The Silver Bullet - Page 5 - JeepForum.com
post #61 of 1339 Old 10-21-2011, 11:39 PM
LilSteve97TJ
Good luck finding a ford 9" in a chevrolet....look into a semifloat 14 bolt while your at it, smaller ring gear then the 1ton version 9.5>10.5 and they are pretty beefy. I have a friend with a ZJ that has a 9" and said he wishes he would have gone full width 8.8 instead of the 9" as the axle seals always leak and pulling the 3rd member out can be a pain.
mallard15, I stated that both of the toyotas i had were sprung over. Theres a lot other ill effects of leaves then axle wrap, having a properly set up leaf system takes a lot of work, shackle angle is a big factor of a proper set up. I'm not jumping into linking my jeep blind i assure you i've done the homework and wheeled with a lot of guys that i've learned a lot from. The antisquat numbers i'm shooting for are between 80-90%, most the jeeps i wheel with are set up close to that and work flawlessly. At the end of the day though, **** on paper may look good but with little space to work with on a TJ frame, you just have to make it fit. The numbers i've crunched should work good and fit under my jeep. I wont say my links are long or short, but from what most people on here refer to them, they're considered mid at 26" front lowers and 28" in rear.
Looks as though your from SC as well, do you wheel around here?
97 TJ
98 Taco
LilSteve97TJ is offline
post #62 of 1339 Old 10-22-2011, 07:08 AM Thread Starter
mcannon111
Yeah I know what to get a nine inch out of lol and a 8.8 is way weaker than a nine inch with way less potential. 14 bolts have no problem clearance, and not as many parts. And Idk why I wrote chevy, hp44 from a 76-77 f100.
And yeah I am from sc I went to gulches a few weekends ago thats where the pics are from
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #63 of 1339 Old 10-22-2011, 07:40 AM
mallard15
I compltely understand what you are saying. I would still like to see how leaves would do on a TJ. I know of a few people, Redsmoke, Kyle and a few others, who have done this and they love it. And yea me and mason both went to school with Gillis last year. I dont wheel very much mostly because I have different ratio's in the front and rear. I did wheel at my farm a couple of times before I swapped axles though. Going in a different direction now. And a 9" is more of a full width than an 8.8. 1980-86 f-150 9"'s are all 31 spline, semifloat, and around 65 inches wide I believe. Correct me if I am wrong but the most common 8.8's, from explorers and such, are around 59 or 60 inches wide. Narrower than stock TJ axles.
Bestop Extendatrunk for sale (150$) PM me
Yukon 4.10 R&P Gears Set (300$) PM me
mallard15 is offline
post #64 of 1339 Old 10-22-2011, 01:59 PM
LilSteve97TJ
The 8.8 that came in the back of early 90s f150 are fullwidth at 65". I wheel with a lot of folks that wheel 8.8's and i've never seen them skip a beat, in fact i've never heard of anyone breaking anything on an 8.8, even though they are c-clip they are stout, i've seen several 9's break several times on the trail. I had a TJ 44 in the rear of my jeep with a detroit and 4.88s and sold it in favor of an 8.8 when i started collecting parts to 4-link. They are a little narrow at 59" but i have no doubt in the strength.
In a year or two i do plan on building a set of 9's for my jeep but they will be custom from the housing on out.
97 TJ
98 Taco
post #65 of 1339 Old 10-22-2011, 03:14 PM
mallard15
Oh yes, a completely different animal haha.
Were those 9's that broke on the trail 31 or 28 spline? Most likely they were 28 spline. I would rather have a 9" over an 8.8. Why wouldnt you? (not trying to be a smart *** just wondering what your opinion is...)
post #66 of 1339 Old 10-22-2011, 07:26 PM
marcus01tj
they were 31 spline.....
marcus01tj is offline
post #67 of 1339 Old 10-22-2011, 07:35 PM
mallard15
Well they must be wheeling harder than the people on 8.8's because, correct me if I am wrong, the axle diameter of an 8.8 is 1.31 and the 9 is 1.33. Idk I would still rather have a 9 inch over an 8.8.
post #68 of 1339 Old 10-22-2011, 09:07 PM
marcus01tj
haha .02
post #69 of 1339 Old 10-22-2011, 09:50 PM
mallard15
haha .02
Yea yea I know its not much...
post #70 of 1339 Old 10-23-2011, 12:04 AM
LilSteve97TJ
31 spline on 35s and took out a detroit while he was at it. The fact you have to pull 2 shafts to pull the 3rd out on the trail is annoying as hell too, same thing with toyota axles.
97 TJ
98 Taco
post #71 of 1339 Old 10-23-2011, 09:31 AM Thread Starter
mcannon111
okay if he broke a 9 inch with a detroit, he would have broken an 8.8 too and then his tire would be walking out... then remove a c clip. bla bla bla. both axles have there pros and cons. this arguement is going no where, if you want to continue it i will happily start a thread
bakc to the normal. i found a nice stubby front bumper with d ring mounts, 3/8ths steel and winch/fairlead mounts for 100 bucks. might be going to get it today!
post #72 of 1339 Old 10-27-2011, 08:44 PM Thread Starter
mcannon111
here we go, 1.25 jks body lift coming, and going to pick up that bumper tomorrow!
post #73 of 1339 Old 10-27-2011, 09:39 PM
kyle_craig
Looking forward to seeing that bumper!
kyle_craig is offline
post #74 of 1339 Old 10-28-2011, 02:03 PM Thread Starter
mcannon111
alright here's a pic of the bumper! man that was a good find! some guy ordered it and then backed out after the guy had already made it. so i got it for only a 100 bucks! got to order a winch before it goes on though, but it will be on before long don't worry only thing i don't like about the bumper is there is no points at the end, but i'll see how it looks when on there, may change it up some
post #75 of 1339 Old 10-28-2011, 10:41 PM
kyle_craig
That's going to look good. Are the ends open or closed up? Either way, nice find.
03 WJ AKA The Silver Bullet Voltage258 Jeep Builds 4 06-29-2011 10:35 PM
JK Silver with Silver hard top pics? gdok Jeep Picture Requests 0 03-09-2011 05:47 PM
Silver Jeeps with Black and Silver rims jsmaem1106 Jeep Picture Requests 6 09-05-2010 12:09 PM
The Silver Bullet causearuckus Jeep Builds 8 02-10-2010 04:33 PM
Silver Bullet Leland Jeep Builds 0 12-17-2001 03:48 PM
