12/10/12 Tatton CV DS, UCF UHC skid, upgraded to 04-06 style trans pan for 42rle
1/5/13 LoPro with lots of grinding
2/17/13 Black Magic brakes, JJ Washers
2/22/13 1.5" Brown Dog MM
3/1/13 Warn 9.5Ti winch with synthetic rope
3/8/13 3" BDS front springs
3/17/13 stock gas tank mod to raise it 1" and gain track bar clearance
3/28/13 UCF engine skid, front DS rebuild, radiator replaced
4/19/13 Replaced rear pads and rotors. replaced Left side Multi-Function switch
6/9/13 Install Windstar air box mod
6/14/13 Install KC Apollo Pro fog lights
6/25/13 Install Exogate
8/15/13 Install MC front track bar
10/5/13 Completed frame repair, installed flowmaster 40, and installed GenRight Comp gas tank
8/1/14 Install PS fenders, PSC aux coolers, oil pressure switch, intake/exhaust gasket, MORE 1" steering brace
Current Specs
Clearances
5.25" between front tire and flare - 3" uptravel, 6" down
5.75" between rear tire and flare - 4.25" uptravel, 3.75" down
24.25" ground to slider
19.5" ground to frame
18.5" ground to skid
Engine
4.0L I6
1.5" Brown dog motor mounts
Transmission
42RLE
04-06 style pan
PSC Trans cooler
Transfer Case
NP241OR
Novak shifter cable
Front Axle
Rubicon D44
4.10 gears
stock axle shafts
factory air locker
MC track bar
Black Magic brakes
Centric rotors
Rebuilt front DS 5-793x, 2x 5-790x, spicer centering ball
Rear Axle
Rubicon D44
4.10 gears
stock axle shafts
factory air locker
Stock disc brakes
Tatton DS 1330 u-joints
Tires and Wheels
315/75r16 Goodyear duratrac E-Load
16" Dick Cepek DC-2
Suspension
Front
3" BDS springs
Fox 2.0 shocks
Savvy aluminum lower control arms
Stock upper control arms
AntiRock swaybar
Stock track bar
2.25" Bump stop
Rear
2" BDS springs
Fox 2.0 shocks
Savvy aluminum upper control arms
Stock sway bar
Stock track bar
1.5" Bump stop
Steering
ZJ tierod
stock drag link
PSC/derale steering cooler
Armor
Front bumper
Stock
Rear bumper
Stock
TC skid
Undercover Fab's Ultra High Clearance .250 aluminum skid plate with Lopro trans mount
Engine skid
Undercover Fab's .250 aluminum skid
Fenders
Poison Spyder Negative XC Defenders in aluminum
Electronics
Radio
Eclipse CD3000 deck
Eclipse XA4000 4 way amp (125wx4 rms)
Polk MM521 5.25" fronts
Polk Momo 6.5" in soundbar
Kicker ZX400.1 mono amp rated at 485w
Kicker 10" CVR sub
Modified stock locker switches
Lights
Bosch H4 headlights
LED tail lights
LED reverse lights
LED bolts lights for license plate
CB
Cobra 19 DX IV
Ironhead is online now
post #2 of 67 Old 10-23-2012, 10:36 AM Thread Starter
Ironhead
lil Red was totalled due to the amount of drivetrain damage. searched all over and found this gem, well, it needed some work, but it was solid
a delivery from BDS
Also, I got that silly light bar off
post #3 of 67 Old 10-23-2012, 10:38 AM Thread Starter
Ironhead
some cheap tires to check fitment
and a delivery from tirerack
post #4 of 67 Old 10-23-2012, 10:41 AM Thread Starter
Ironhead
first off-road trip. @ badlands
post #5 of 67 Old 10-23-2012, 11:02 AM Thread Starter
Ironhead
a few mods
AR
Savvy front LCA
Locker switch mod
Bump stops
and some more fun @ badlands
post #6 of 67 Old 10-29-2012, 07:17 AM Thread Starter
Ironhead
got the savvy rear control arms in and adjusted.
debating on relocating my compressors or just mounting them to the new skid
planning the new skid install on thursday or friday
also, got that god awful brush guard off, swapped tail lights, and added hood louvers
some cheap flex pics for now
getting all set to hit the Badlands on Nov. 10th
post #7 of 67 Old 11-05-2012, 12:35 PM Thread Starter
Ironhead
Just ordered a Tatton CV DS. planing on installing my skid over the next few days. it'll be nice to have it on and not have any vibs
will also be installing 04-06 trans pan while i have the skid down
post #8 of 67 Old 11-07-2012, 08:53 AM
Tbasham
[QUOTE=Ironhead_Jed;14345481]
QUOTE]
I agree that light bar was ridiculous. Is this a DD too or mainly on trails.
Tbasham is offline
post #9 of 67 Old 11-08-2012, 01:46 PM Thread Starter
Ironhead
It's a dd in the winter, splits time with motorcycles in the summer
post #10 of 67 Old 11-08-2012, 01:54 PM
Imped
Imped's Avatar
Solid purchases so far.
OlllllllO
IndyORV
Imped is offline
post #11 of 67 Old 11-08-2012, 03:01 PM
marcuslehning
I might have missed it, but lift and tire size? Looks nice
marcuslehning is offline
post #12 of 67 Old 11-09-2012, 07:56 AM Thread Starter
Ironhead
2" spring lift and 1.25" BL. 315/75r16 duratracs, roughly 35x12.5x16
post #13 of 67 Old 11-19-2012, 09:54 AM
slmason72
Good looking Jeep. Chive on.
slmason72 is offline
post #14 of 67 Old 12-15-2012, 07:16 PM Thread Starter
Ironhead
Thanks man. Always nice to chat with a fellow chiver. I dig the color on your rig
post #15 of 67 Old 12-15-2012, 07:32 PM Thread Starter
Ironhead
did some more upgrades and played around at the badlands a bit today.
UCF UHC skid, still modding things to get the lopro to work
ended up having to use a 1" radiator drop with the tummy tuck
Finally figured out a decent place to mount the stock rubi air pumps
changed the 03 trans pan to the new design
Tatton drive shaft w/ all three 1330 u-joints
replaced a wheel bearing
upgraded to h4 headlights
still want to play around with my control arm lengths a bit and i think a new muffler is on the list, but was very happy with the results for a rainy,sandy, sloppy day
