The Silver Bullet - Page 4 - JeepForum.com
post #46 of 1339 Old 10-11-2011, 09:51 PM
mallard15
Originally Posted by kyle_craig View Post
You really should man! it's a fun and straightforward way to stretch it. We went and pulled a factory Cherokee rear shaft, cut the welds off of the yoke, cut it shorter, and welded the yoke back in. I'm real happy with it. Got lucky in the fact that it has no vibrations what so ever. If you're going to do a slip yoke eliminator, a shortened front Cherokee shaft would work well too!
Hey Kyle do you have a SYE? super short SYE? or no SYE on your 231?
Bestop Extendatrunk for sale (150$) PM me
Yukon 4.10 R&P Gears Set (300$) PM me
mallard15 is offline
post #47 of 1339 Old 10-11-2011, 10:02 PM
kyle_craig
No SYE at the moment. I'm still running the factory belly pan. I'm planning on changing that though. That's why the rear Cherokee DS worked. Cherokee 231s have a slip yoke just like the wranglers. If you install a SYE though, you can use a Cherokee front shaft to the best of my knowledge.
kyle_craig is offline
post #48 of 1339 Old 10-21-2011, 02:16 AM
LilSteve97TJ
Originally Posted by mcannon111 View Post
here are some pictures from this weekend, great trip!
I see Gillis scurrying along behind you. You know him? Jeep looks good.
And im sorry for knocking anyone thats done it, but dont do leaves in the rear. It may be a cheap and easy way to stretch it but you'll regret it i'm sure. I've had 2 vehicles on leaves and axle wrap sucks. Building twice also blows. Check out Offroadsc.com it's a bunch of folks around SC local to you and can hook you up with what you need, including a 4-link rear.
97 TJ
98 Taco
LilSteve97TJ is offline
post #49 of 1339 Old 10-21-2011, 05:47 AM
ibjeepin95
I too have had two vehicles (XJ's) on leaves and I actually enjoyed wheeling them 10x more than my TJ. Never, ever had any axle wrap, so much more stable, better road manners, less wheel hop. With this said, I plan to stretch my TJ to 100" on leaves by the beginning of the year.
ibjeepin95 is offline
post #50 of 1339 Old 10-21-2011, 06:49 AM
TJRHD
Man I like this thread. I was just thinking about snubbing my factory bumper this same way. Like the siver jeep!
NOT A HATER
TJRHD is offline
post #51 of 1339 Old 10-21-2011, 09:19 AM
kyle_craig
Finished mine two weeks ago and I have zero regrets. Were your vehicles set up SUA or SOA?
post #52 of 1339 Old 10-21-2011, 02:27 PM Thread Starter
mcannon111
yeah man i actualy have an account on there and know gillis, and sam pretty well. I meant to come to the last jeep club meeting (which i assume your in) but i just couldn't get off work. i'm for sure coming in november and i am going to go on yalls december wheeling trip as long as you aren't going to harlan, just don't want to drive that far for what my jeep is right now lol.
and idk i've heard alot of positive things about leaf springs in a tj. do it SUA, and stock xj springs. Get about 5-7 inch stretch to put you right on the money at a 100 inch wheel base. tough, stupid proof, and easy to fix if something goes wrong. and you can easily fix axle wrap with a trac bar
i feel like people just have a negative thought toward leafs springs to begin with because they think of all of the poorly designed leaf set ups (the stock xj one) lol if its done right it can easily provide the same or more travel than a well done short arm setup.
idk not completely set on leafs yet, but almost positive that will be the rout i go.
thanks man, yeah the bumper i could have probably cut a little different, but it looks fine like it is to me. probably fabbing one up out a 3/8 steal sometime in the near future!
mcannon111 is offline
post #53 of 1339 Old 10-21-2011, 02:35 PM Thread Starter
mcannon111
also no anti squat with leafs
post #54 of 1339 Old 10-21-2011, 02:40 PM
4Banger88YJ
I would've kept some of the black and went tube fenders to kill a couple birds with one stone. I love the CJ "blinker" conversion.
4Banger88YJ is offline
post #55 of 1339 Old 10-21-2011, 06:46 PM
LilSteve97TJ
I actually live in clemson, but i know brooks and have wheeled with a lot of the midcarolina jeepers, including this weekend at gulches.
Let me get a few more things done to my jeep and i'll start a build thread on here, already have a little one on offroadsc. Im in the middle of a 3/4link with waggy 44 front and ford 8.8 rear and i'll be sitting about 99-101" with adjustablility to go both ways and I have a stupid low amount of money in it and it isn't going to be a hack job, i just slowly aquired parts and waited on deals on stuff, also horse traded. I probably have less in the rear with JJ on both ends of the lowers, and heims on upper using DOM and frame and axle brackets then most have in a leaf conversion, or mighty close.
Both of the leaf rigs i've had were toyota so they were SOA which i know has more wrap then spring under. I still would rather have my jeep linked as it wheels a lot better then any leafs i've seen.
97 TJ
98 Taco
post #56 of 1339 Old 10-21-2011, 09:14 PM Thread Starter
mcannon111
dude that black was gross man you, the pictures made it look mint to what it really looked liked. i did get tube fenders and killed two birds in one stone cause i painted them with the hood and grill and the same time paint match looks way cleaner to me, but its all opion
post #57 of 1339 Old 10-21-2011, 09:16 PM Thread Starter
mcannon111
idk man i'm doing a 9 inch and hp 44 from a chevy cause 9 inches are way stronger, provide the same clearance, semi float, way cheaper parts, and parts are wayyyyyy more common
post #58 of 1339 Old 10-21-2011, 09:36 PM
mallard15
Alright, I can understand why someone would not think a leave swap in a TJ would be a good idea. But, correct me if I am wrong, I'm just guessing that the two vehicles you had were SOA and not SUA. And like mcannon111 said axle wrap can easily be fixed with a track bar. If you use XJ rear leaves and add an extra main leaf the leaves will be nearly flat. Thus, the ride will, most likely, be better than most coil sprung vehicles. Add some stiff gas charged shocks and it will ride very smooth. The 4 link rear entails a lot of effort to do it right. BTW what anti-squat numbers are you going to be shooting for? It's much more difficult to build a efficent and useful four link than it is to swap leaves on. And are you going to LA's? I'd hate to have the links dragging all over rocks
post #59 of 1339 Old 10-21-2011, 09:48 PM
4Banger88YJ
This is true, pictures usually are an injustice, looks good either way, its a JEEEEPPP
post #60 of 1339 Old 10-21-2011, 10:16 PM
mallard15
The pictures were an injustice trust me The paint looked horrible. Like he said, the guy who had it rolled on the paint. The paint had to some type of house paint (Like a Behr or something similar to that).
03 WJ AKA The Silver Bullet Voltage258 Jeep Builds 4 06-29-2011 09:35 PM
JK Silver with Silver hard top pics? gdok Jeep Picture Requests 0 03-09-2011 04:47 PM
Silver Jeeps with Black and Silver rims jsmaem1106 Jeep Picture Requests 6 09-05-2010 11:09 AM
The Silver Bullet causearuckus Jeep Builds 8 02-10-2010 03:33 PM
Silver Bullet Leland Jeep Builds 0 12-17-2001 02:48 PM
